    can't run "npm run start"
    25 Posts 3 Posters 9.3k Views 3 Watching
      jefftse @sdetweil
      @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
        sdetweil @jefftse
        @jefftse did u use my install script? can’t understand why u are having trouble
          jefftse @sdetweil
          @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
            sdetweil @jefftse
            @jefftse not supposed to be root
            are u trying to run as root?
            can’t do that
              jefftse @sdetweil
              @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                sdetweil @jefftse
                @jefftse I don’t understand created a user.
                raspian installs and starts with user pi
                  @sdetweil you are running under the same user as during install time, right?
                    jefftse @sdetweil
                    @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                    one question, I just enabled auto start and how do i disable it ? I need to config the config file
                      jefftse @sdetweil
                      @sdetweil Thank you!
                        sdetweil @jefftse
                        @jefftse pm2 stop
                        then when you reboot it won’t come up again
                          @sdetweil u can use npm start to test
