    covid bell curve line graph tracker
    89 Posts 6 Posters 71.1k Views 8 Watching
      darbos @sdetweil
      @sdetweil Would you mind double checking my config, Im still seeing a large spike at the begining…
      Ive tried changing the start date to the 3rd, 10th, and 12th with the same result. Ive also tried both 0,100,100 and 0,500,500.
      Thank you much!
      		module:"MyCovid19",
      		position:"bottom_center",
      		config:{
      			states:['Arizona','Michigan','California'],
      			line_colors:['red','white','blue'],
      			chart_type:"cases",
      			chart_title:"COVID Cases Reported Daily",
      			ranges:{min:0,max:500,stepSize:500},
                                  backgroundColor: "transparent",
      		      width: 600,
      		      height: 500,
      		      debug: false,
      		      startDate: '06/12/2020'
      ***EDIT: The copy/paste spacing is off, but I double checked and spacing is correct in my file…with no trailing white space.
        darbos @sdetweil
        @sdetweil Its like its pulling the total first and then displaying dailys no matter what date I start at…I think anyway.
          sdetweil @darbos
          @darbos I see the same will debug later tonight. family dinner first
            darbos @sdetweil
            @sdetweil ok thank you much!!!
              sdetweil @darbos
              @darbos nice bug, been there since the beginning…
              the countries give me daily counts, and I have to calculate accumulative (1st day to last)
              the states/counties give me cumulative and I have to calculate dailys… (last day to 1st)…
              but I had cut off the number of days to the start date, and needed ONE more day to calculate the daily for the requested start day
              didn’t see it before, because back in feb/march the accum for states as near 0
              thanks for the good recreate…
              do a git pull in the module folder and restart magic mirror
                darbos @sdetweil
                @sdetweil Your awesome man. Working perfect now, thanks so much!!!
                  the country data is back online…
                  based on the emails i exchanged with them I expect the files will go offline again, but don’t have any idea when
                  they are moving things to a different server… the xlsx is already there, but we use the csv.
                    darbos @sdetweil
                    @sdetweil it looks like mine stopped updating. The past two days haven’t shown on my mirror or the one I made for my dad. I’ve rebooted them a few times, is anyone else seeing the same?
                      sdetweil @darbos
                      @darbos mine is updating… there was a problem with countries last week, but since resolved. and I just verified the data downloads with new data
                      can u open the developers window, ctrl-shift-i, select the tab labeled console and add My to the filter field?
                      also, look at the console where u start MM…
                      pm2 logs–lines=100 (if pm2)
                      or
                      the npm start window if you use npm
                        darbos @sdetweil
                        @sdetweil awesome thanks for the quick response I’ll check it out
                          darbos @sdetweil
                          @sdetweil Sorry about the firedrill, after running pm2 restart mm it updated.
                          I know this isnt the best way, but I have it connected to a smart switch and just tell google to turn it off and on…i havent had an issue and had it this way over a year. Might have just got hung up, but issue is solved. Thanks again for the quick help sir.
                            sdetweil @darbos
                            @darbos ok, did u save the pm2 logs?? I’d love to see them
                              darbos @sdetweil
                              @sdetweil sorry I did not see this till now. If it happens again I’ll be sure to grab them. It happened on both mine and my dad’s mirror so I’ll let him know to give me a heads up too. Thanks !
                              • 5 / 5
