    weatherforecast showing only two days.
    31 Posts 22 Posters 13.7k Views 21 Watching
    • E Offline
      erik.voznak @lavolp3
      @lavolp3
      tried right now and no change.
      maxNumberOfDays: 7,
      colored: “true”,
      fade: “false”,
      fadePoint: 1,
      lavolp3L 1 Reply Last reply Reply Quote -1
      • lavolp3L Offline
        lavolp3 Module Developer @erik.voznak
        @erik-voznak @heeroy
        Have you updated?
        Seems to be fixed in latest release from this morning
        https://github.com/MichMich/MagicMirror/issues/2018
        https://forum.magicmirror.builders/topic/13182/v2-12-0
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • E Offline
          @lavolp3
          I did update this morning and issue started after update…
          [2020-07-02 13:37:30.638] [LOG] Starting MagicMirror: v2.12.0
          [2020-07-02 13:37:30.651] [LOG] Loading config …
            A Former User
            • O Offline
              oemel09
              Had the same issue after the update.
              The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx)
              This results in a 401 for me because I’m using a free API token.
              Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same cnt value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx). Here the value 7 for cnt returns 7 entries, that’s why there is only a two day forecast.
              I’ll try to write a fix.
              In the meantime as a quick fix you can change line 297 of weatherforecast.js from:
              params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
              to
              params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
              Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
              E T D W H 6 Replies Last reply Reply Quote 9
              • E Offline
                erik.voznak @oemel09
                @hango, yeah I know I shouldn`t but I am using free API so… but anyway I will change appid.
                @oemel09, Many thanks man, your fix helped and finally it is working as intended.
                alt text
                  castletonroad
                  This fix worked for me too, so thanks very much.
                  Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
                  This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
                  And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
                  Ho-hum…
                  S kayakbabeK 2 Replies Last reply Reply Quote 1
                    sdetweil @castletonroad
                    @castletonroad
                    how about no quotes
                    showRainAmount: false,
                    values that are all numbers, or true and false do not need quotes
                    everything else does need quotes
                      castletonroad @sdetweil
                      @sdetweil Great, that sorted things nicely!
                      How ever did I miss that in the config instructions… :astonished_face:
                      • T Offline
                        tenyo @oemel09
                        @oemel09 Thanks a lot!
                        • 1 / 4
