    Twitter feed
    21 Posts 10 Posters 12.9k Views 10 Watching
    • bheplerB Offline
      bhepler Module Developer @deadherring
      @deadherring I have not. But I do want to report that I am having the same issue.
      • MitchfarinoM Offline
        Mitchfarino Module Developer
        Post your config so people can check it
        • bheplerB Offline
          Sorry for the delay. Here’s the relevant portion of my config:
               module: 'twitControl',
               position: 'middle_left',
                         maxNumTweets: 3,
                         consumer_key: '[redacted]',
                         consumer_secret: '[redacted]',
                         access_token_key: '[redacted]',
                         access_token_secret: '[redacted]'
            deadherring
            Did anyone ever get the Twitter module working?
            • bheplerB Offline
              Negative. I have, however, made some progress. Just FYI - If you attempt to position a module into a segment that doesn’t actually exist, you will receive an error of cannot read property 'appendChild' of undefined. This actually means “The position ‘center_left’ doesn’t actually exist, jerk.”
              Having fixed this, I now see the title “Twitter Feed” on my mirror. It does not, however, actually display any tweets. Still… progress.
              • G Offline
                gshimself
                Got any updates on this problem? I was about to use twitcontrol on my mirror but get same problem as above. Can only see the Title, but no feeds.
                • enith2478E Offline
                  enith2478
                  I converted the the desired twitter feed to RSS using https://twitrss.me/
                  mediathreatM 1 Reply Last reply Reply Quote 0
                  • mediathreatM Offline
                    mediathreat @enith2478
                    @enith2478 does this give you a static or a dynamic feed from twitter?
                    • MaxPowerM Offline
                      MaxPower
                      Hi, does anybody has had any issues with TwitControl recently? My module stopped working, anything changed with API codes?
                        StrIIker @MaxPower
                        @maxpower said in Twitter feed:
                        It’s possible that the recent changes at Twitter with regard to their API has caused some issues although these changes I believe went into effect in August…
                        https://9to5mac.com/2018/08/07/twitter-api-change-tweetbot-twitterrific/
                        MaxPowerM 1 Reply Last reply Reply Quote 0
