    Send existing Notifications from a script
    15 Posts 3 Posters 4.1k Views 3 Watching
    • thetobydeT Offline
      thetobyde
      Hey :)
      I want to re-write the “MMM-SmartTouch” Module to have an “App-Dock-Bar”. I was able to change the CSS file to have this look now:
      I also was able to add the first 4 buttons with costom icons. I want to have these icons to change the pages with “MMM-pages”.
      The pages module listens on these Notifications: PAGE_CHANGED, pageNumber
      But I cant get it to work. This is my smartTouch.js and my nodeHelper:
      MMM-smartTouch.js :
      //Main Menu Bar
              var main_menu = document.createElement("div");
              main_menu.className = "main-menu"
              main_menu.id = "navbar"
              home_div.appendChild(main_menu)
              var main_menu_ul = document.createElement("ul");
              main_menu_ul.className = "navbar-nav"
              main_menu.appendChild(main_menu_ul)
      	//Page 1 (Home Screen)
              var main_menu_li_restart = document.createElement("span");
              main_menu_li_restart.innerHTML = "<span class='fas fa-home fa-3x'></span>" + "&nbsp" + "&nbsp" + "&nbsp" + "&nbsp";
              main_menu_li_restart.className = "li-t"
              main_menu_ul.appendChild(main_menu_li_restart)
              main_menu_li_restart.addEventListener("click", () => this.sendSocketNotification("PAGEONE", {}));
      	//Page 2 (Wetter)
              main_menu_li_restart.innerHTML = "<span class='fas fa-cloud-sun fa-3x'></span>" + "&nbsp" + "&nbsp" + "&nbsp" + "&nbsp";
              main_menu_li_restart.addEventListener("click", () => this.sendSocketNotification("SHUTDOWN", {}));
      	//Page 3 (Drive Bilder)
              main_menu_li_restart.innerHTML = "<span class='far fa-image fa-3x'></span>" + "&nbsp" + "&nbsp" + "&nbsp" + "&nbsp";
      	//Page 4 (Party Bilder)
              //Power Off Button
              var main_menu_li_shutdown = document.createElement("span");
              main_menu_li_shutdown.innerHTML = "<span class='fa fa-power-off fa-3x'></span>" + "&nbsp" + "&nbsp" + "&nbsp" + "&nbsp";
              main_menu_li_shutdown.className = "li-t"
              main_menu_ul.appendChild(main_menu_li_shutdown)
              //Onclick event to send shutdown notification
              main_menu_li_shutdown.addEventListener("click", () => this.sendSocketNotification("SHUTDOWN", {}));
              //Restart Button
              main_menu_li_restart.innerHTML = "<span class='fa fa-repeat fa-3x'></span>" + "&nbsp" + "&nbsp" + "&nbsp" + "&nbsp";
              main_menu_li_restart.addEventListener("click", () => this.sendSocketNotification("RESTART", {}));
      and my nodeHelper.js:
      if (notification === "PAGEONE") {
                    console.log("Page1!")
                    require('child_process').this.sendSocketNotification("PAGE_CHANGED", 1);
      	  if (notification === "SHUTDOWN") {
                    console.log("Shutting Down!")
                    require('child_process').exec('shutdown -h now', console.log)
                if (notification === "RESTART") {
                    console.log("Restarting Magic Mirror!")
                    require('child_process').exec('sudo reboot', console.log)
      nothing happens when i touch the first (Page1) icon…
      Thx for help! :) Toby
        sdetweil @thetobyde
        @thetobyde in your click handlers, ‘this’ points to the button causing the click.
        this is why we do
        var self=this
        and use self. in handlers and callbacks
        instead of this.
        you should see the error reported in the developers window console
        thetobydeT 1 Reply Last reply Reply Quote 0
          thetobyde @sdetweil
          @sdetweil thx for the fast answer. I change „this.send…“ to „self.send…“ but did not work sadly… i also changed the payload from 1 to 0, because the notifications from MMM-pages are zero-based. So page 1 is PAGE_CHANGED, 0…
          The var self = this is written by the Developer of MMM-SmartTouch
            sdetweil @thetobyde
            @thetobyde did step thru the code w the developers window source tab?
              u changed the code here from this. to self.
              and all similar
              thetobydeT 2 Replies Last reply Reply Quote 0
                thetobyde @sdetweil
                @sdetweil i changed the code in the nodeHelper from this. to self.
                  thetobyde @sdetweil
                  meinCode
                  Like this :)
                    sdetweil @thetobyde
                    @thetobyde and the module code with the buttons?
                      thetobyde @sdetweil
                      @sdetweil didt change that because it worked for the pre-existing Shutdown and Reboot button from the developer of MMM-smartTouch… isnt it right?
                        sdetweil @thetobyde
                        @thetobyde said in Send existing Notifications from a script:
                        well, you are not launching a program to chnage the page, and don’t need to send this down to the node_helper
                        as he has to send it back up to the module to send the notfication,
                        just do the sendNotification from the module (note its not sendsocketNotification(to my node helper) , just sendNotification(to other modules)
