    Magic Mirror flashing black screen after a power failure
    5 Posts 3 Posters 965 Views 3 Watching
    • L Offline
      lusiess01
      After an power failure my RaspberryPi have been starting up but MagicMirror only is a flashing black screen. I try pm2 restart MagicMirror but nothing changed.
      Can someone help me pleas?! I post the log below
      Thanks!!
      pm2 log MagicMirror
      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:685:19)
      0|MagicMir |     at require (internal/modules/cjs/helpers.js:16:16)
      0|MagicMir |     at /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/exports/electron.js:11:27
      0|MagicMir |     at Object.app (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/api/exports/electron.js:12:29)
      0|MagicMir | [2020-06-04 22:50:21.405] [ERROR]  TypeError: Cannot redefine property: applicationMenu
      0|MagicMir |     at Function.defineProperty (<anonymous>)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/app.js:37:8)
      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32)
      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:560:12)
      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
      0|MagicMir | [2020-06-04 22:50:20.341] [LOG]    Whoops! There was an uncaught exception...
      0|MagicMir | [2020-06-04 22:50:20.345] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-06-04 22:50:20.346] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-06-04 22:50:20.588] [LOG]    Whoops! There was an uncaught exception...
      0|MagicMir | [2020-06-04 22:50:20.604] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-06-04 22:50:20.606] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-06-04 22:50:20.847] [LOG]    Whoops! There was an uncaught exception...
      0|MagicMir | [2020-06-04 22:50:20.855] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-06-04 22:50:20.858] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-06-04 22:50:21.128] [LOG]    Whoops! There was an uncaught exception...
      0|MagicMir | [2020-06-04 22:50:21.146] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-06-04 22:50:21.148] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-06-04 22:50:21.399] [LOG]    Whoops! There was an uncaught exception...
      0|MagicMir | [2020-06-04 22:50:21.410] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-06-04 22:50:21.413] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @lusiess01
        @lusiess01 i am sad to say this looks like an SD card problem…
        lets see if we can work around it. reinstall the exact same version
        grep version ~/MagicMirror/node_modules/electron/package.json
        mv   ~/MagicMirror/node_modules/electron  ~/MagicMirror/node_modules/electron.save
        npm install electron@??? --only=prod  # where ??? is the version number from the 1st statement
        • BKeyportB Offline
          BKeyport Module Developer
          I agree with Sam here - I’d bet the SD card got bit from the power failure.
          • L Offline
            lusiess01 @sdetweil
            Thanks i tryed your way but i get this…
            pi@raspberrypi:~ $ npm install electron@6.1.7 --only=prod
            npm ERR! code EAI_AGAIN
            npm ERR! errno EAI_AGAIN
            npm ERR! request to https://registry.npmjs.org/electron failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
            npm ERR!     /home/pi/.npm/_logs/2020-06-05T06_21_53_740Z-debug.log
            • BKeyportB Offline
              um. That’s a DNS error. Basically “Try again later” – Might wanna try a new OS install on a new card, and if that don’t work, you’ve got some slightly burned hardware.
