    MM cant boot, wont boot!
    40 Posts 5 Posters 19.9k Views 5 Watching
      Cyric @sdetweil
      @sdetweil ok, progress. It started magic mirror with a black screen and no mouse. Before it was a black screen with the mouse, and it said electron instead of magic mirror 2. I rebooted and tried to reload my config.js, but it didn’t help.
        sdetweil @Cyric
        @Cyric can u show any errors from pm2 or npm start screen
          Cyric @sdetweil
          @sdetweil main.js:478 Initializing MagicMirror.
          translator.js:202 Loading core translation file: translations/en.json
          translator.js:227 Loading core translation fallback file: translations/en.json
          loader.js:175 Load script: modules/default/alert//alert.js
          :8080/modules/default/alert//alert.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/alert//alert.js
          script.onerror @ loader.js:185
          loader.js:175 Load script: modules/default/updatenotification//updatenotification.js
          :8080/modules/default/updatenotification//updatenotification.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/updatenotification//updatenotification.js
          loader.js:175 Load script: modules/default/clock//clock.js
          :8080/modules/default/clock//clock.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/clock//clock.js
          loader.js:175 Load script: modules/default/calendar//calendar.js
          :8080/modules/default/calendar//calendar.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/calendar//calendar.js
          loader.js:175 Load script: modules/default/compliments//compliments.js
          :8080/modules/default/compliments//compliments.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/compliments//compliments.js
          loader.js:175 Load script: modules/default/currentweather//currentweather.js
          :8080/modules/default/currentweather//currentweather.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/currentweather//currentweather.js
          loader.js:175 Load script: modules/default/weatherforecast//weatherforecast.js
          :8080/modules/default/weatherforecast//weatherforecast.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/weatherforecast//weatherforecast.js
          loader.js:175 Load script: modules/default/newsfeed//newsfeed.js
          :8080/modules/default/newsfeed//newsfeed.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
          loader.js:185 Error on loading script: modules/default/newsfeed//newsfeed.js
          loader.js:194 Load stylesheet: css/custom.css
          main.js:496 All modules started!
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
          protocols.This exposes users of this app to unnecessary security risks.
          Consider loading the following resources over HTTPS or FTPS.
          • http://localhost:8080/css/main.css
          • http://localhost:8080/fonts/roboto.css
          • http://localhost:8080/socket.io/socket.io.js
          • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          • http://localhost:8080/js/defaults.js
          • http://localhost:8080/config/config.js
          • http://localhost:8080/vendor/vendor.js
          • http://localhost:8080/modules/default/defaultmodules.js
          • http://localhost:8080/js/logger.js
          • http://localhost:8080/translations/translations.js
          • http://localhost:8080/js/translator.js
          • http://localhost:8080/js/class.js
          • http://localhost:8080/js/module.js
          • http://localhost:8080/js/loader.js
          • http://localhost:8080/js/socketclient.js
          • http://localhost:8080/js/main.js
          • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          • http://localhost:8080/translations/en.json
          • http://localhost:8080/css/custom.css
          For more information and help, consult
          https://electronjs.org/docs/tutorial/security.
          This warning will not show up
          once the app is packaged.
          warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
          Policy set or a policy with “unsafe-eval” enabled. This exposes users of
          (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
            sdetweil @Cyric
            @Cyric are u running MM OS? or docker?
            those files should be there.
            ls modules/default -laF
            C chrisparkerC 2 Replies Last reply Reply Quote 1
              Cyric @sdetweil
              @sdetweil I’m running rasbian like the tutorial suggests.
              That command gave me: “pi@raspberrypi:~/MagicMirror $ ls modules/default -laF
              total 12
              drwxr-xr-x 2 pi pi 4096 Jul 3 08:21 ./
              drwxr-xr-x 3 pi pi 4096 Jul 3 08:21 …/
              -rw-r–r-- 1 pi pi 512 Jul 3 08:21 defaultmodules.js”
                sdetweil @Cyric
                @Cyric well. why are they. missing?
                I don’t know if this will work
                git checkout modules/default
                if not, you will probably have to git clone and copy the files from the clone
                git clone https://github.com/MichMich/MagicMirror. git mm
                cp -r -p mm/modules/default ~/MagicMirror/modules
                  Cyric @sdetweil
                  @sdetweil I have no idea what happened. I ran the update, restarted, and nothing worked.
                  So, the command git checkout and nothing seemed to happen. I removed the folder and did the git clone of the directory. I tried to do git mm and it said mm is not a git command. I tried to run the last line you gave me, and it said no such file or directory.
                  I really appreciate all your work on this.
                    sdetweil @Cyric
                    @Cyric that git clone was all one long line
                    clone this repo into a folder named mm
                    you removed the folder, that’s where it went further south
                      Cyric
                        Cyric @sdetweil
                        @sdetweil when I out the whole line in, it said fatal too many arguments. I made a new folder called mm and did the git clone of the site.
                        Forgot to run npm install, will do that and post results.
                          Cyric
                          ok, mostly back. My calendar and news feed is still stuck on loading, but everything else is back up. I will post some error logs later after i poke around.
                          Sam, thank you so much for your help. It is really appreciated.
                            Cyric
                            rebooted this morning, reinstalled a module, and everything is back except the weather only shows 2 days. Thank you again for your help Sam.
                            • chrisparkerC Offline
                              chrisparker @sdetweil
                              @sdetweil I’ve going through the same thing. I had a good running copy of MM and I attempted to upgrade to the latest version. It would not boot. I followed this thread as far as discovering that all the modules had been deleted. I used the command to reinstall the default module, then reinstalled my selected modules from the MM Package Manager. Still doesn’t work, it only shows a blank screen with a pointer.
                              Running npm restart gives:
                              > magicmirror@2.12.0 start /home/pi/MagicMirror
                              [2020-07-05 17:36:08.008] [LOG]    Starting MagicMirror: v2.12.0
                              [2020-07-05 17:36:08.021] [LOG]    Loading config ...
                              [2020-07-05 17:36:08.031] [LOG]    Loading module helpers ...
                              [2020-07-05 17:36:08.035] [LOG]    No helper found for module: MMM-Carousel.
                              [2020-07-05 17:36:08.046] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.048] [LOG]    Module helper loaded: MMM-WatchDog
                              [2020-07-05 17:36:08.700] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.701] [LOG]    Module helper loaded: MMM-SystemStats
                              [2020-07-05 17:36:08.819] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.820] [LOG]    Module helper loaded: MMM-PilotWX
                              [2020-07-05 17:36:08.822] [LOG]    No helper found for module: MMM-DigClock.
                              [2020-07-05 17:36:08.828] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'cheerio'
                              Require stack:
                              - /home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js
                              [2020-07-05 17:36:08.830] [LOG]    Loading module helpers ...
                              [2020-07-05 17:36:08.831] [LOG]    No helper found for module: MMM-Carousel.
                              [2020-07-05 17:36:08.833] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.835] [LOG]    Module helper loaded: MMM-WatchDog
                              [2020-07-05 17:36:08.836] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.837] [LOG]    Module helper loaded: MMM-SystemStats
                              [2020-07-05 17:36:08.838] [LOG]    Initializing new module helper ...
                              [2020-07-05 17:36:08.839] [LOG]    Module helper loaded: MMM-PilotWX
                              [2020-07-05 17:36:08.840] [LOG]    No helper found for module: MMM-DigClock.
                              [2020-07-05 17:36:08.843] [ERROR]  App threw an error during load
                              [2020-07-05 17:36:08.845] [ERROR]  Error: Cannot find module 'cheerio'
                              Require stack:
                                  at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                  at Module.require (internal/modules/cjs/loader.js:685:19)
                                  at require (internal/modules/cjs/helpers.js:16:16)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js:3:15)
                                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                  at Module.load (internal/modules/cjs/loader.js:645:32)
                              [2020-07-05 17:36:08.848] [ERROR]  Whoops! There was an uncaught exception...
                              [2020-07-05 17:36:08.849] [ERROR]  Error: Cannot find module 'cheerio'
                              Require stack:
                                  at Module.load (internal/modules/cjs/loader.js:645:32) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js',
                                  '/home/pi/MagicMirror/js/app.js',
                                  '/home/pi/MagicMirror/js/electron.js',
                                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                  undefined
                              [2020-07-05 17:36:08.860] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [2020-07-05 17:36:08.861] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [2020-07-05 17:36:09.030] [LOG]    Launching application.
                              and running npm run config:check gives:
                              > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                              > node js/check_config.js
                              [2020-07-05 17:37:18.657] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                              [2020-07-05 17:37:18.948] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                              /home/pi/MagicMirror/js/check_config.js:66
                              			throw new Error("Wrong syntax in config file!");
                              Error: Wrong syntax in config file!
                                  at /home/pi/MagicMirror/js/check_config.js:66:10
                                  at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                              npm ERR!     /home/pi/.npm/_logs/2020-07-05T15_37_18_992Z-debug.log
                              and that log shows:
                              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
                              2 info using npm@6.14.4
                              3 info using node@v10.20.1
                              4 verbose run-script [ 'preconfig:check', 'config:check', 'postconfig:check' ]
                              5 info lifecycle magicmirror@2.12.0~preconfig:check: magicmirror@2.12.0
                              6 info lifecycle magicmirror@2.12.0~config:check: magicmirror@2.12.0
                              7 verbose lifecycle magicmirror@2.12.0~config:check: unsafe-perm in lifecycle true
                              8 verbose lifecycle magicmirror@2.12.0~config:check: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle$
                              9 verbose lifecycle magicmirror@2.12.0~config:check: CWD: /home/pi/MagicMirror
                              10 silly lifecycle magicmirror@2.12.0~config:check: Args: [ '-c', 'node js/check_config.js' ]
                              11 silly lifecycle magicmirror@2.12.0~config:check: Returned: code: 1  signal: null
                              12 info lifecycle magicmirror@2.12.0~config:check: Failed to exec config:check script
                              13 verbose stack Error: magicmirror@2.12.0 config:check: `node js/check_config.js`
                              13 verbose stack Exit status 1
                              13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js$
                              13 verbose stack     at EventEmitter.emit (events.js:198:13)
                              13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spaw$
                              13 verbose stack     at ChildProcess.emit (events.js:198:13)
                              13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                              14 verbose pkgid magicmirror@2.12.0
                              15 verbose cwd /home/pi/MagicMirror
                              16 verbose Linux 4.19.97-v7+
                              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
                              18 verbose node v10.20.1
                              19 verbose npm  v6.14.4
                              20 error code ELIFECYCLE
                              21 error errno 1
                              22 error magicmirror@2.12.0 config:check: `node js/check_config.js`
                              22 error Exit status 1
                              23 error Failed at the magicmirror@2.12.0 config:check script.
                              23 error This is probably not a problem with npm. There is likely additional logging output above.
                              24 verbose exit [ 1, true ]
                              I’m out of ideas - can anybody help please?
                              TIA,
                              Chris
                                sdetweil @chrisparker
                                @chrisparker somebody is missing one of their dependencies
                                do
                                npm install cheerio
                                then try to start
                                chrisparkerC 1 Reply Last reply Reply Quote 0
                                  sdetweil @Cyric
                                  @Cyric 2 days, I think they pushed a fix for that, do
                                  git checkout develop
                                  git pull
                                  then restart mm
                                    Cyric @sdetweil
                                    @sdetweil So i tried that and it said “error: Your local changes to the following files would be overwritten by checkout:
                                    package-lock.json
                                    Please commit your changes or stash them before you switch branches.
                                    Aborting”
                                    but i havent edited the package-lock.json, so i don’t know why its saying that. Since the problems started when i ran the update, i’m nervous to mess with anything again.
                                      sdetweil @Cyric
                                      @Cyric package-lock. Jason is shipped as part of the project, AND updated every time one does npm install, so it will always present a problem.
                                      just erase it, and then git pull again
                                        Cyric @sdetweil
                                        @sdetweil So i should delete the package-lock.json file, then run
                                        git pull
                                        and then restart mm?
                                          sdetweil @Cyric
                                          @Cyric yes
                                            Cyric
                                            awesome, that worked.
                                            Thank you!
