    can't run "npm run start"
    25 Posts 3 Posters 8.9k Views 3 Watching
      actimbar @sdetweil
      @sdetweil by VNC desktop, I got stuck on step 4 of manual installation (npm install), I made a reboot before the error, now I’m trying (npm install) without VNC.
      Now installation ended successfully!
        jefftse @sdetweil
        Raspberry pi 4 raspbrian
          jefftse @sdetweil
          I did and the same thing
            sdetweil @jefftse
            @jefftse are u doing this over vnc without a real display?
            the start script assumes a real display
            change the package.json start to match your config
            the start command is
            npm start
              jefftse @sdetweil
              I tried both. I even deleted the whole folder and reinstalled. Maybe electron is the problem.
                sdetweil @jefftse
                @jefftse no, change the line in package.json
                from
                to
                 "start": "./node_modules/.bin/electron js/electron.js",
                the error is " cannot open display: :0.0" typically, DISPLAY:0 is the physical display
                  jefftse @sdetweil
                  just did that and the error is below
                  magicmirror@2.11.0 start /home/jeff/MagicMirror
                  No protocol specified
                  (electron:32527): Gtk-WARNING **: 21:53:58.634: cannot open display: :0.0
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.11.0 start: electron js/electron.js
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.11.0 start script.
                  npm ERR! /home/jeff/.npm/_logs/2020-06-24T01_53_58_663Z-debug.log
                    sdetweil @jefftse
                    @jefftse still trying to open display 0
                    what is the vnc display number? do
                    env | grep -i display
                      jefftse @sdetweil
                      XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
                      XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
                      DISPLAY=:0.0
                        sdetweil @jefftse
                        @jefftse do u have a real display
                          jefftse @sdetweil
                          @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
                            sdetweil @jefftse
                            @jefftse did u use my install script? can’t understand why u are having trouble
                              jefftse @sdetweil
                              @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
                                sdetweil @jefftse
                                @jefftse not supposed to be root
                                are u trying to run as root?
                                can’t do that
                                  jefftse @sdetweil
                                  @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                                    sdetweil @jefftse
                                    @jefftse I don’t understand created a user.
                                    raspian installs and starts with user pi
                                      @sdetweil you are running under the same user as during install time, right?
                                        jefftse @sdetweil
                                        @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                                        one question, I just enabled auto start and how do i disable it ? I need to config the config file
                                          jefftse @sdetweil
                                          @sdetweil Thank you!
                                            sdetweil @jefftse
                                            @jefftse pm2 stop
                                            then when you reboot it won’t come up again
