    Twitter feed
    21 Posts 10 Posters 13.0k Views 10 Watching
      deadherring
      Did anyone ever get the Twitter module working?
      • bheplerB Offline
        bhepler Module Developer
        Negative. I have, however, made some progress. Just FYI - If you attempt to position a module into a segment that doesn’t actually exist, you will receive an error of cannot read property 'appendChild' of undefined. This actually means “The position ‘center_left’ doesn’t actually exist, jerk.”
        Having fixed this, I now see the title “Twitter Feed” on my mirror. It does not, however, actually display any tweets. Still… progress.
        • G Offline
          gshimself
          Got any updates on this problem? I was about to use twitcontrol on my mirror but get same problem as above. Can only see the Title, but no feeds.
          • enith2478E Offline
            enith2478
            I converted the the desired twitter feed to RSS using https://twitrss.me/
            mediathreatM 1 Reply Last reply Reply Quote 0
            • mediathreatM Offline
              mediathreat @enith2478
              @enith2478 does this give you a static or a dynamic feed from twitter?
              • MaxPowerM Offline
                MaxPower
                Hi, does anybody has had any issues with TwitControl recently? My module stopped working, anything changed with API codes?
                  StrIIker @MaxPower
                  @maxpower said in Twitter feed:
                  It’s possible that the recent changes at Twitter with regard to their API has caused some issues although these changes I believe went into effect in August…
                  https://9to5mac.com/2018/08/07/twitter-api-change-tweetbot-twitterrific/
                  MaxPowerM 1 Reply Last reply Reply Quote 0
                  • MaxPowerM Offline
                    MaxPower @StrIIker
                    @striiker probably around that time module stopped working. Not sure what to do next (
                    • MaxPowerM Offline
                      MaxPower
                      Hey guys! Does anyone has thier twitter feed on the mirror? What module you are using?
                        chassain 0 @MaxPower
                        @MaxPower hello
                        i m working with https://github.com/ulrichwisser/MMM-Widget2 and https://publish.twitter.com/# to embed the code…easy to integrate
