    can't run "npm run start"
    25 Posts 3 Posters 8.0k Views 3 Watching
      jefftse @sdetweil
      Raspberry pi 4 raspbrian
        jefftse @sdetweil
        I did and the same thing
          sdetweil @jefftse
          @jefftse are u doing this over vnc without a real display?
          the start script assumes a real display
          change the package.json start to match your config
          the start command is
          npm start
            jefftse @sdetweil
            I tried both. I even deleted the whole folder and reinstalled. Maybe electron is the problem.
              sdetweil @jefftse
              @jefftse no, change the line in package.json
              from
              to
               "start": "./node_modules/.bin/electron js/electron.js",
              the error is " cannot open display: :0.0" typically, DISPLAY:0 is the physical display
                jefftse @sdetweil
                just did that and the error is below
                magicmirror@2.11.0 start /home/jeff/MagicMirror
                No protocol specified
                (electron:32527): Gtk-WARNING **: 21:53:58.634: cannot open display: :0.0
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.11.0 start: electron js/electron.js
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.11.0 start script.
                npm ERR! /home/jeff/.npm/_logs/2020-06-24T01_53_58_663Z-debug.log
                  sdetweil @jefftse
                  @jefftse still trying to open display 0
                  what is the vnc display number? do
                  env | grep -i display
                    jefftse @sdetweil
                    XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
                    XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
                    DISPLAY=:0.0
                      sdetweil @jefftse
                      @jefftse do u have a real display
                        jefftse @sdetweil
                        @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
