Solved covid bell curve line graph tracker
@darbos for the spike, move the start day to the 2nd or 3rd
@sdetweil here is my cases by day by state
min 0, max 500, step 500
(chart 300x300)one cool thing, when u make the step low, u can turn off individual sources to see the remaining adjust
just click on the legend entry to turn it offlooks like Michigan had a reporting spike
Looks like the EU site used for the data is currently down
@sdetweil Sorry for just getting back. Thanks for taking the time to explain and help.
I follow what your saying and made the changes. Looks like the reporting site is down so I will have to wait to make sure mine looks as good as yours:)
Thanks again.
@sdetweil Would you mind double checking my config, Im still seeing a large spike at the begining…
Ive tried changing the start date to the 3rd, 10th, and 12th with the same result. Ive also tried both 0,100,100 and 0,500,500.
Thank you much!
{ module:"MyCovid19", position:"bottom_center", config:{ states:['Arizona','Michigan','California'], line_colors:['red','white','blue'], chart_type:"cases", chart_title:"COVID Cases Reported Daily", ranges:{min:0,max:500,stepSize:500}, backgroundColor: "transparent", width: 600, height: 500, debug: false, startDate: '06/12/2020' } },
***EDIT: The copy/paste spacing is off, but I double checked and spacing is correct in my file…with no trailing white space.
@sdetweil Its like its pulling the total first and then displaying dailys no matter what date I start at…I think anyway.
@darbos I see the same will debug later tonight. family dinner first
@sdetweil ok thank you much!!!
@darbos nice bug, been there since the beginning…
the countries give me daily counts, and I have to calculate accumulative (1st day to last)
the states/counties give me cumulative and I have to calculate dailys… (last day to 1st)…but I had cut off the number of days to the start date, and needed ONE more day to calculate the daily for the requested start day
didn’t see it before, because back in feb/march the accum for states as near 0
thanks for the good recreate…
do a git pull in the module folder and restart magic mirror
@sdetweil Your awesome man. Working perfect now, thanks so much!!!
