    Twitter feed
    21 Posts 10 Posters 15.0k Views 10 Watching
    • mediathreatM
      mediathreat @enith2478
      @enith2478 does this give you a static or a dynamic feed from twitter?
      • MaxPowerM
        MaxPower
        Hi, does anybody has had any issues with TwitControl recently? My module stopped working, anything changed with API codes?
          StrIIker @MaxPower
          @maxpower said in Twitter feed:
          It’s possible that the recent changes at Twitter with regard to their API has caused some issues although these changes I believe went into effect in August…
          https://9to5mac.com/2018/08/07/twitter-api-change-tweetbot-twitterrific/
          MaxPowerM 1 Reply Last reply
          • MaxPowerM
            MaxPower @StrIIker
            @striiker probably around that time module stopped working. Not sure what to do next (
            • MaxPowerM
              MaxPower
              Hey guys! Does anyone has thier twitter feed on the mirror? What module you are using?
              C 1 Reply Last reply
                chassain 0 @MaxPower
                @MaxPower hello
                i m working with https://github.com/ulrichwisser/MMM-Widget2 and https://publish.twitter.com/# to embed the code…easy to integrate
                • MaxPowerM
                  MaxPower
                  @chassain-0 Thank you! I will try to do the same!
                  • MaxPowerM
                    MaxPower
                    @chassain-0 sorry, quick question, do I just copy and paste the code line from the https://publish.twitter.com/# and enter it in to the config control widget, under the code? I get a syntax error under this line.
                      @MaxPower just past the code line like this :
                        			module: "MMM-Widget1",  //ok tweet hyeres
                      			disabled: false,
                      			position: "left",
                      				refreshInterval: 1000*60*60,
                      				code: `<a class="twitter-timeline" href="https://twitter.com/villedhyeres?ref_src=twsrc%5Etfw">Tweets by villedhyeres</a> <script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script> `, // https://publish.twitter.com/
                       				iframeStyle: {
                      				width: "700px",
                              				height: "820px",
                      K 1 Reply Last reply
                      • MaxPowerM
                        MaxPower
                        @chassain-0 Thank you! I will try it!
                        • K
                          kasperb @chassain 0
                          @chassain-0 said in Twitter feed:
                            		code: `<a href="https://twitter.com/villedhyeres?ref_src=twsrc%5Etfw">Tweets by villedhyeres</a>  `, // https://publish.twitter.com/
                          Hi - did you have any other dependencies configured prior to adding this to your config? I just tried this (after installing the MMM-Widget2 app), but nothing is being displayed on the screen. My objective is to display the CNN breaking news feed from twitter.
                            chassain 0 @kasperb
                            @kasperb
                              			module: "MMM-Widget1",  //ok tweet CNN
                            			disabled: false,
                            			position: "left",
                            				code: `<a class="twitter-timeline" href="https://twitter.com/CNN?ref_src=twsrc%5Etfw">Tweets by CNN</a> <script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script>  `, // https://publish.twitter.com/
                             				iframeStyle: {
                            				width: "700px",
                                    				height: "820px",
                            looks like this in config MMM Widget2. no try in my magicmirror
                              chassain 0
                              don’t forget ‘…’ in code
