    weatherforecast showing only two days.
    31 Posts 22 Posters 15.6k Views 21 Watching
    • O Offline
      oemel09
      Had the same issue after the update.
      The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx)
      This results in a 401 for me because I’m using a free API token.
      Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same cnt value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx). Here the value 7 for cnt returns 7 entries, that’s why there is only a two day forecast.
      I’ll try to write a fix.
      In the meantime as a quick fix you can change line 297 of weatherforecast.js from:
      params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
      to
      params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
      Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
      E T D W H 6 Replies Last reply Reply Quote 9
      • E Offline
        erik.voznak @oemel09
        @hango, yeah I know I shouldn`t but I am using free API so… but anyway I will change appid.
        @oemel09, Many thanks man, your fix helped and finally it is working as intended.
        alt text
          castletonroad
          This fix worked for me too, so thanks very much.
          Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
          This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
          And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
          Ho-hum…
          S kayakbabeK 2 Replies Last reply Reply Quote 1
            sdetweil @castletonroad
            @castletonroad
            how about no quotes
            showRainAmount: false,
            values that are all numbers, or true and false do not need quotes
            everything else does need quotes
              castletonroad @sdetweil
              @sdetweil Great, that sorted things nicely!
              How ever did I miss that in the config instructions… :astonished_face:
              • T Offline
                tenyo @oemel09
                @oemel09 Thanks a lot!
                  dh1201
                  Thanks for the ‘quick fix’ - Works perfectly.
                    ArthurOff
                    Will this be fixed in the next update or do we need to adjust manually?
                      sdetweil @ArthurOff
                      @ArthurOff next release (3 months), OR you can use the develop branch now til then, 2.12+.
                        ArthurOff @sdetweil
                        @sdetweil haha, got it!
                          DavidCarreira @oemel09
                          @oemel09 Thanks, your fix is working fine!
                          • F Offline
                            FatTony123
                            @oemel09… yep, just can confirm. This fix works like charm ;-)
                            • W Offline
                              Wilfried @oemel09
                              @oemel09 Perfect. Thanks for the workaround.
                              • H Offline
                                Hindenberg @oemel09
                                @oemel09 thx for your support. Different to many others, this fix doesn’t work for me. I’m running MM in a docker container and am not able to keep line 297 of weatherforecast.js edited. It always jumps back into its origin version:
                                I tried in /mounts/modules/default/weatherforecast/ and also inside the container. I also set the container environment: MM_OVERRIDE_CSS: "false", but no way, after restarting the container, it is always showing the “old” values above
                                Any hints?
                                • amarandA Offline
                                  amarand @oemel09
                                  @oemel09
                                  Patch worked for me, thank you!
                                  • karsten13K Offline
                                    karsten13 @Hindenberg
                                    @Hindenberg
                                    If you are using this setup https://gitlab.com/khassel/magicmirror#default-modules you need also set MM_OVERRIDE_DEFAULT_MODULES: "false"
                                    • H Offline
                                      Hindenberg @karsten13
                                      @karsten13 was pretty sure I did this. Works perfect, thanks a lot.
                                      • kayakbabeK Offline
                                        kayakbabe @castletonroad
                                        @castletonroad I have had the same eperience too.
                                        • Z Offline
                                          zxjason
                                            radioman
                                            I have the same Problem
                                            Thanks, your fix is working very good
