    MMM-Assistant2Display doesn´t show any photos
    4 Posts 2 Posters 850 Views 2 Watching
    • K Offline
      Klinge
      I installed the modules MMM-GoogleAssistant and MMM-Assistant2Display.
      But I have a problem with displaying photos.
      When I sayed, “JARVIS, show me a video from the soccer game Brazil vs Germany”, a Youtube-Video will be shown.
      But when I sayed, “JARVIS, show me a photo from a tree”, only a google-Link will be shown.
      Here you can see my config file
      var config = {
                electronOptions: {
                       webPreferences: {
                            webviewTag: true
              port: 8080,
                       module: "MMM-GoogleAssistant",
                        position: "fullscreen_above",
                          debug: true,
                          assistantConfig: {
                            lang: "de-DE",
                            projectId: "", // Required to use gaction.
                            modelId: "", // (OPTIONAL for gaction)
                            instanceId: "", // (OPTIONAL for gaction)
                            latitude: XX.XXXXX,
                            longitude: X.XXXXXXX,
                          responseConfig: {
                            useScreenOutput: true,
                            screenOutputCSS: "screen_output.css",
                            screenOutputTimer: 5000,
                            activateDelay: 250,
                            useAudioOutput: true,
                            useChime: true,
                            newChime: false
                          micConfig: { // put there configuration generated by auto-installer
                            recorder: "arecord",
                            device: "plughw:1",
                          customActionConfig: {
                            autoMakeAction: false,
                            autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                            actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                          snowboy: {
                            audioGain: 2.0,
                            Frontend: true,
                            Model: "jarvis",
                            Sensitivity: null
                          A2DServer: {
                            useA2D: true,
                            stopCommand: "stop"
                          recipes: [ "with-MMM-TelegramBot.js" ]
                      module: "MMM-Assistant2Display",
                          debug:true,
                      photos: {
                            usePhotos: true,
                            displayDelay: 10 * 1000
                  spotify: {
                            useSpotify: true,
                            connectTo: null,
                            playDelay: 3000,
                            minVolume: 10,
                            maxVolume: 100
      I enabled the debugging. But I don´t know, where I can find the logs.
      Unfortunately I didn´t found something in this forum.
      It would be great if someone could help me.
      Thanks in advance.
      Klinge
        [[global:former-user]]
        usePhotos functionality is for displaying your own google photos album
        So it’s not for displaying web-links, you can use links module for this
        • K Offline
          Klinge
          thank you for your response.
          Then I obviously got it wrong. I searched for the links module, but unfortunately I couldn’t find it or anything like this.
          Please, can you give me a tip, which module you mean exactly.
          Thanks in advance.
            check the Assistant2Display wiki
