    can't run "npm run start"
    25 Posts 3 Posters 9.0k Views 3 Watching
      sdetweil @actimbar
      @actimbar did u use the install script?
      A J 2 Replies Last reply Reply Quote 0
        actimbar @sdetweil
        @sdetweil by VNC desktop, I got stuck on step 4 of manual installation (npm install), I made a reboot before the error, now I’m trying (npm install) without VNC.
        Now installation ended successfully!
          jefftse @sdetweil
          Raspberry pi 4 raspbrian
            jefftse @sdetweil
            I did and the same thing
              sdetweil @jefftse
              @jefftse are u doing this over vnc without a real display?
              the start script assumes a real display
              change the package.json start to match your config
              the start command is
              npm start
                jefftse @sdetweil
                I tried both. I even deleted the whole folder and reinstalled. Maybe electron is the problem.
                  sdetweil @jefftse
                  @jefftse no, change the line in package.json
                  from
                  to
                   "start": "./node_modules/.bin/electron js/electron.js",
                  the error is " cannot open display: :0.0" typically, DISPLAY:0 is the physical display
                    jefftse @sdetweil
                    just did that and the error is below
                    magicmirror@2.11.0 start /home/jeff/MagicMirror
                    No protocol specified
                    (electron:32527): Gtk-WARNING **: 21:53:58.634: cannot open display: :0.0
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.11.0 start: electron js/electron.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.11.0 start script.
                    npm ERR! /home/jeff/.npm/_logs/2020-06-24T01_53_58_663Z-debug.log
                      sdetweil @jefftse
                      @jefftse still trying to open display 0
                      what is the vnc display number? do
                      env | grep -i display
                        jefftse @sdetweil
                        XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
                        XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
                        DISPLAY=:0.0
                          sdetweil @jefftse
                          @jefftse do u have a real display
                            jefftse @sdetweil
                            @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
                              sdetweil @jefftse
                              @jefftse did u use my install script? can’t understand why u are having trouble
                                jefftse @sdetweil
                                @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
                                  sdetweil @jefftse
                                  @jefftse not supposed to be root
                                  are u trying to run as root?
                                  can’t do that
                                    jefftse @sdetweil
                                    @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                                      sdetweil @jefftse
                                      @jefftse I don’t understand created a user.
                                      raspian installs and starts with user pi
                                        @sdetweil you are running under the same user as during install time, right?
                                          jefftse @sdetweil
                                          @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                                          one question, I just enabled auto start and how do i disable it ? I need to config the config file
                                            jefftse @sdetweil
                                            @sdetweil Thank you!
