weatherforecast showing only two days.
@erik-voznak said in weatherforecast showing only two days.:
you shouldn’t have posted it but I checked your appid and is wrong or not valid {code 401}
Had the same issue after the update.
The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx
)This results in a
401
for me because I’m using a free API token.Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same
cnt
value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx
). Here the value7
forcnt
returns 7 entries, that’s why there is only a two day forecast.I’ll try to write a fix.
In the meantime as a quick fix you can change line 297 ofweatherforecast.js
from:params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
to
params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
This fix worked for me too, so thanks very much.
Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
Ho-hum…
how about no quotes
showRainAmount: false,
values that are all numbers, or true and false do not need quotes
everything else does need quotes -
@sdetweil Great, that sorted things nicely!
How ever did I miss that in the config instructions… :astonished_face:
@oemel09 Thanks a lot!
Thanks for the ‘quick fix’ - Works perfectly.
Will this be fixed in the next update or do we need to adjust manually?
@ArthurOff next release (3 months), OR you can use the develop branch now til then, 2.12+.
