    Send existing Notifications from a script
    15 Posts 3 Posters 4.9k Views 3 Watching
      u changed the code here from this. to self.
      => this.sendSocketNotification("SHUTDOWN
      and all similar
      thetobydeT 2 Replies Last reply
      • thetobydeT
        thetobyde @sdetweil
        @sdetweil i changed the code in the nodeHelper from this. to self.
        • thetobydeT
          thetobyde @sdetweil
          meinCode
          Like this :)
            sdetweil @thetobyde
            @thetobyde and the module code with the buttons?
            thetobydeT 1 Reply Last reply
            • thetobydeT
              thetobyde @sdetweil
              @sdetweil didt change that because it worked for the pre-existing Shutdown and Reboot button from the developer of MMM-smartTouch… isnt it right?
                sdetweil @thetobyde
                @thetobyde said in Send existing Notifications from a script:
                require('child_process').this.sendSocketNotification("PAGE_CHANGED", 1);
                well, you are not launching a program to chnage the page, and don’t need to send this down to the node_helper
                as he has to send it back up to the module to send the notfication,
                just do the sendNotification from the module (note its not sendsocketNotification(to my node helper) , just sendNotification(to other modules)
                • lavolp3L
                  lavolp3 Module Developer
                  @thetobyde if you haven’t figured it out yet, have a look at my module https://github.com/lavolp3/MMM-NavigationBar which kind of does what you want. This one is using MMM-pages as well.
                  ALl that I needed for this to work out is this:
                    getDom: function() {
                      var container = document.createElement("div");
                      container.className = "naviContainer";
                      self = this;
                      for (var i = 0; i < this.config.sections.length; i++) {
                        var buttonDiv = document.createElement("div");
                        buttonDiv.className = "naviButton fas fa-"+this.config.sectionIcons[this.config.sections[i]];
                        buttonDiv.style.fontSize = this.config.iconSize + "px";
                        button.addEventListener("click", function() {
                          self.sendNotification("PAGE_CHANGED", i);
                        //this.log(buttonDiv.className);
                        container.appendChild(buttonDiv);
                      return container;
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • lavolp3L
                    @thetobyde I think you should avoid the node_helper and directly send a broadcast notification via self.sendNotification() to to the MMM-pages module.
                      sdetweil @lavolp3
                      @lavolp3 which is what I said 3 posts back
                      lavolp3L 1 Reply Last reply
                      • lavolp3L
                        @sdetweil sorry read thorugh it too fast
                        • thetobydeT
                          thetobyde
                          It‘s working! Thx u!!
