    MM cant boot, wont boot!
    40 Posts 5 Posters 19.6k Views 5 Watching
      sdetweil @Cyric
      @Cyric ok, where do u start mm? pm2 or nom start manually
      if pm2 do
      pm2 logs --lines=100
      if nom start, the console output is right there.
      let us know what u find
        Cyric @sdetweil
        @sdetweil Here is what it gave me when i tried npm start:
        "magicmirror@2.11.0 start /home/pi/MagicMirror
        [2020-07-02 21:33:26.029] [LOG] Starting MagicMirror: v2.11.0
        [2020-07-02 21:33:26.054] [LOG] Loading config …
        [2020-07-02 21:33:26.071] [LOG] Loading module helpers …
        [2020-07-02 21:33:26.079] [LOG] No helper found for module: alert.
        [2020-07-02 21:33:26.249] [LOG] Initializing new module helper …
        [2020-07-02 21:33:26.251] [LOG] Module helper loaded: updatenotification
        [2020-07-02 21:33:26.253] [LOG] No helper found for module: clock.
        [2020-07-02 21:33:26.279] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘ical’
        Require stack:
        • /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
        • /home/pi/MagicMirror/modules/default/calendar/node_helper.js
        [2020-07-02 21:33:26.282] [LOG] Loading module helpers …
        [2020-07-02 21:33:26.284] [LOG] No helper found for module: alert.
        [2020-07-02 21:33:26.286] [LOG] Initializing new module helper …
        [2020-07-02 21:33:26.287] [LOG] Module helper loaded: updatenotification
        [2020-07-02 21:33:26.289] [LOG] No helper found for module: clock.
        [2020-07-02 21:33:26.300] [ERROR] App threw an error during load
        [2020-07-02 21:33:26.303] [ERROR] Error: Cannot find module ‘ical’
        Require stack:
        • at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Object. (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
          at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          [2020-07-02 21:33:26.308] [ERROR] Whoops! There was an uncaught exception…
          [2020-07-02 21:33:26.310] [ERROR] Error: Cannot find module ‘ical’
          Require stack:
          at Module.load (internal/modules/cjs/loader.js:645:32) {
          code: ‘MODULE_NOT_FOUND’,
          requireStack: [
          ‘/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js’,
          ‘/home/pi/MagicMirror/modules/default/calendar/node_helper.js’,
          ‘/home/pi/MagicMirror/js/app.js’,
          ‘/home/pi/MagicMirror/js/electron.js’,
          ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
          undefined
          [2020-07-02 21:33:26.337] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-07-02 21:33:26.338] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues"
          sdetweil @Cyric
          @Cyric >Cannot find module ‘ical’
          hm…
          the calendar reader module is not found
          can you do
          rm package-lock.json
          rm -rf node_ modules
          npm install
            Cyric
            I ran that, then did npm start again. It told me: "> magicmirror@2.11.0 start /home/pi/MagicMirror
            [2020-07-03 07:35:17.160] [ERROR] App threw an error during load
            [2020-07-03 07:35:17.189] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/js/…/modules/default/defaultmodules.js’
            Require stack:
              at Object. (/home/pi/MagicMirror/js/app.js:12:22)
              at Function.Module._load (internal/modules/cjs/loader.js:560:12)
              A JavaScript error occurred in the main process
              Uncaught Exception:
              Require stack:
              at Function.Module._load (internal/modules/cjs/loader.js:560:12)"
            Now it won’t load the black screen. I have not rebooted yet.
              sdetweil @Cyric
              @Cyric weird
              do
              git checkout modules/default/defaultmodules.js
              then try npm start again
              C 2 Replies Last reply Reply Quote 0
                Cyric @sdetweil
                  Cyric @sdetweil
                  @sdetweil ok, progress. It started magic mirror with a black screen and no mouse. Before it was a black screen with the mouse, and it said electron instead of magic mirror 2. I rebooted and tried to reload my config.js, but it didn’t help.
                    sdetweil @Cyric
                    @Cyric can u show any errors from pm2 or npm start screen
                      Cyric @sdetweil
                      @sdetweil main.js:478 Initializing MagicMirror.
                      translator.js:202 Loading core translation file: translations/en.json
                      translator.js:227 Loading core translation fallback file: translations/en.json
                      loader.js:175 Load script: modules/default/alert//alert.js
                      :8080/modules/default/alert//alert.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/alert//alert.js
                      script.onerror @ loader.js:185
                      loader.js:175 Load script: modules/default/updatenotification//updatenotification.js
                      :8080/modules/default/updatenotification//updatenotification.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/updatenotification//updatenotification.js
                      loader.js:175 Load script: modules/default/clock//clock.js
                      :8080/modules/default/clock//clock.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/clock//clock.js
                      loader.js:175 Load script: modules/default/calendar//calendar.js
                      :8080/modules/default/calendar//calendar.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/calendar//calendar.js
                      loader.js:175 Load script: modules/default/compliments//compliments.js
                      :8080/modules/default/compliments//compliments.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/compliments//compliments.js
                      loader.js:175 Load script: modules/default/currentweather//currentweather.js
                      :8080/modules/default/currentweather//currentweather.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/currentweather//currentweather.js
                      loader.js:175 Load script: modules/default/weatherforecast//weatherforecast.js
                      :8080/modules/default/weatherforecast//weatherforecast.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/weatherforecast//weatherforecast.js
                      loader.js:175 Load script: modules/default/newsfeed//newsfeed.js
                      :8080/modules/default/newsfeed//newsfeed.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                      loader.js:185 Error on loading script: modules/default/newsfeed//newsfeed.js
                      loader.js:194 Load stylesheet: css/custom.css
                      main.js:496 All modules started!
                      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                      protocols.This exposes users of this app to unnecessary security risks.
                      Consider loading the following resources over HTTPS or FTPS.
                      • http://localhost:8080/css/main.css
                      • http://localhost:8080/fonts/roboto.css
                      • http://localhost:8080/socket.io/socket.io.js
                      • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                      • http://localhost:8080/js/defaults.js
                      • http://localhost:8080/config/config.js
                      • http://localhost:8080/vendor/vendor.js
                      • http://localhost:8080/modules/default/defaultmodules.js
                      • http://localhost:8080/js/logger.js
                      • http://localhost:8080/translations/translations.js
                      • http://localhost:8080/js/translator.js
                      • http://localhost:8080/js/class.js
                      • http://localhost:8080/js/module.js
                      • http://localhost:8080/js/loader.js
                      • http://localhost:8080/js/socketclient.js
                      • http://localhost:8080/js/main.js
                      • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                      • http://localhost:8080/translations/en.json
                      • http://localhost:8080/css/custom.css
                      For more information and help, consult
                      https://electronjs.org/docs/tutorial/security.
                      This warning will not show up
                      once the app is packaged.
                      warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
                      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                      Policy set or a policy with “unsafe-eval” enabled. This exposes users of
                      (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
                        sdetweil @Cyric
                        @Cyric are u running MM OS? or docker?
                        those files should be there.
                        ls modules/default -laF
                        C chrisparkerC 2 Replies Last reply Reply Quote 1
                          Cyric @sdetweil
                          @sdetweil I’m running rasbian like the tutorial suggests.
                          That command gave me: “pi@raspberrypi:~/MagicMirror $ ls modules/default -laF
                          total 12
                          drwxr-xr-x 2 pi pi 4096 Jul 3 08:21 ./
                          drwxr-xr-x 3 pi pi 4096 Jul 3 08:21 …/
                          -rw-r–r-- 1 pi pi 512 Jul 3 08:21 defaultmodules.js”
                            sdetweil @Cyric
                            @Cyric well. why are they. missing?
                            I don’t know if this will work
                            if not, you will probably have to git clone and copy the files from the clone
                            git clone https://github.com/MichMich/MagicMirror. git mm
                            cp -r -p mm/modules/default ~/MagicMirror/modules
                              Cyric @sdetweil
                              @sdetweil I have no idea what happened. I ran the update, restarted, and nothing worked.
                              So, the command git checkout and nothing seemed to happen. I removed the folder and did the git clone of the directory. I tried to do git mm and it said mm is not a git command. I tried to run the last line you gave me, and it said no such file or directory.
                              I really appreciate all your work on this.
                                sdetweil @Cyric
                                @Cyric that git clone was all one long line
                                clone this repo into a folder named mm
                                you removed the folder, that’s where it went further south
                                  Cyric
                                    Cyric @sdetweil
                                    @sdetweil when I out the whole line in, it said fatal too many arguments. I made a new folder called mm and did the git clone of the site.
                                    Forgot to run npm install, will do that and post results.
                                      Cyric
                                      ok, mostly back. My calendar and news feed is still stuck on loading, but everything else is back up. I will post some error logs later after i poke around.
                                      Sam, thank you so much for your help. It is really appreciated.
                                        Cyric
                                        rebooted this morning, reinstalled a module, and everything is back except the weather only shows 2 days. Thank you again for your help Sam.
                                        • chrisparkerC Offline
                                          chrisparker @sdetweil
                                          @sdetweil I’ve going through the same thing. I had a good running copy of MM and I attempted to upgrade to the latest version. It would not boot. I followed this thread as far as discovering that all the modules had been deleted. I used the command to reinstall the default module, then reinstalled my selected modules from the MM Package Manager. Still doesn’t work, it only shows a blank screen with a pointer.
                                          Running npm restart gives:
                                          > magicmirror@2.12.0 start /home/pi/MagicMirror
                                          [2020-07-05 17:36:08.008] [LOG]    Starting MagicMirror: v2.12.0
                                          [2020-07-05 17:36:08.021] [LOG]    Loading config ...
                                          [2020-07-05 17:36:08.031] [LOG]    Loading module helpers ...
                                          [2020-07-05 17:36:08.035] [LOG]    No helper found for module: MMM-Carousel.
                                          [2020-07-05 17:36:08.046] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.048] [LOG]    Module helper loaded: MMM-WatchDog
                                          [2020-07-05 17:36:08.700] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.701] [LOG]    Module helper loaded: MMM-SystemStats
                                          [2020-07-05 17:36:08.819] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.820] [LOG]    Module helper loaded: MMM-PilotWX
                                          [2020-07-05 17:36:08.822] [LOG]    No helper found for module: MMM-DigClock.
                                          [2020-07-05 17:36:08.828] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'cheerio'
                                          Require stack:
                                          - /home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js
                                          [2020-07-05 17:36:08.830] [LOG]    Loading module helpers ...
                                          [2020-07-05 17:36:08.831] [LOG]    No helper found for module: MMM-Carousel.
                                          [2020-07-05 17:36:08.833] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.835] [LOG]    Module helper loaded: MMM-WatchDog
                                          [2020-07-05 17:36:08.836] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.837] [LOG]    Module helper loaded: MMM-SystemStats
                                          [2020-07-05 17:36:08.838] [LOG]    Initializing new module helper ...
                                          [2020-07-05 17:36:08.839] [LOG]    Module helper loaded: MMM-PilotWX
                                          [2020-07-05 17:36:08.840] [LOG]    No helper found for module: MMM-DigClock.
                                          [2020-07-05 17:36:08.843] [ERROR]  App threw an error during load
                                          [2020-07-05 17:36:08.845] [ERROR]  Error: Cannot find module 'cheerio'
                                          Require stack:
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js:3:15)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                          [2020-07-05 17:36:08.848] [ERROR]  Whoops! There was an uncaught exception...
                                          [2020-07-05 17:36:08.849] [ERROR]  Error: Cannot find module 'cheerio'
                                          Require stack:
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: [
                                              '/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js',
                                              '/home/pi/MagicMirror/js/app.js',
                                              '/home/pi/MagicMirror/js/electron.js',
                                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                              undefined
                                          [2020-07-05 17:36:08.860] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-07-05 17:36:08.861] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-07-05 17:36:09.030] [LOG]    Launching application.
                                          and running npm run config:check gives:
                                          > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                                          > node js/check_config.js
                                          [2020-07-05 17:37:18.657] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                          [2020-07-05 17:37:18.948] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                                          /home/pi/MagicMirror/js/check_config.js:66
                                          			throw new Error("Wrong syntax in config file!");
                                          Error: Wrong syntax in config file!
                                              at /home/pi/MagicMirror/js/check_config.js:66:10
                                              at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                                          npm ERR!     /home/pi/.npm/_logs/2020-07-05T15_37_18_992Z-debug.log
                                          and that log shows:
                                          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
                                          2 info using npm@6.14.4
                                          3 info using node@v10.20.1
                                          4 verbose run-script [ 'preconfig:check', 'config:check', 'postconfig:check' ]
                                          5 info lifecycle magicmirror@2.12.0~preconfig:check: magicmirror@2.12.0
                                          6 info lifecycle magicmirror@2.12.0~config:check: magicmirror@2.12.0
                                          7 verbose lifecycle magicmirror@2.12.0~config:check: unsafe-perm in lifecycle true
                                          8 verbose lifecycle magicmirror@2.12.0~config:check: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle$
                                          9 verbose lifecycle magicmirror@2.12.0~config:check: CWD: /home/pi/MagicMirror
                                          10 silly lifecycle magicmirror@2.12.0~config:check: Args: [ '-c', 'node js/check_config.js' ]
                                          11 silly lifecycle magicmirror@2.12.0~config:check: Returned: code: 1  signal: null
                                          12 info lifecycle magicmirror@2.12.0~config:check: Failed to exec config:check script
                                          13 verbose stack Error: magicmirror@2.12.0 config:check: `node js/check_config.js`
                                          13 verbose stack Exit status 1
                                          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js$
                                          13 verbose stack     at EventEmitter.emit (events.js:198:13)
                                          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spaw$
                                          13 verbose stack     at ChildProcess.emit (events.js:198:13)
                                          13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                          14 verbose pkgid magicmirror@2.12.0
                                          15 verbose cwd /home/pi/MagicMirror
                                          16 verbose Linux 4.19.97-v7+
                                          17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
                                          18 verbose node v10.20.1
                                          19 verbose npm  v6.14.4
                                          20 error code ELIFECYCLE
                                          21 error errno 1
                                          22 error magicmirror@2.12.0 config:check: `node js/check_config.js`
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.12.0 config:check script.
                                          23 error This is probably not a problem with npm. There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                          I’m out of ideas - can anybody help please?
                                          TIA,
                                          Chris
                                            sdetweil @chrisparker
                                            @chrisparker somebody is missing one of their dependencies
                                            do
                                            npm install cheerio
                                            then try to start
                                            chrisparkerC 1 Reply Last reply Reply Quote 0
