    MM cant boot, wont boot!
    40 Posts 5 Posters 21.1k Views 5 Watching
      Cyric
        Cyric @sdetweil
        @sdetweil when I out the whole line in, it said fatal too many arguments. I made a new folder called mm and did the git clone of the site.
        Forgot to run npm install, will do that and post results.
          Cyric
          ok, mostly back. My calendar and news feed is still stuck on loading, but everything else is back up. I will post some error logs later after i poke around.
          Sam, thank you so much for your help. It is really appreciated.
            Cyric
            rebooted this morning, reinstalled a module, and everything is back except the weather only shows 2 days. Thank you again for your help Sam.
            • chrisparkerC
              chrisparker @sdetweil
              @sdetweil I’ve going through the same thing. I had a good running copy of MM and I attempted to upgrade to the latest version. It would not boot. I followed this thread as far as discovering that all the modules had been deleted. I used the command to reinstall the default module, then reinstalled my selected modules from the MM Package Manager. Still doesn’t work, it only shows a blank screen with a pointer.
              Running npm restart gives:
              > magicmirror@2.12.0 start /home/pi/MagicMirror
              [2020-07-05 17:36:08.008] [LOG]    Starting MagicMirror: v2.12.0
              [2020-07-05 17:36:08.021] [LOG]    Loading config ...
              [2020-07-05 17:36:08.031] [LOG]    Loading module helpers ...
              [2020-07-05 17:36:08.035] [LOG]    No helper found for module: MMM-Carousel.
              [2020-07-05 17:36:08.046] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.048] [LOG]    Module helper loaded: MMM-WatchDog
              [2020-07-05 17:36:08.700] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.701] [LOG]    Module helper loaded: MMM-SystemStats
              [2020-07-05 17:36:08.819] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.820] [LOG]    Module helper loaded: MMM-PilotWX
              [2020-07-05 17:36:08.822] [LOG]    No helper found for module: MMM-DigClock.
              [2020-07-05 17:36:08.828] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'cheerio'
              Require stack:
              - /home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js
              [2020-07-05 17:36:08.830] [LOG]    Loading module helpers ...
              [2020-07-05 17:36:08.831] [LOG]    No helper found for module: MMM-Carousel.
              [2020-07-05 17:36:08.833] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.835] [LOG]    Module helper loaded: MMM-WatchDog
              [2020-07-05 17:36:08.836] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.837] [LOG]    Module helper loaded: MMM-SystemStats
              [2020-07-05 17:36:08.838] [LOG]    Initializing new module helper ...
              [2020-07-05 17:36:08.839] [LOG]    Module helper loaded: MMM-PilotWX
              [2020-07-05 17:36:08.840] [LOG]    No helper found for module: MMM-DigClock.
              [2020-07-05 17:36:08.843] [ERROR]  App threw an error during load
              [2020-07-05 17:36:08.845] [ERROR]  Error: Cannot find module 'cheerio'
              Require stack:
                  at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                  at Module.require (internal/modules/cjs/loader.js:685:19)
                  at require (internal/modules/cjs/helpers.js:16:16)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js:3:15)
                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                  at Module.load (internal/modules/cjs/loader.js:645:32)
              [2020-07-05 17:36:08.848] [ERROR]  Whoops! There was an uncaught exception...
              [2020-07-05 17:36:08.849] [ERROR]  Error: Cannot find module 'cheerio'
              Require stack:
                  at Module.load (internal/modules/cjs/loader.js:645:32) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js',
                  '/home/pi/MagicMirror/js/app.js',
                  '/home/pi/MagicMirror/js/electron.js',
                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  undefined
              [2020-07-05 17:36:08.860] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2020-07-05 17:36:08.861] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [2020-07-05 17:36:09.030] [LOG]    Launching application.
              and running npm run config:check gives:
              > magicmirror@2.12.0 config:check /home/pi/MagicMirror
              > node js/check_config.js
              [2020-07-05 17:37:18.657] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
              [2020-07-05 17:37:18.948] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
              /home/pi/MagicMirror/js/check_config.js:66
              			throw new Error("Wrong syntax in config file!");
              Error: Wrong syntax in config file!
                  at /home/pi/MagicMirror/js/check_config.js:66:10
                  at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.12.0 config:check script.
              npm ERR!     /home/pi/.npm/_logs/2020-07-05T15_37_18_992Z-debug.log
              and that log shows:
              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
              2 info using npm@6.14.4
              3 info using node@v10.20.1
              4 verbose run-script [ 'preconfig:check', 'config:check', 'postconfig:check' ]
              5 info lifecycle magicmirror@2.12.0~preconfig:check: magicmirror@2.12.0
              6 info lifecycle magicmirror@2.12.0~config:check: magicmirror@2.12.0
              7 verbose lifecycle magicmirror@2.12.0~config:check: unsafe-perm in lifecycle true
              8 verbose lifecycle magicmirror@2.12.0~config:check: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle$
              9 verbose lifecycle magicmirror@2.12.0~config:check: CWD: /home/pi/MagicMirror
              10 silly lifecycle magicmirror@2.12.0~config:check: Args: [ '-c', 'node js/check_config.js' ]
              11 silly lifecycle magicmirror@2.12.0~config:check: Returned: code: 1  signal: null
              12 info lifecycle magicmirror@2.12.0~config:check: Failed to exec config:check script
              13 verbose stack Error: magicmirror@2.12.0 config:check: `node js/check_config.js`
              13 verbose stack Exit status 1
              13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js$
              13 verbose stack     at EventEmitter.emit (events.js:198:13)
              13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spaw$
              13 verbose stack     at ChildProcess.emit (events.js:198:13)
              13 verbose stack     at maybeClose (internal/child_process.js:982:16)
              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              14 verbose pkgid magicmirror@2.12.0
              15 verbose cwd /home/pi/MagicMirror
              16 verbose Linux 4.19.97-v7+
              17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
              18 verbose node v10.20.1
              19 verbose npm  v6.14.4
              20 error code ELIFECYCLE
              21 error errno 1
              22 error magicmirror@2.12.0 config:check: `node js/check_config.js`
              22 error Exit status 1
              23 error Failed at the magicmirror@2.12.0 config:check script.
              23 error This is probably not a problem with npm. There is likely additional logging output above.
              24 verbose exit [ 1, true ]
              I’m out of ideas - can anybody help please?
              TIA,
              Chris
                sdetweil @chrisparker
                @chrisparker somebody is missing one of their dependencies
                do
                npm install cheerio
                then try to start
                chrisparkerC 1 Reply Last reply
                  sdetweil @Cyric
                  @Cyric 2 days, I think they pushed a fix for that, do
                  git checkout develop
                  git pull
                  then restart mm
                    Cyric @sdetweil
                    @sdetweil So i tried that and it said “error: Your local changes to the following files would be overwritten by checkout:
                    package-lock.json
                    Please commit your changes or stash them before you switch branches.
                    Aborting”
                    but i havent edited the package-lock.json, so i don’t know why its saying that. Since the problems started when i ran the update, i’m nervous to mess with anything again.
                      sdetweil @Cyric
                      @Cyric package-lock. Jason is shipped as part of the project, AND updated every time one does npm install, so it will always present a problem.
                      just erase it, and then git pull again
                        Cyric @sdetweil
                        @sdetweil So i should delete the package-lock.json file, then run
                        git pull
                        and then restart mm?
                          sdetweil @Cyric
                          @Cyric yes
                            Cyric
                            awesome, that worked.
                            Thank you!
                            • chrisparkerC
                              @sdetweil Thanks. Turned out there were several dependencies missing that are needed by the Dilbert module.
                              I’ve now reloaded my config files and all is well - thanks!
