Mirror display not showing changes made to config filedock
9 Posts 3 Posters 1.1k Views 3 Watching
    Perkinje
    After making changes to the config file, like 12hr time format, adding modules etc. I restart MM and it’s as if no changes were made. It just displays the sample config. When I reopen the config file then changes are still there. I’ve even tried rebooting the whole pi with no luck. MM is running in a docker on a pi3.
    T 1 Reply Last reply Jun 13, 2020, 9:13 AM Reply Quote 0
    • T Offline
      thedoorsfanatic @Perkinje
      @Perkinje
      Did you rename the file to config.js?
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        Perkinje
        yes, the filename is config.js. It shows the default display config without my changes.
        S 1 Reply Last reply Jun 13, 2020, 3:50 PM Reply Quote 0
          sdetweil @Perkinje
          @Perkinje do you have something at boot that copies config.js.sample to config.js? perhaps?
          P 1 Reply Last reply Jun 13, 2020, 4:05 PM Reply Quote 0
            Perkinje @sdetweil
            @sdetweil nope, and when I reopen the config.js file my changes are still there.
            S 1 Reply Last reply Jun 13, 2020, 4:09 PM Reply Quote 0
              sdetweil @Perkinje
              @Perkinje so, let’s check this again
              the file used for running is
              ~/MagicMirror/config/config.js
              P 1 Reply Last reply Jun 13, 2020, 4:28 PM Reply Quote 0
                Perkinje @sdetweil
                @sdetweil Yes, it is. I don’t see how this is possible. I’ve checked the docker setup to confirm the location of the config/config.js and it is showing the file I’ve modified.
                S 1 Reply Last reply Jun 13, 2020, 4:35 PM Reply Quote 0
                  sdetweil @Perkinje
                  @Perkinje oh, docker… don’t know about that
                    Perkinje
                    I’ve given up docker. Runs fine with standard install. I’ll try docker with my next MM.
