    V2.12.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 2.0k Views 1 Watching
    • MichMichM Offline
      MichMich
      [2.12.0] - 2020-07-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.12.0
      Special thanks to the following contributors: @AndreKoepke, @andrezibaia, @bryanzzhu, @chamakura, @DarthBrento, @Ekristoffe, @khassel, @Legion2, @ndom91, @radokristof, @rejas, @XBCreepinJesus & @ZoneMR.
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install.
      Added
      • Added option to config the level of logging.
      • Added prettier for an even cleaner codebase.
      • Hide Sunrise/Sunset in Weather module.
      • Hide Sunrise/Sunset in Current Weather module.
      • Added Met Office DataHub (UK) provider.
      Updated
      • Cleaned up alert module code.
      • Cleaned up check_config code.
      • Replaced grunt-based linters with their non-grunt equivalents.
      • Switch to most of the eslint:recommended rules and fix warnings.
      • Replaced insecure links with https ones.
      • Cleaned up all “no-undef” warnings from eslint.
      • Added location title wrapping for calendar module.
      • Updated the BG translation.
      Deleted
      • Removed truetype (ttf) fonts.
      Fixed
      • The broken modules due to Socket.io change from last release. #1973
      • Add backward compatibility for old module code in socketclient.js. #1973
      • Support multiple instances of calendar module with different config. #1109
      • Fix the use of “maxNumberOfDays” in the module “weatherforecast”. #2018
      • Throw error when check_config fails. #1928
      • Bug fix related to ‘maxEntries’ not displaying Calendar events. #2050
      • Updated ical library to latest version. #1926
      1 Reply Last reply Reply Quote 10
