MagicMirror Boot loop...
7 Posts 2 Posters 1.0k Views 2 Watching
  • T Offline
    thymon
    Sorry for my english…
    But my MM reboot again and again.
    ~/MagicMirror/installers $ sh mm.sh
    > magicmirror@2.12.0 start /home/pi/MagicMirror
    /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: |ibffi.so.6: cannot open shared object file: No such file or directory
    npm ERR! code ELIFECYCLE
    npm ERR! syscall spawn
    npm ERR! file sh
    npm ERR! errno ENOENT
    npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.12.0 start script.
    npm ERR!     /home/pi/.npm/_logs/2020-07-15T20_28_46_768Z-debug.log
    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
    2 info using npm@6.14.5
    3 info using node@v10.20.1
    5 info lifecycle magicmirror@2.12.0~prestart: magicmirror@2.12.0
    6 info lifecycle magicmirror@2.12.0~start: magicmirror@2.12.0
    7 verbose lifecycle magicmirror@2.12.0~start: unsafe-perm in lifecycle true
    8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_module$
    9 verbose lifecycle magicmirror@2.12.0~start: CWD: /home/pi/MagicMirror
    10 silly lifecycle magicmirror@2.12.0~start: Args: [ '-c',
    10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
    11 info lifecycle magicmirror@2.12.0~start: Failed to exec start script
    12 verbose stack Error: magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
    12 verbose stack spawn ENOENT
    12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
    12 verbose stack     at ChildProcess.emit (events.js:198:13)
    12 verbose stack     at maybeClose (internal/child_process.js:982:16)
    12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    13 verbose pkgid magicmirror@2.12.0
    14 verbose cwd /home/pi/MagicMirror
    15 verbose Linux 4.19.97-v7+
    16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
    17 verbose node v10.20.1
    18 verbose npm  v6.14.5
    19 error code ELIFECYCLE
    20 error syscall spawn
    21 error file sh
    22 error errno ENOENT
    23 error magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
    23 error spawn ENOENT
    24 error Failed at the magicmirror@2.12.0 start script.
    24 error This is probably not a problem with npm. There is likely additional logging output above.
    25 verbose exit [ 1, true ]
    Thanks a lot in advance
    I have try : npm rebuild / npm install
    S 1 Reply Last reply Jul 15, 2020, 9:16 PM Reply Quote 0
      sdetweil @thymon
      @thymon how long has mm been installed?
      this looks like an SD card corruption
      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: ***|ibffi.so.6***: cannot open shared object file:
      • T Offline
        thymon
        Recently.
        Three months ago.
        S 1 Reply Last reply Jul 15, 2020, 11:39 PM Reply Quote 0
          sdetweil @thymon
          @thymon try this… make a backup of you MM config.js
          sudo apt-get update
          sudo apt-get install libffi-dev
          then try to restart mm
          • T Offline
            thymon
            @sdetweil Hi !
            Thx for your interest.
            sudo apt-get update
            Nothing… same error
            S 1 Reply Last reply Jul 16, 2020, 12:28 AM Reply Quote 0
              sdetweil @thymon
              @thymon yeh, so I would start w a new sd card. never seen one recover
              • T Offline
                thymon
                @sdetweil Ok thx you for this information
