    can't run "npm run start"
    25 Posts 3 Posters 7.8k Views 3 Watching
      jefftse
      I can do “npm run server” but not “npm run start”
      Any takers?
      magicmirror@2.11.0 start /home/jeff/MagicMirror
      No protocol specified
      (electron:17603): Gtk-WARNING **: 18:42:53.065: cannot open display: :0.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR! /home/jeff/.npm/_logs/2020-06-23T22_42_53_102Z-debug.log
      A S 2 Replies Last reply Reply Quote 0
        actimbar @jefftse
        @jefftse i had an error yesterday on a clean installation of raspberrian with npm and electron was involved, but I did it from another virtual desktop, (working with unencrypted VNC server) working on finding a solution.
          sdetweil @jefftse
          @jefftse what os platform is this?
          did you do manual install or use the script?
            sdetweil @actimbar
            @actimbar did u use the install script?
            A J 2 Replies Last reply Reply Quote 0
              actimbar @sdetweil
              @sdetweil by VNC desktop, I got stuck on step 4 of manual installation (npm install), I made a reboot before the error, now I’m trying (npm install) without VNC.
              Now installation ended successfully!
                jefftse @sdetweil
                Raspberry pi 4 raspbrian
                  jefftse @sdetweil
                  I did and the same thing
                    sdetweil @jefftse
                    @jefftse are u doing this over vnc without a real display?
                    the start script assumes a real display
                    change the package.json start to match your config
                    the start command is
                    npm start
                      jefftse @sdetweil
                      I tried both. I even deleted the whole folder and reinstalled. Maybe electron is the problem.
                        sdetweil @jefftse
                        @jefftse no, change the line in package.json
                        from
                        to
                         "start": "./node_modules/.bin/electron js/electron.js",
                        the error is " cannot open display: :0.0" typically, DISPLAY:0 is the physical display
