    Mirror supplier in Ireland
    11 Posts 4 Posters 9.8k Views 4 Watching
    • G Offline
      Gazzamc
      Does anyone know of a supplier for a two way mirror (acrylic) in Ireland? If not the uk would be my last option.
        McSorley
        I used this in the UK.
        http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror
        I would recommend making sure you have the right size as it isn’t easy to cut yourself.
        • G Offline
          Gazzamc @McSorley
          @McSorley said in Mirror supplier in Ireland:
          Thank you for the reply, I’ve calculated my dimensions and it seems reasonable enough, only thing is I’m not sure if they ship to Ireland (I’ve shot them an email anyway).
          Now in the chance they do, how did yours turn out with it?
          ceddirrC 1 Reply Last reply Reply Quote 0
          • ceddirrC Offline
            ceddirr @Gazzamc
            @Gazzamc
            I am currently living in Ireland, so I am interested in this link. Did you finally get your order?
            • G Offline
              Gazzamc @ceddirr
              @ceddirr
              I actually went with glass so I found a source locally, for much cheaper too. If you’re interested it’s Mirror Zone… Its based in Tipperary.
              I got a relatively big piece (to cover a 32") for 150 with delivery to my door. It works really well in the mirror atm.
              Hopefully that helps you.
              ceddirrC D 2 Replies Last reply Reply Quote 0
              • ceddirrC Offline
                ceddirr @Gazzamc
                @Gazzamc
                Thank you very much for your help, please could you tell me the type keyword I should research to have a mirror which can work with this project?
                Because I think most of those mirrors are reals mirrors so won’t work with a screen behind?
                Thank you again!
                • G Offline
                  Gazzamc @ceddirr
                  @ceddirr
                  No problem, its called a “two way mirror” … You need to call them for a quote, they don’t have them online… They also refer to them as “spy mirrors”…
                  Best of luck with the project.
                    McSorley
                    I went with the supplier I linked. Worked a treat.
                    • ceddirrC Offline
                      ceddirr @McSorley
                      @McSorley Hi there,
                      Quick question about the supplier in the UK: the mirror is 3mm, which is quite thin, did it arrive in a good shape?
                      thank you in advance
                      Cedric
                        McSorley @ceddirr
                        @ceddirr Yes. Packaging was great. Was a good while ago now since I ordered it though.
                        I’d be careful if you want to cut it though. Make sure you order the right sizes.
