weatherforecast showing only two days.
31 Posts 22 Posters 9.1k Views 21 Watching
  • E Offline
    erik.voznak
    Hey Guys,
    After latest update of MagicMirror (v2.12.0) module weatherforecast is showing only two day forecast no matter what I configure in “maxNumberOfDays” option.
    Can you please help me? I tried to search for any errors in logs regarding this module or api response, but I wasn`t lucky.
    Below is my config for this module and screenshot to show that it shows only two days.
    module: “weatherforecast”,
    position: “top_right”,
    header: “Predpoveď počasia”,
    lang: “sk”,
    locationID: “3060972”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
    appid: “6ba6364f776c4927bf2145c8582e8c3c”,
    maxNumberOfDays: “7”,
    colored: “true”,
    fade: “false”,
    fadePoint: “1”,
    showRainAmount: “true”,
    scale: “true”,
    alt text
    L 1 Reply Last reply Jul 2, 2020, 10:26 AM Reply Quote 0
    • L Offline
      lavolp3 Module Developer @erik.voznak
      @erik-voznak have you tried
      maxNumberOfDays: 7
      needs to be a number instead of a string.
      fadePoint as well.
      You need to be careful with the format of the values.
      Look into the readme what format is expected.
      https://docs.magicmirror.builders/modules/weatherforecast.html#configuration-options
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      E 1 Reply Last reply Jul 2, 2020, 11:32 AM Reply Quote 0
      • H Offline
        heeroy
        I have the same problem Tryed to change in module config to change numbers of days,tried in weatherforecast.js,always the same Anybody knows how to solve problem?
        • E Offline
          erik.voznak @lavolp3
          @lavolp3
          tried right now and no change.
          maxNumberOfDays: 7,
          colored: “true”,
          fade: “false”,
          fadePoint: 1,
          L 1 Reply Last reply Jul 2, 2020, 11:43 AM Reply Quote -1
          • L Offline
            @erik-voznak @heeroy
            Have you updated?
            Seems to be fixed in latest release from this morning
            https://github.com/MichMich/MagicMirror/issues/2018
            https://forum.magicmirror.builders/topic/13182/v2-12-0
            E 1 Reply Last reply Jul 2, 2020, 11:46 AM Reply Quote 0
            • E Offline
              @lavolp3
              I did update this morning and issue started after update…
              [2020-07-02 13:37:30.638] [LOG] Starting MagicMirror: v2.12.0
              [2020-07-02 13:37:30.651] [LOG] Loading config …
                A Former User
                • O Offline
                  oemel09
                  Had the same issue after the update.
                  The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx)
                  This results in a 401 for me because I’m using a free API token.
                  Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same cnt value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx). Here the value 7 for cnt returns 7 entries, that’s why there is only a two day forecast.
                  I’ll try to write a fix.
                  In the meantime as a quick fix you can change line 297 of weatherforecast.js from:
                  params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
                  to
                  params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
                  Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
                  E T D W H 6 Replies Last reply Jul 3, 2020, 6:47 AM Reply Quote 9
                  • E Offline
                    erik.voznak @oemel09
                    @hango, yeah I know I shouldn`t but I am using free API so… but anyway I will change appid.
                    @oemel09, Many thanks man, your fix helped and finally it is working as intended.
                    alt text
                      castletonroad
                      This fix worked for me too, so thanks very much.
                      Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
                      This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
                      And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
                      Ho-hum…
                      S K 2 Replies Last reply Jul 3, 2020, 11:32 AM Reply Quote 1
                      • 1 / 4
                      1 / 4
