    Send existing Notifications from a script
    15 Posts 3 Posters 4.7k Views 3 Watching
    • thetobydeT Offline
      thetobyde @sdetweil
      @sdetweil thx for the fast answer. I change „this.send…“ to „self.send…“ but did not work sadly… i also changed the payload from 1 to 0, because the notifications from MMM-pages are zero-based. So page 1 is PAGE_CHANGED, 0…
      The var self = this is written by the Developer of MMM-SmartTouch
        sdetweil @thetobyde
        @thetobyde did step thru the code w the developers window source tab?
          u changed the code here from this. to self.
          => this.sendSocketNotification("SHUTDOWN
          and all similar
          thetobydeT 2 Replies Last reply Reply Quote 0
            thetobyde @sdetweil
            @sdetweil i changed the code in the nodeHelper from this. to self.
              thetobyde @sdetweil
              meinCode
              Like this :)
                sdetweil @thetobyde
                @thetobyde and the module code with the buttons?
                thetobydeT 1 Reply Last reply Reply Quote 0
                  thetobyde @sdetweil
                  @sdetweil didt change that because it worked for the pre-existing Shutdown and Reboot button from the developer of MMM-smartTouch… isnt it right?
                    sdetweil @thetobyde
                    @thetobyde said in Send existing Notifications from a script:
                    require('child_process').this.sendSocketNotification("PAGE_CHANGED", 1);
                    well, you are not launching a program to chnage the page, and don’t need to send this down to the node_helper
                    as he has to send it back up to the module to send the notfication,
                    just do the sendNotification from the module (note its not sendsocketNotification(to my node helper) , just sendNotification(to other modules)
                    • lavolp3L Offline
                      lavolp3 Module Developer
                      @thetobyde if you haven’t figured it out yet, have a look at my module https://github.com/lavolp3/MMM-NavigationBar which kind of does what you want. This one is using MMM-pages as well.
                      ALl that I needed for this to work out is this:
                        getDom: function() {
                          var container = document.createElement("div");
                          container.className = "naviContainer";
                          self = this;
                          for (var i = 0; i < this.config.sections.length; i++) {
                            var buttonDiv = document.createElement("div");
                            buttonDiv.className = "naviButton fas fa-"+this.config.sectionIcons[this.config.sections[i]];
                            buttonDiv.style.fontSize = this.config.iconSize + "px";
                            button.addEventListener("click", function() {
                              self.sendNotification("PAGE_CHANGED", i);
                            //this.log(buttonDiv.className);
                            container.appendChild(buttonDiv);
                          return container;
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • lavolp3L Offline
                        @thetobyde I think you should avoid the node_helper and directly send a broadcast notification via self.sendNotification() to to the MMM-pages module.
                          sdetweil @lavolp3
                          @lavolp3 which is what I said 3 posts back
                          • lavolp3L Offline
                            @sdetweil sorry read thorugh it too fast
                              thetobyde
                              It‘s working! Thx u!!
