    MMM-PIR-Sensor module not working after module update
    32 Posts 3 Posters 14.8k Views 3 Watching
      @JoeFranz what do the console messages look like at mm startup?
      either the output of npm start, or the output of pm2 logs --lines=20
      J 1 Reply Last reply
        JoeFranz
        MM does not restart, the screen goes into standby shortly after the start and remains so. Despite movement in front of the PIR sensor. MM continues, there is no error. The PIR module has been running without any options in the config for over two years without any problems.
          sdetweil @JoeFranz
          @JoeFranz so, mm goes black screen, u call it continues. but it’s broken
          please post the messages I requested
            JoeFranz @sdetweil
            @sdetweil said in MMM-PIR-Sensor module not working after module update:
            sorry but i don’t know how to do that … :-(
              sdetweil @JoeFranz
              @JoeFranz how do u start mm?
              using pm2 at boot, or some command u enter
                JoeFranz
                npm start
                  sdetweil @JoeFranz
                  @JoeFranz ok, so the messages are displayed right there at npm start.
                  minimize mm (alt-spacebar, n) and u can see them, or redirect to a file
                  npm start > somefile
                    JoeFranz
                    magicmirror@2.12.0 start /home/pi/MagicMirror
                    [2020-07-18 16:04:39.810] [LOG] Starting MagicMirror: v2.12.0
                    [2020-07-18 16:04:39.825] [LOG] Loading config …
                    [2020-07-18 16:04:39.835] [LOG] Loading module helpers …
                    [2020-07-18 16:04:39.838] [LOG] No helper found for module: alert.
                    [2020-07-18 16:04:39.981] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:39.982] [LOG] Module helper loaded: MMM-PIR-Sensor
                    [2020-07-18 16:04:40.021] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:40.022] [LOG] Module helper loaded: updatenotification
                    [2020-07-18 16:04:40.023] [LOG] No helper found for module: clock.
                    [2020-07-18 16:04:40.798] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:40.799] [LOG] Module helper loaded: calendar
                    [2020-07-18 16:04:41.497] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:41.498] [LOG] Module helper loaded: MMM-Tado
                    [2020-07-18 16:04:42.098] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.099] [LOG] Module helper loaded: MMM-DarkSkyForecast
                    [2020-07-18 16:04:42.164] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.165] [LOG] Module helper loaded: newsfeed
                    [2020-07-18 16:04:42.629] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.679] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                    [2020-07-18 16:04:42.778] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.779] [LOG] Module helper loaded: MMM-soccer
                    [2020-07-18 16:04:42.801] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.802] [LOG] Module helper loaded: MMM-Tools
                    [2020-07-18 16:04:42.805] [LOG] Initializing new module helper …
                    [2020-07-18 16:04:42.806] [LOG] Module helper loaded: mmm-hue-lights
                    [2020-07-18 16:04:42.806] [LOG] All module helpers loaded.
                    [2020-07-18 16:04:43.026] [LOG] Starting server on port 8080 …
                    [2020-07-18 16:04:43.050] [LOG] Server started …
                    [2020-07-18 16:04:43.051] [LOG] Connecting socket for: MMM-PIR-Sensor
                    [2020-07-18 16:04:43.053] [LOG] Connecting socket for: updatenotification
                    [2020-07-18 16:04:43.054] [LOG] Connecting socket for: calendar
                    [2020-07-18 16:04:43.061] [LOG] Starting node helper for: calendar
                    [2020-07-18 16:04:43.062] [LOG] Connecting socket for: MMM-Tado
                    [2020-07-18 16:04:43.063] [LOG] Connecting socket for: MMM-DarkSkyForecast
                    [2020-07-18 16:04:43.064] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                    [2020-07-18 16:04:43.065] [LOG] Connecting socket for: newsfeed
                    [2020-07-18 16:04:43.066] [LOG] Starting node helper for: newsfeed
                    [2020-07-18 16:04:43.066] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                    [2020-07-18 16:04:43.067] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                    [2020-07-18 16:04:43.068] [LOG] Connecting socket for: MMM-soccer
                    [2020-07-18 16:04:43.068] [LOG] Starting module: MMM-soccer
                    [2020-07-18 16:04:43.069] [LOG] Connecting socket for: MMM-Tools
                    [2020-07-18 16:04:43.072] [LOG] Connecting socket for: mmm-hue-lights
                    [2020-07-18 16:04:43.073] [LOG] Starting node_helper for module [mmm-hue-lights]
                    [2020-07-18 16:04:43.074] [LOG] Sockets connected & modules started …
                    [2020-07-18 16:04:43.301] [LOG] Launching application.
                    [2020-07-18 16:04:46.964] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                    [2020-07-18 16:04:47.058] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:47.060] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:47.066] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                    [2020-07-18 16:04:47.138] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                    [2020-07-18 16:04:47.142] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                    [2020-07-18 16:04:47.152] [LOG] [COVID:CORE] Scan starts.
                    [2020-07-18 16:04:47.647] [INFO] Checking git for module: MMM-PIR-Sensor
                    [2020-07-18 16:04:47.680] [INFO] Checking git for module: MMM-Tado
                    [2020-07-18 16:04:47.707] [INFO] Checking git for module: MMM-DarkSkyForecast
                    [2020-07-18 16:04:47.732] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                    [2020-07-18 16:04:47.755] [INFO] Checking git for module: MMM-soccer
                    [2020-07-18 16:04:47.779] [INFO] Checking git for module: MMM-Tools
                    [2020-07-18 16:04:47.803] [INFO] Checking git for module: mmm-hue-lights
                    [2020-07-18 16:04:48.279] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:48.280] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:48.877] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                    [2020-07-18 16:04:51.061] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                    [2020-07-18 16:04:51.067] [LOG] Requests available: 9
                    [2020-07-18 16:04:51.088] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:51.089] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:51.618] [LOG] - MMM-Tado: Logged in
                    [2020-07-18 16:04:53.448] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                    [2020-07-18 16:04:53.476] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:53.477] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:53.545] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                    [2020-07-18 16:04:53.949] [INFO] Newsfeed-Fetcher: Broadcasting 29 items.
                    [2020-07-18 16:04:54.339] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                    [2020-07-18 16:04:54.359] [LOG] - MMM-Tado: Got me()
                    [2020-07-18 16:04:54.360] [LOG] - MMM-Tado: Got homes()
                    [2020-07-18 16:04:54.458] [LOG] [COVID:CORE] Access to data source.
                    [2020-07-18 16:04:54.940] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:54.941] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:55.286] [LOG] - MMM-Tado: Got zones()
                    [2020-07-18 16:04:55.324] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                    [2020-07-18 16:04:56.023] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:56.024] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 16:04:56.039] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                    [2020-07-18 16:04:56.475] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                    [2020-07-18 16:04:56.523] [LOG] can’t find property recovered Canada:
                    [2020-07-18 16:04:56.524] [LOG] adding…
                    [2020-07-18 16:04:56.755] [LOG] [COVID:CORE] Calculating Wordlwide total.
                    [2020-07-18 16:04:56.965] [LOG] [COVID:CORE] Scan Completed.
                    [2020-07-18 16:04:57.528] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 16:04:57.529] [LOG] - MMM-TADO: All data is present
                    [2020-07-18 16:04:58.109] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                    [2020-07-18 16:06:03.699] [LOG] Shutting down server…
                    [2020-07-18 16:06:03.705] [LOG] Stopping module helper: MMM-PIR-Sensor
                    [2020-07-18 16:06:03.707] [LOG] Stopping module helper: updatenotification
                    [2020-07-18 16:06:03.708] [LOG] Stopping module helper: calendar
                    [2020-07-18 16:06:03.709] [LOG] Stopping module helper: MMM-Tado
                    [2020-07-18 16:06:03.710] [LOG] Stopping module helper: MMM-DarkSkyForecast
                    [2020-07-18 16:06:03.711] [LOG] Stopping module helper: newsfeed
                    [2020-07-18 16:06:03.712] [LOG] Stopping module helper: MMM-COVID19-SPARKLINE
                    [2020-07-18 16:06:03.713] [LOG] Stopping module helper: MMM-soccer
                    [2020-07-18 16:06:03.714] [LOG] Stopping module helper: MMM-Tools
                    [2020-07-18 16:06:03.715] [LOG] Stopping module helper: mmm-hue-lights
                      sdetweil @JoeFranz
                      @JoeFranz ok, nothing obvious there, so, now we need to open the developers window, ctrl-shift-i and select the console tab and scroll up to see any errors, usually red text
                        JoeFranz
                          JoeFranz @sdetweil
                          S mumblebajM 2 Replies Last reply
                            sdetweil @JoeFranz
                            @JoeFranz looks likes is mmm-soccer w the problem
                              JoeFranz
                              Without MMM-soccer same error :-(
                              • mumblebajM
                                mumblebaj Module Developer @JoeFranz
                                @JoeFranz Looks more like an issue with the MMM-Formula1. It is the first thing throwing an error. Can you write the npm to file and post the contents of the log file?
                                npm start > log.txt 2>&1
                                  sdetweil @mumblebaj
                                  @mumblebaj there were no errors in the npm start log info.
                                  the calendar error is not fatal.
                                  the soccer error is fatal, as it’s in the web drawing loop.
                                  @JoeFranz u can’t have the ‘same’ error if u disabled the soccer module
                                    JoeFranz
                                    The Formula1 module is not active and i have nothing change in the config.js since MMM-PIR-Sensor update.
                                    /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
                                    [2020-07-18 18:21:54.455] [LOG] Starting MagicMirror: v2.12.0
                                    [2020-07-18 18:21:54.466] [LOG] Loading config …
                                    [2020-07-18 18:21:54.476] [LOG] Loading module helpers …
                                    [2020-07-18 18:21:54.479] [LOG] No helper found for module: alert.
                                    [2020-07-18 18:21:54.541] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:54.542] [LOG] Module helper loaded: updatenotification
                                    [2020-07-18 18:21:54.543] [LOG] No helper found for module: clock.
                                    [2020-07-18 18:21:55.313] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:55.314] [LOG] Module helper loaded: calendar
                                    [2020-07-18 18:21:55.992] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:55.993] [LOG] Module helper loaded: MMM-Tado
                                    [2020-07-18 18:21:56.585] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:56.586] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                    [2020-07-18 18:21:56.629] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:56.630] [LOG] Module helper loaded: newsfeed
                                    [2020-07-18 18:21:57.071] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:57.073] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                                    [2020-07-18 18:21:57.094] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:57.095] [LOG] Module helper loaded: MMM-Tools
                                    [2020-07-18 18:21:57.098] [LOG] Initializing new module helper …
                                    [2020-07-18 18:21:57.099] [LOG] Module helper loaded: mmm-hue-lights
                                    [2020-07-18 18:21:57.099] [LOG] All module helpers loaded.
                                    [2020-07-18 18:21:57.302] [LOG] Starting server on port 8080 …
                                    [2020-07-18 18:21:57.324] [LOG] Server started …
                                    [2020-07-18 18:21:57.325] [LOG] Connecting socket for: updatenotification
                                    [2020-07-18 18:21:57.327] [LOG] Connecting socket for: calendar
                                    [2020-07-18 18:21:57.328] [LOG] Starting node helper for: calendar
                                    [2020-07-18 18:21:57.328] [LOG] Connecting socket for: MMM-Tado
                                    [2020-07-18 18:21:57.329] [LOG] Connecting socket for: MMM-DarkSkyForecast
                                    [2020-07-18 18:21:57.330] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                    [2020-07-18 18:21:57.331] [LOG] Connecting socket for: newsfeed
                                    [2020-07-18 18:21:57.332] [LOG] Starting node helper for: newsfeed
                                    [2020-07-18 18:21:57.333] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                                    [2020-07-18 18:21:57.333] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                                    [2020-07-18 18:21:57.334] [LOG] Connecting socket for: MMM-Tools
                                    [2020-07-18 18:21:57.337] [LOG] Connecting socket for: mmm-hue-lights
                                    [2020-07-18 18:21:57.338] [LOG] Starting node_helper for module [mmm-hue-lights]
                                    [2020-07-18 18:21:57.339] [LOG] Sockets connected & modules started …
                                    Fontconfig warning: “/etc/fonts/fonts.conf”, line 86: unknown element “blank”
                                    /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)
                                    [2020-07-18 18:21:57.496] [LOG] Launching application.
                                    libGL error: MESA-LOADER: failed to retrieve device information
                                    ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                    [2020-07-18 18:22:01.271] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                                    [2020-07-18 18:22:01.296] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                                    [2020-07-18 18:22:01.301] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                                    [2020-07-18 18:22:01.314] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                                    [2020-07-18 18:22:01.328] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                                    [2020-07-18 18:22:01.476] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/MMM-Formula1/schedule.ics 404: Not Found
                                    [2020-07-18 18:22:01.533] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:01.535] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:01.578] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                                    [2020-07-18 18:22:01.650] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                                    [2020-07-18 18:22:01.662] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                                    [2020-07-18 18:22:01.678] [LOG] [COVID:CORE] Scan starts.
                                    [2020-07-18 18:22:03.860] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                                    [2020-07-18 18:22:03.879] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:03.880] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:04.777] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                                    [2020-07-18 18:22:04.884] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:04.885] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:05.180] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                                    [2020-07-18 18:22:05.268] [INFO] Checking git for module: MMM-Tado
                                    [2020-07-18 18:22:05.305] [INFO] Checking git for module: MMM-DarkSkyForecast
                                    [2020-07-18 18:22:05.342] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                                    [2020-07-18 18:22:05.374] [INFO] Checking git for module: MMM-Tools
                                    [2020-07-18 18:22:05.413] [INFO] Checking git for module: mmm-hue-lights
                                    [2020-07-18 18:22:05.519] [LOG] - MMM-Tado: Logged in
                                    [2020-07-18 18:22:06.068] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
                                    [2020-07-18 18:22:06.193] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                                    [2020-07-18 18:22:06.303] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:06.305] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:07.917] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                                    [2020-07-18 18:22:07.924] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:07.926] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:08.117] [LOG] [COVID:CORE] Access to data source.
                                    [2020-07-18 18:22:08.516] [LOG] - MMM-Tado: Got me()
                                    [2020-07-18 18:22:08.518] [LOG] - MMM-Tado: Got homes()
                                    [2020-07-18 18:22:08.756] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                                    [2020-07-18 18:22:09.204] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:09.213] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:09.384] [LOG] - MMM-Tado: Got zones()
                                    [2020-07-18 18:22:09.429] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                                    [2020-07-18 18:22:09.876] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                                    [2020-07-18 18:22:09.932] [LOG] can’t find property recovered Canada:
                                    [2020-07-18 18:22:09.933] [LOG] adding…
                                    [2020-07-18 18:22:10.185] [LOG] [COVID:CORE] Calculating Wordlwide total.
                                    [2020-07-18 18:22:10.398] [LOG] [COVID:CORE] Scan Completed.
                                    [2020-07-18 18:22:11.152] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:11.157] [LOG] - MMM-Tado: Not all data present
                                    [2020-07-18 18:22:11.654] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                                    [2020-07-18 18:22:12.193] [LOG] - MMM-Tado: Checking if all data is present
                                    [2020-07-18 18:22:12.194] [LOG] - MMM-TADO: All data is present
                                    [2020-07-18 18:22:37.119] [LOG] Shutting down server…
                                    [2020-07-18 18:22:37.157] [LOG] Stopping module helper: updatenotification
                                    [2020-07-18 18:22:37.159] [LOG] Stopping module helper: calendar
                                    [2020-07-18 18:22:37.161] [LOG] Stopping module helper: MMM-Tado
                                    [2020-07-18 18:22:37.169] [LOG] Stopping module helper: MMM-DarkSkyForecast
                                    [2020-07-18 18:22:37.171] [LOG] Stopping module helper: newsfeed
                                    [2020-07-18 18:22:37.174] [LOG] Stopping module helper: MMM-COVID19-SPARKLINE
                                    [2020-07-18 18:22:37.178] [LOG] Stopping module helper: MMM-Tools
                                    [2020-07-18 18:22:37.180] [LOG] Stopping module helper: mmm-hue-lights
                                    mumblebajM S 2 Replies Last reply
                                    • mumblebajM
                                      @JoeFranz How long have you been using the MMM-COVID19-SPARKLINE? When I installed it the other night it caused issues for me. My NPM did not log any issues but the calculations from the module took too long and caused other modules to freeze up.
                                        sdetweil @JoeFranz
                                        @JoeFranz comment out the mmm-soccer module
                                          JoeFranz
                                          That’s my entry for the MMM-soccer module in config.js…
                                          module: ‘MMM-soccer’,
                                          position: ‘bottom_left’,
                                          api_key: ‘aeed8b37e1224fe699db9416e7c8ec12’,
                                          width: 350,
                                          show: [‘BL1’],
                                          showTables: false,
                                          colored: true,
                                          updateInterval: 60,
                                          focus_on: {‘BL1’: ‘VfL Wolfsburg’},
                                          max_teams: 5,
                                          matchType: ‘league’
                                          /* will not be shown
                                          • mumblebajM
                                            @JoeFranz To comment out a module you need to use /* as the starting and */ as the end.
