MMM-GoogleAssistant problem with .asoundrc
@RIKKO14 we are not selling mm, so not commercial use. you are adding a module to your personal system ( unless YOU intend to sell it)
I don’t know about the older module. only that @Bugsounet has done a lot of work to get it going
@RIKKO14 said in MMM-GoogleAssistant problem with .asoundrc:
The MMM-GoogleAssistant of @Bugsounet doen’t work
je ne savais pas que je fesais des module qui ne fonctionnait pas ;)
Merci toutefois de me l’apprendre :)“By terms of Google Assistant SDK, You are not allowed to use or provide this module for commercial purpose.”
cela veux simplement dire qu’il n’est pas permis d’utiliser ce module a des fin commerciale
@Bugsounet TOUTES MES PLATES EXCUSES !!! J’avais donc mal compris, vraiment désolé…
I continue in English because it is required here (and that you will understand that I all pages and tutorials read with google translate …):
But then why in the page of your MMM-GoogleAssistant there is only the link git@github.com: bugsounet / MMM-GoogleAssistant.git and not all the description to install MMM-GoogleAssistant ? -
Great, thank you !
So can you confirm me the card and device for my mic and headphones ? -
It’s depend of you device.
It’s the job of micConfig check at the end of installAttention:
you share some personal data in your config.
You can have some takeover
Don’t forget … it’s a forum ! everyone read this ! -
I tried to edit my 1st post but I can’t: “You are only allowed to edit posts for 3600 second (s) after posting”.
in the case I published which is:
**** Liste des Périphériques Matériels CAPTURE **** carte 1: USB [WordForum USB], périphérique 0: USB Audio [USB Audio] Sous-périphériques: 1/1 Sous-périphérique #0: subdevice #0 pi@raspberrypi:~ $ aplay -l **** Liste des Périphériques Matériels PLAYBACK **** carte 0: b1 [bcm2835 HDMI 1], périphérique 0: bcm2835 HDMI 1 [bcm2835 HDMI 1] Sous-périphériques: 4/4 Sous-périphérique #0: subdevice #0 Sous-périphérique #1: subdevice #1 Sous-périphérique #2: subdevice #2 Sous-périphérique #3: subdevice #3 carte 2: Headphones [bcm2835 Headphones], périphérique 0: bcm2835 Headphones [bcm2835 Headphones] Sous-périphériques: 4/4 Sous-périphérique #0: subdevice #0 Sous-périphérique #1: subdevice #1 Sous-périphérique #2: subdevice #2 Sous-périphérique #3: subdevice #3 pi@raspberrypi:~ $
my mic in on card 1, device 0 because " Liste des Périphériques Matériels CAPTURE", and my 3.5 jack headphone is on card 2, device 0 because " Liste des Périphériques Matériels PLAYBACK" , and in card 0, device 0 it’s HDMI.
is it correct ?
