    weatherforecast showing only two days.
    31 Posts 22 Posters 16.1k Views 21 Watching
      A Former User
      • O Offline
        oemel09
        Had the same issue after the update.
        The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx)
        This results in a 401 for me because I’m using a free API token.
        Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same cnt value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx). Here the value 7 for cnt returns 7 entries, that’s why there is only a two day forecast.
        I’ll try to write a fix.
        In the meantime as a quick fix you can change line 297 of weatherforecast.js from:
        params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
        to
        params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
        Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
        E T D W H 6 Replies Last reply Reply Quote 9
        • E Offline
          erik.voznak @oemel09
          @hango, yeah I know I shouldn`t but I am using free API so… but anyway I will change appid.
          @oemel09, Many thanks man, your fix helped and finally it is working as intended.
          alt text
            castletonroad
            This fix worked for me too, so thanks very much.
            Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
            This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
            And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
            Ho-hum…
            S kayakbabeK 2 Replies Last reply Reply Quote 1
              sdetweil @castletonroad
              @castletonroad
              how about no quotes
              showRainAmount: false,
              values that are all numbers, or true and false do not need quotes
              everything else does need quotes
                castletonroad @sdetweil
                @sdetweil Great, that sorted things nicely!
                How ever did I miss that in the config instructions… :astonished_face:
                • T Offline
                  tenyo @oemel09
                  @oemel09 Thanks a lot!
                    dh1201
                    Thanks for the ‘quick fix’ - Works perfectly.
                      ArthurOff
                      Will this be fixed in the next update or do we need to adjust manually?
                        sdetweil @ArthurOff
                        @ArthurOff next release (3 months), OR you can use the develop branch now til then, 2.12+.
                          ArthurOff @sdetweil
                          @sdetweil haha, got it!
                            DavidCarreira @oemel09
                            @oemel09 Thanks, your fix is working fine!
                            • F Offline
                              FatTony123
                              @oemel09… yep, just can confirm. This fix works like charm ;-)
                              • W Offline
                                Wilfried @oemel09
                                @oemel09 Perfect. Thanks for the workaround.
                                • H Offline
                                  Hindenberg @oemel09
                                  @oemel09 thx for your support. Different to many others, this fix doesn’t work for me. I’m running MM in a docker container and am not able to keep line 297 of weatherforecast.js edited. It always jumps back into its origin version:
                                  I tried in /mounts/modules/default/weatherforecast/ and also inside the container. I also set the container environment: MM_OVERRIDE_CSS: "false", but no way, after restarting the container, it is always showing the “old” values above
                                  Any hints?
                                  • amarandA Offline
                                    amarand @oemel09
                                    @oemel09
                                    Patch worked for me, thank you!
                                    • karsten13K Offline
                                      karsten13 @Hindenberg
                                      @Hindenberg
                                      If you are using this setup https://gitlab.com/khassel/magicmirror#default-modules you need also set MM_OVERRIDE_DEFAULT_MODULES: "false"
                                      • H Offline
                                        Hindenberg @karsten13
                                        @karsten13 was pretty sure I did this. Works perfect, thanks a lot.
                                        • kayakbabeK Offline
                                          kayakbabe @castletonroad
                                          @castletonroad I have had the same eperience too.
                                          • Z Offline
                                            zxjason
