    can't run "npm run start"
    25 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @jefftse
      @jefftse did u use my install script? can’t understand why u are having trouble
        jefftse @sdetweil
        @sdetweil sure did. I had to create an user to run your script since it wouldn’t allow me to do in root
          sdetweil @jefftse
          @jefftse not supposed to be root
          are u trying to run as root?
          can’t do that
            jefftse @sdetweil
            @sdetweil correct, and I created an user for the install. the install went fine. I just can’t run it!
              sdetweil @jefftse
              @jefftse I don’t understand created a user.
              raspian installs and starts with user pi
                @sdetweil you are running under the same user as during install time, right?
                  jefftse @sdetweil
                  @sdetweil i think i got it working. I deleted everything and run your script again in “pi” user.
                  one question, I just enabled auto start and how do i disable it ? I need to config the config file
                    jefftse @sdetweil
                    @sdetweil Thank you!
                      sdetweil @jefftse
                      @jefftse pm2 stop
                      then when you reboot it won’t come up again
                        @sdetweil u can use npm start to test
