    can't run "npm run start"
    25 Posts 3 Posters 9.6k Views 3 Watching
      sdetweil @jefftse
      @jefftse still trying to open display 0
      what is the vnc display number? do
      env | grep -i display
      J 1 Reply Last reply
        jefftse @sdetweil
        XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
        XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
        DISPLAY=:0.0
          sdetweil @jefftse
          @jefftse do u have a real display
            jefftse @sdetweil
            @sdetweil yes, in fact, i had it all working yesterday till I accident broken my sd card. I had to rebuild everything today.
              sdetweil @jefftse
              @jefftse did u use my install script? can’t understand why u are having trouble
                jefftse @sdetweil
                @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
                  sdetweil @jefftse
                  @jefftse not supposed to be root
                  are u trying to run as root?
                  can’t do that
                    jefftse @sdetweil
                    @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
                      sdetweil @jefftse
                      @jefftse I don’t understand created a user.
                      raspian installs and starts with user pi
                        @sdetweil you are running under the same user as during install time, right?
                        J 2 Replies Last reply
                          jefftse @sdetweil
                          @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                          one question, I just enabled auto start and how do i disable it ? I need to config the config file
                            jefftse @sdetweil
                            @sdetweil Thank you!
                              sdetweil @jefftse
                              @jefftse pm2 stop
                              then when you reboot it won’t come up again
                                @sdetweil u can use npm start to test
