    MMM-PIR-Sensor module not working after module update
    32 Posts 3 Posters 14.8k Views 3 Watching
      JoeFranz
      Hi, the PIR sensor is not working since the last module update. Shortly after starting MM, the monitor goes into standby and stays that way. The sensor then no longer reacts to movement. Only after restarting the Pi do I have a picture again. In the config nothing is entered everything on default. That’s how it worked before. Someone an idea?
        sdetweil @JoeFranz
        @JoeFranz what do you mean by module update?
        i don’t understand what that means… you added a module entry for the PIR module, yes?
          JoeFranz
          Three days ago there was an update for the module MMM-PIR sensor.
          https://github.com/paviro/MMM-PIR-Sensor
          Only the module is in the config.js, no further entries.
          module: ‘MMM-PIR-Sensor’,
          // See ‘Configuration options’ for more information.
            sdetweil @JoeFranz
            @JoeFranz so, you did
            cd ~/MagicMirror/modules/MMM-PIR-Sensor
            git pull
            and then restarted mm, yes?
            there should be some config options u needed to specify. like the gpio pin the sensor is connected to
              @JoeFranz what do the console messages look like at mm startup?
              either the output of npm start, or the output of pm2 logs --lines=20
              J 1 Reply Last reply
                JoeFranz
                MM does not restart, the screen goes into standby shortly after the start and remains so. Despite movement in front of the PIR sensor. MM continues, there is no error. The PIR module has been running without any options in the config for over two years without any problems.
                  sdetweil @JoeFranz
                  @JoeFranz so, mm goes black screen, u call it continues. but it’s broken
                  please post the messages I requested
                    JoeFranz @sdetweil
                    @sdetweil said in MMM-PIR-Sensor module not working after module update:
                    sorry but i don’t know how to do that … :-(
                      sdetweil @JoeFranz
                      @JoeFranz how do u start mm?
                      using pm2 at boot, or some command u enter
                        JoeFranz
                        npm start
                          sdetweil @JoeFranz
                          @JoeFranz ok, so the messages are displayed right there at npm start.
                          minimize mm (alt-spacebar, n) and u can see them, or redirect to a file
                          npm start > somefile
                            JoeFranz
                            magicmirror@2.12.0 start /home/pi/MagicMirror
                            [2020-07-18 16:04:39.810] [LOG] Starting MagicMirror: v2.12.0
                            [2020-07-18 16:04:39.825] [LOG] Loading config …
                            [2020-07-18 16:04:39.835] [LOG] Loading module helpers …
                            [2020-07-18 16:04:39.838] [LOG] No helper found for module: alert.
                            [2020-07-18 16:04:39.981] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:39.982] [LOG] Module helper loaded: MMM-PIR-Sensor
                            [2020-07-18 16:04:40.021] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:40.022] [LOG] Module helper loaded: updatenotification
                            [2020-07-18 16:04:40.023] [LOG] No helper found for module: clock.
                            [2020-07-18 16:04:40.798] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:40.799] [LOG] Module helper loaded: calendar
                            [2020-07-18 16:04:41.497] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:41.498] [LOG] Module helper loaded: MMM-Tado
                            [2020-07-18 16:04:42.098] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.099] [LOG] Module helper loaded: MMM-DarkSkyForecast
                            [2020-07-18 16:04:42.164] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.165] [LOG] Module helper loaded: newsfeed
                            [2020-07-18 16:04:42.629] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.679] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                            [2020-07-18 16:04:42.778] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.779] [LOG] Module helper loaded: MMM-soccer
                            [2020-07-18 16:04:42.801] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.802] [LOG] Module helper loaded: MMM-Tools
                            [2020-07-18 16:04:42.805] [LOG] Initializing new module helper …
                            [2020-07-18 16:04:42.806] [LOG] Module helper loaded: mmm-hue-lights
                            [2020-07-18 16:04:42.806] [LOG] All module helpers loaded.
                            [2020-07-18 16:04:43.026] [LOG] Starting server on port 8080 …
                            [2020-07-18 16:04:43.050] [LOG] Server started …
                            [2020-07-18 16:04:43.051] [LOG] Connecting socket for: MMM-PIR-Sensor
                            [2020-07-18 16:04:43.053] [LOG] Connecting socket for: updatenotification
                            [2020-07-18 16:04:43.054] [LOG] Connecting socket for: calendar
                            [2020-07-18 16:04:43.061] [LOG] Starting node helper for: calendar
                            [2020-07-18 16:04:43.062] [LOG] Connecting socket for: MMM-Tado
                            [2020-07-18 16:04:43.063] [LOG] Connecting socket for: MMM-DarkSkyForecast
                            [2020-07-18 16:04:43.064] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                            [2020-07-18 16:04:43.065] [LOG] Connecting socket for: newsfeed
                            [2020-07-18 16:04:43.066] [LOG] Starting node helper for: newsfeed
                            [2020-07-18 16:04:43.066] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                            [2020-07-18 16:04:43.067] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                            [2020-07-18 16:04:43.068] [LOG] Connecting socket for: MMM-soccer
                            [2020-07-18 16:04:43.068] [LOG] Starting module: MMM-soccer
                            [2020-07-18 16:04:43.069] [LOG] Connecting socket for: MMM-Tools
                            [2020-07-18 16:04:43.072] [LOG] Connecting socket for: mmm-hue-lights
                            [2020-07-18 16:04:43.073] [LOG] Starting node_helper for module [mmm-hue-lights]
                            [2020-07-18 16:04:43.074] [LOG] Sockets connected & modules started …
                            [2020-07-18 16:04:43.301] [LOG] Launching application.
                            [2020-07-18 16:04:46.964] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                            [2020-07-18 16:04:47.058] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:47.060] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:47.066] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                            [2020-07-18 16:04:47.138] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                            [2020-07-18 16:04:47.142] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                            [2020-07-18 16:04:47.152] [LOG] [COVID:CORE] Scan starts.
                            [2020-07-18 16:04:47.647] [INFO] Checking git for module: MMM-PIR-Sensor
                            [2020-07-18 16:04:47.680] [INFO] Checking git for module: MMM-Tado
                            [2020-07-18 16:04:47.707] [INFO] Checking git for module: MMM-DarkSkyForecast
                            [2020-07-18 16:04:47.732] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                            [2020-07-18 16:04:47.755] [INFO] Checking git for module: MMM-soccer
                            [2020-07-18 16:04:47.779] [INFO] Checking git for module: MMM-Tools
                            [2020-07-18 16:04:47.803] [INFO] Checking git for module: mmm-hue-lights
                            [2020-07-18 16:04:48.279] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:48.280] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:48.877] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                            [2020-07-18 16:04:51.061] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                            [2020-07-18 16:04:51.067] [LOG] Requests available: 9
                            [2020-07-18 16:04:51.088] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:51.089] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:51.618] [LOG] - MMM-Tado: Logged in
                            [2020-07-18 16:04:53.448] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                            [2020-07-18 16:04:53.476] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:53.477] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:53.545] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                            [2020-07-18 16:04:53.949] [INFO] Newsfeed-Fetcher: Broadcasting 29 items.
                            [2020-07-18 16:04:54.339] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                            [2020-07-18 16:04:54.359] [LOG] - MMM-Tado: Got me()
                            [2020-07-18 16:04:54.360] [LOG] - MMM-Tado: Got homes()
                            [2020-07-18 16:04:54.458] [LOG] [COVID:CORE] Access to data source.
                            [2020-07-18 16:04:54.940] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:54.941] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:55.286] [LOG] - MMM-Tado: Got zones()
                            [2020-07-18 16:04:55.324] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                            [2020-07-18 16:04:56.023] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:56.024] [LOG] - MMM-Tado: Not all data present
                            [2020-07-18 16:04:56.039] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                            [2020-07-18 16:04:56.475] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                            [2020-07-18 16:04:56.523] [LOG] can’t find property recovered Canada:
                            [2020-07-18 16:04:56.524] [LOG] adding…
                            [2020-07-18 16:04:56.755] [LOG] [COVID:CORE] Calculating Wordlwide total.
                            [2020-07-18 16:04:56.965] [LOG] [COVID:CORE] Scan Completed.
                            [2020-07-18 16:04:57.528] [LOG] - MMM-Tado: Checking if all data is present
                            [2020-07-18 16:04:57.529] [LOG] - MMM-TADO: All data is present
                            [2020-07-18 16:04:58.109] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                            [2020-07-18 16:06:03.699] [LOG] Shutting down server…
                            [2020-07-18 16:06:03.705] [LOG] Stopping module helper: MMM-PIR-Sensor
                            [2020-07-18 16:06:03.707] [LOG] Stopping module helper: updatenotification
                            [2020-07-18 16:06:03.708] [LOG] Stopping module helper: calendar
                            [2020-07-18 16:06:03.709] [LOG] Stopping module helper: MMM-Tado
                            [2020-07-18 16:06:03.710] [LOG] Stopping module helper: MMM-DarkSkyForecast
                            [2020-07-18 16:06:03.711] [LOG] Stopping module helper: newsfeed
                            [2020-07-18 16:06:03.712] [LOG] Stopping module helper: MMM-COVID19-SPARKLINE
                            [2020-07-18 16:06:03.713] [LOG] Stopping module helper: MMM-soccer
                            [2020-07-18 16:06:03.714] [LOG] Stopping module helper: MMM-Tools
                            [2020-07-18 16:06:03.715] [LOG] Stopping module helper: mmm-hue-lights
                              sdetweil @JoeFranz
                              @JoeFranz ok, nothing obvious there, so, now we need to open the developers window, ctrl-shift-i and select the console tab and scroll up to see any errors, usually red text
                                JoeFranz
                                  JoeFranz @sdetweil
                                  S mumblebajM 2 Replies Last reply
                                    sdetweil @JoeFranz
                                    @JoeFranz looks likes is mmm-soccer w the problem
                                      JoeFranz
                                      Without MMM-soccer same error :-(
                                      • mumblebajM
                                        mumblebaj Module Developer @JoeFranz
                                        @JoeFranz Looks more like an issue with the MMM-Formula1. It is the first thing throwing an error. Can you write the npm to file and post the contents of the log file?
                                        npm start > log.txt 2>&1
                                          sdetweil @mumblebaj
                                          @mumblebaj there were no errors in the npm start log info.
                                          the calendar error is not fatal.
                                          the soccer error is fatal, as it’s in the web drawing loop.
                                          @JoeFranz u can’t have the ‘same’ error if u disabled the soccer module
                                            JoeFranz
                                            The Formula1 module is not active and i have nothing change in the config.js since MMM-PIR-Sensor update.
                                            /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
                                            [2020-07-18 18:21:54.455] [LOG] Starting MagicMirror: v2.12.0
                                            [2020-07-18 18:21:54.466] [LOG] Loading config …
                                            [2020-07-18 18:21:54.476] [LOG] Loading module helpers …
                                            [2020-07-18 18:21:54.479] [LOG] No helper found for module: alert.
                                            [2020-07-18 18:21:54.541] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:54.542] [LOG] Module helper loaded: updatenotification
                                            [2020-07-18 18:21:54.543] [LOG] No helper found for module: clock.
                                            [2020-07-18 18:21:55.313] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:55.314] [LOG] Module helper loaded: calendar
                                            [2020-07-18 18:21:55.992] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:55.993] [LOG] Module helper loaded: MMM-Tado
                                            [2020-07-18 18:21:56.585] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:56.586] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                            [2020-07-18 18:21:56.629] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:56.630] [LOG] Module helper loaded: newsfeed
                                            [2020-07-18 18:21:57.071] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:57.073] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                                            [2020-07-18 18:21:57.094] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:57.095] [LOG] Module helper loaded: MMM-Tools
                                            [2020-07-18 18:21:57.098] [LOG] Initializing new module helper …
                                            [2020-07-18 18:21:57.099] [LOG] Module helper loaded: mmm-hue-lights
                                            [2020-07-18 18:21:57.099] [LOG] All module helpers loaded.
                                            [2020-07-18 18:21:57.302] [LOG] Starting server on port 8080 …
                                            [2020-07-18 18:21:57.324] [LOG] Server started …
                                            [2020-07-18 18:21:57.325] [LOG] Connecting socket for: updatenotification
                                            [2020-07-18 18:21:57.327] [LOG] Connecting socket for: calendar
                                            [2020-07-18 18:21:57.328] [LOG] Starting node helper for: calendar
                                            [2020-07-18 18:21:57.328] [LOG] Connecting socket for: MMM-Tado
                                            [2020-07-18 18:21:57.329] [LOG] Connecting socket for: MMM-DarkSkyForecast
                                            [2020-07-18 18:21:57.330] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                            [2020-07-18 18:21:57.331] [LOG] Connecting socket for: newsfeed
                                            [2020-07-18 18:21:57.332] [LOG] Starting node helper for: newsfeed
                                            [2020-07-18 18:21:57.333] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                                            [2020-07-18 18:21:57.333] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                                            [2020-07-18 18:21:57.334] [LOG] Connecting socket for: MMM-Tools
                                            [2020-07-18 18:21:57.337] [LOG] Connecting socket for: mmm-hue-lights
                                            [2020-07-18 18:21:57.338] [LOG] Starting node_helper for module [mmm-hue-lights]
                                            [2020-07-18 18:21:57.339] [LOG] Sockets connected & modules started …
                                            Fontconfig warning: “/etc/fonts/fonts.conf”, line 86: unknown element “blank”
                                            /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)
                                            [2020-07-18 18:21:57.496] [LOG] Launching application.
                                            libGL error: MESA-LOADER: failed to retrieve device information
                                            ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                            [2020-07-18 18:22:01.271] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                                            [2020-07-18 18:22:01.296] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                                            [2020-07-18 18:22:01.301] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                                            [2020-07-18 18:22:01.314] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                                            [2020-07-18 18:22:01.328] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                                            [2020-07-18 18:22:01.476] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/MMM-Formula1/schedule.ics 404: Not Found
                                            [2020-07-18 18:22:01.533] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:01.535] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:01.578] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                                            [2020-07-18 18:22:01.650] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                                            [2020-07-18 18:22:01.662] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                                            [2020-07-18 18:22:01.678] [LOG] [COVID:CORE] Scan starts.
                                            [2020-07-18 18:22:03.860] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                                            [2020-07-18 18:22:03.879] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:03.880] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:04.777] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                                            [2020-07-18 18:22:04.884] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:04.885] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:05.180] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                                            [2020-07-18 18:22:05.268] [INFO] Checking git for module: MMM-Tado
                                            [2020-07-18 18:22:05.305] [INFO] Checking git for module: MMM-DarkSkyForecast
                                            [2020-07-18 18:22:05.342] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                                            [2020-07-18 18:22:05.374] [INFO] Checking git for module: MMM-Tools
                                            [2020-07-18 18:22:05.413] [INFO] Checking git for module: mmm-hue-lights
                                            [2020-07-18 18:22:05.519] [LOG] - MMM-Tado: Logged in
                                            [2020-07-18 18:22:06.068] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
                                            [2020-07-18 18:22:06.193] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                                            [2020-07-18 18:22:06.303] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:06.305] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:07.917] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                                            [2020-07-18 18:22:07.924] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:07.926] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:08.117] [LOG] [COVID:CORE] Access to data source.
                                            [2020-07-18 18:22:08.516] [LOG] - MMM-Tado: Got me()
                                            [2020-07-18 18:22:08.518] [LOG] - MMM-Tado: Got homes()
                                            [2020-07-18 18:22:08.756] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                                            [2020-07-18 18:22:09.204] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:09.213] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:09.384] [LOG] - MMM-Tado: Got zones()
                                            [2020-07-18 18:22:09.429] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                                            [2020-07-18 18:22:09.876] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                                            [2020-07-18 18:22:09.932] [LOG] can’t find property recovered Canada:
                                            [2020-07-18 18:22:09.933] [LOG] adding…
                                            [2020-07-18 18:22:10.185] [LOG] [COVID:CORE] Calculating Wordlwide total.
                                            [2020-07-18 18:22:10.398] [LOG] [COVID:CORE] Scan Completed.
                                            [2020-07-18 18:22:11.152] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:11.157] [LOG] - MMM-Tado: Not all data present
                                            [2020-07-18 18:22:11.654] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                                            [2020-07-18 18:22:12.193] [LOG] - MMM-Tado: Checking if all data is present
                                            [2020-07-18 18:22:12.194] [LOG] - MMM-TADO: All data is present
                                            [2020-07-18 18:22:37.119] [LOG] Shutting down server…
                                            [2020-07-18 18:22:37.157] [LOG] Stopping module helper: updatenotification
                                            [2020-07-18 18:22:37.159] [LOG] Stopping module helper: calendar
                                            [2020-07-18 18:22:37.161] [LOG] Stopping module helper: MMM-Tado
                                            [2020-07-18 18:22:37.169] [LOG] Stopping module helper: MMM-DarkSkyForecast
                                            [2020-07-18 18:22:37.171] [LOG] Stopping module helper: newsfeed
                                            [2020-07-18 18:22:37.174] [LOG] Stopping module helper: MMM-COVID19-SPARKLINE
                                            [2020-07-18 18:22:37.178] [LOG] Stopping module helper: MMM-Tools
                                            [2020-07-18 18:22:37.180] [LOG] Stopping module helper: mmm-hue-lights
                                            mumblebajM S 2 Replies Last reply
