    can't run "npm run start"
    25 Posts 3 Posters 9.3k Views 3 Watching
      jefftse @sdetweil
      XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
      XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
      DISPLAY=:0.0
        sdetweil @jefftse
        @jefftse do u have a real display
          jefftse @sdetweil
          @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
            sdetweil @jefftse
            @jefftse did u use my install script? can’t understand why u are having trouble
              jefftse @sdetweil
              @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
                sdetweil @jefftse
                @jefftse not supposed to be root
                are u trying to run as root?
                can’t do that
                  jefftse @sdetweil
                  @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                    sdetweil @jefftse
                    @jefftse I don’t understand created a user.
                    raspian installs and starts with user pi
                      @sdetweil you are running under the same user as during install time, right?
                        jefftse @sdetweil
                        @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                        one question, I just enabled auto start and how do i disable it ? I need to config the config file
                          jefftse @sdetweil
                          @sdetweil Thank you!
                            sdetweil @jefftse
                            @jefftse pm2 stop
                            then when you reboot it won’t come up again
                              @sdetweil u can use npm start to test
