    MMM-Formula1 - Formula 1 Standings
    30 Posts 10 Posters 24.7k Views 8 Watching
      Peter
      Does anybody see the new 2018 standings after yesterdays races?
      I don’t and I even don’t see the next races in my calendar any more.
      Peter
      F 1 Reply Last reply
      • F
        fabbr @Peter
        @Peter Hey Peter, I just checked and mine is working ok and showing today’s results.
        If yours are still not showing anything, send us your config code of this module and we can try to help you out
        P 1 Reply Last reply
          Peter @fabbr
          Problem solved: localhost 8080 was in use with another module I was experimenting with.
          It works fine now.
          Thanks!
          Peter@fabbr
          I 1 Reply Last reply
          • I
            ianperrin @Peter
            @Peter it’s worth noting that the API isn’t immediately updated following each race so hang in there, the data usually updates by the end of the same day of the race
            “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
              Peter
              I am missing the country flag of Charles Leclerc (Monaco).
              Can somebody give me a hint how to fix this?
              Peter
              • I
                ianperrin @Peter
                @Peter just checking whether you are using the latest version of the module? If not, try updating
                I added a fix last year to support Monegasque as a nationality for Charles Leclerc.
                  Peter @ianperrin
                  @ianperrin Thanks! That solved the problem!
                    RoddyJoff @Mar
                    @Mar Hi, bit of a long shot but did you ever solve this problem?
                    I too can only display one module at a time.
                    Cheers
                      Christiaan99
                      @ianperrin for some reason the calendar is not showing up.
                      I did all the steps from the github page including the localhost:8080 link and a update but is not working.
                      Is it for you still working?
                      EDIT:
                      The command log shows:
                      Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - interval: 3000000
                      Calendar Error, could not fetch calendar: url: http://localhost:8080/MMM-Formula1/schedule.ics…
                      error: invalid url: “http://localhost:8080/MMM-Formula1/schedule.ics”
                      • W
                        Wrangler
                        Module is working great for me, but I like to align the drivers name’s .
                        how do I do that.
                        thanx
