    MMM-PIR-Sensor module not working after module update
    32 Posts 3 Posters 12.7k Views 3 Watching
      JoeFranz
        JoeFranz @sdetweil
        S mumblebajM 2 Replies Last reply Reply Quote 0
          sdetweil @JoeFranz
          @JoeFranz looks likes is mmm-soccer w the problem
            JoeFranz
            Without MMM-soccer same error :-(
            • mumblebajM Offline
              mumblebaj Module Developer @JoeFranz
              @JoeFranz Looks more like an issue with the MMM-Formula1. It is the first thing throwing an error. Can you write the npm to file and post the contents of the log file?
              npm start > log.txt 2>&1
                sdetweil @mumblebaj
                @mumblebaj there were no errors in the npm start log info.
                the calendar error is not fatal.
                the soccer error is fatal, as it’s in the web drawing loop.
                @JoeFranz u can’t have the ‘same’ error if u disabled the soccer module
                  JoeFranz
                  The Formula1 module is not active and i have nothing change in the config.js since MMM-PIR-Sensor update.
                  magicmirror@2.12.0 start /home/pi/MagicMirror
                  /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
                  [2020-07-18 18:21:54.455] [LOG] Starting MagicMirror: v2.12.0
                  [2020-07-18 18:21:54.466] [LOG] Loading config …
                  [2020-07-18 18:21:54.476] [LOG] Loading module helpers …
                  [2020-07-18 18:21:54.479] [LOG] No helper found for module: alert.
                  [2020-07-18 18:21:54.541] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:54.542] [LOG] Module helper loaded: updatenotification
                  [2020-07-18 18:21:54.543] [LOG] No helper found for module: clock.
                  [2020-07-18 18:21:55.313] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:55.314] [LOG] Module helper loaded: calendar
                  [2020-07-18 18:21:55.992] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:55.993] [LOG] Module helper loaded: MMM-Tado
                  [2020-07-18 18:21:56.585] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:56.586] [LOG] Module helper loaded: MMM-DarkSkyForecast
                  [2020-07-18 18:21:56.629] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:56.630] [LOG] Module helper loaded: newsfeed
                  [2020-07-18 18:21:57.071] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:57.073] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                  [2020-07-18 18:21:57.094] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:57.095] [LOG] Module helper loaded: MMM-Tools
                  [2020-07-18 18:21:57.098] [LOG] Initializing new module helper …
                  [2020-07-18 18:21:57.099] [LOG] Module helper loaded: mmm-hue-lights
                  [2020-07-18 18:21:57.099] [LOG] All module helpers loaded.
                  [2020-07-18 18:21:57.302] [LOG] Starting server on port 8080 …
                  [2020-07-18 18:21:57.324] [LOG] Server started …
                  [2020-07-18 18:21:57.325] [LOG] Connecting socket for: updatenotification
                  [2020-07-18 18:21:57.327] [LOG] Connecting socket for: calendar
                  [2020-07-18 18:21:57.328] [LOG] Starting node helper for: calendar
                  [2020-07-18 18:21:57.328] [LOG] Connecting socket for: MMM-Tado
                  [2020-07-18 18:21:57.329] [LOG] Connecting socket for: MMM-DarkSkyForecast
                  [2020-07-18 18:21:57.330] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                  [2020-07-18 18:21:57.331] [LOG] Connecting socket for: newsfeed
                  [2020-07-18 18:21:57.332] [LOG] Starting node helper for: newsfeed
                  [2020-07-18 18:21:57.333] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                  [2020-07-18 18:21:57.333] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                  [2020-07-18 18:21:57.334] [LOG] Connecting socket for: MMM-Tools
                  [2020-07-18 18:21:57.337] [LOG] Connecting socket for: mmm-hue-lights
                  [2020-07-18 18:21:57.338] [LOG] Starting node_helper for module [mmm-hue-lights]
                  [2020-07-18 18:21:57.339] [LOG] Sockets connected & modules started …
                  Fontconfig warning: “/etc/fonts/fonts.conf”, line 86: unknown element “blank”
                  /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)
                  [2020-07-18 18:21:57.496] [LOG] Launching application.
                  libGL error: MESA-LOADER: failed to retrieve device information
                  ATTENTION: default value of option force_s3tc_enable overridden by environment.
                  [2020-07-18 18:22:01.271] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                  [2020-07-18 18:22:01.296] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                  [2020-07-18 18:22:01.301] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                  [2020-07-18 18:22:01.314] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                  [2020-07-18 18:22:01.328] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                  [2020-07-18 18:22:01.476] [ERROR] Calendar Error. Could not fetch calendar: http://localhost:8080/MMM-Formula1/schedule.ics 404: Not Found
                  [2020-07-18 18:22:01.533] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:01.535] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:01.578] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                  [2020-07-18 18:22:01.650] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                  [2020-07-18 18:22:01.662] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                  [2020-07-18 18:22:01.678] [LOG] [COVID:CORE] Scan starts.
                  [2020-07-18 18:22:03.860] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                  [2020-07-18 18:22:03.879] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:03.880] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:04.777] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                  [2020-07-18 18:22:04.884] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:04.885] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:05.180] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                  [2020-07-18 18:22:05.268] [INFO] Checking git for module: MMM-Tado
                  [2020-07-18 18:22:05.305] [INFO] Checking git for module: MMM-DarkSkyForecast
                  [2020-07-18 18:22:05.342] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                  [2020-07-18 18:22:05.374] [INFO] Checking git for module: MMM-Tools
                  [2020-07-18 18:22:05.413] [INFO] Checking git for module: mmm-hue-lights
                  [2020-07-18 18:22:05.519] [LOG] - MMM-Tado: Logged in
                  [2020-07-18 18:22:06.068] [INFO] Newsfeed-Fetcher: Broadcasting 28 items.
                  [2020-07-18 18:22:06.193] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                  [2020-07-18 18:22:06.303] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:06.305] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:07.917] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                  [2020-07-18 18:22:07.924] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:07.926] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:08.117] [LOG] [COVID:CORE] Access to data source.
                  [2020-07-18 18:22:08.516] [LOG] - MMM-Tado: Got me()
                  [2020-07-18 18:22:08.518] [LOG] - MMM-Tado: Got homes()
                  [2020-07-18 18:22:08.756] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                  [2020-07-18 18:22:09.204] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:09.213] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:09.384] [LOG] - MMM-Tado: Got zones()
                  [2020-07-18 18:22:09.429] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                  [2020-07-18 18:22:09.876] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                  [2020-07-18 18:22:09.932] [LOG] can’t find property recovered Canada:
                  [2020-07-18 18:22:09.933] [LOG] adding…
                  [2020-07-18 18:22:10.185] [LOG] [COVID:CORE] Calculating Wordlwide total.
                  [2020-07-18 18:22:10.398] [LOG] [COVID:CORE] Scan Completed.
                  [2020-07-18 18:22:11.152] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:11.157] [LOG] - MMM-Tado: Not all data present
                  [2020-07-18 18:22:11.654] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                  [2020-07-18 18:22:12.193] [LOG] - MMM-Tado: Checking if all data is present
                  [2020-07-18 18:22:12.194] [LOG] - MMM-TADO: All data is present
                  [2020-07-18 18:22:37.119] [LOG] Shutting down server…
                  [2020-07-18 18:22:37.157] [LOG] Stopping module helper: updatenotification
                  [2020-07-18 18:22:37.159] [LOG] Stopping module helper: calendar
                  [2020-07-18 18:22:37.161] [LOG] Stopping module helper: MMM-Tado
                  [2020-07-18 18:22:37.169] [LOG] Stopping module helper: MMM-DarkSkyForecast
                  [2020-07-18 18:22:37.171] [LOG] Stopping module helper: newsfeed
                  [2020-07-18 18:22:37.174] [LOG] Stopping module helper: MMM-COVID19-SPARKLINE
                  [2020-07-18 18:22:37.178] [LOG] Stopping module helper: MMM-Tools
                  [2020-07-18 18:22:37.180] [LOG] Stopping module helper: mmm-hue-lights
                  mumblebajM S 2 Replies Last reply Reply Quote 0
                    @JoeFranz How long have you been using the MMM-COVID19-SPARKLINE? When I installed it the other night it caused issues for me. My NPM did not log any issues but the calculations from the module took too long and caused other modules to freeze up.
                      sdetweil @JoeFranz
                      @JoeFranz comment out the mmm-soccer module
                        JoeFranz
                        That’s my entry for the MMM-soccer module in config.js…
                        module: ‘MMM-soccer’,
                        position: ‘bottom_left’,
                        api_key: ‘aeed8b37e1224fe699db9416e7c8ec12’,
                        width: 350,
                        show: [‘BL1’],
                        showTables: false,
                        colored: true,
                        updateInterval: 60,
                        focus_on: {‘BL1’: ‘VfL Wolfsburg’},
                        max_teams: 5,
                        matchType: ‘league’
                        /* will not be shown
                          @JoeFranz To comment out a module you need to use /* as the starting and */ as the end.
                            sdetweil @JoeFranz
                            @JoeFranz but u said same error. there were two.
                              JoeFranz @mumblebaj
                              @mumblebaj said in MMM-PIR-Sensor module not working after module update:
                              It is comment out with /* and */ the * not shown in my post, sorry.
                                sdetweil @JoeFranz
                                @JoeFranz can u show log again please
                                  JoeFranz
                                  [2020-07-18 20:00:56.211] [LOG] Starting MagicMirror: v2.12.0
                                  [2020-07-18 20:00:56.259] [LOG] Loading config …
                                  [2020-07-18 20:00:56.275] [LOG] Loading module helpers …
                                  [2020-07-18 20:00:56.279] [LOG] No helper found for module: alert.
                                  [2020-07-18 20:00:56.417] [LOG] Initializing new module helper …
                                  [2020-07-18 20:00:56.418] [LOG] Module helper loaded: MMM-PIR-Sensor
                                  [2020-07-18 20:00:56.480] [LOG] Initializing new module helper …
                                  [2020-07-18 20:00:56.481] [LOG] Module helper loaded: updatenotification
                                  [2020-07-18 20:00:56.483] [LOG] No helper found for module: clock.
                                  [2020-07-18 20:00:57.914] [LOG] Initializing new module helper …
                                  [2020-07-18 20:00:57.915] [LOG] Module helper loaded: calendar
                                  [2020-07-18 20:00:59.026] [LOG] Initializing new module helper …
                                  [2020-07-18 20:00:59.027] [LOG] Module helper loaded: MMM-Tado
                                  [2020-07-18 20:01:00.063] [LOG] Initializing new module helper …
                                  [2020-07-18 20:01:00.064] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                  [2020-07-18 20:01:00.155] [LOG] Initializing new module helper …
                                  [2020-07-18 20:01:00.156] [LOG] Module helper loaded: newsfeed
                                  [2020-07-18 20:01:00.842] [LOG] Initializing new module helper …
                                  [2020-07-18 20:01:00.843] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                                  [2020-07-18 20:01:00.908] [LOG] Initializing new module helper …
                                  [2020-07-18 20:01:00.909] [LOG] Module helper loaded: MMM-Tools
                                  [2020-07-18 20:01:00.935] [LOG] Initializing new module helper …
                                  [2020-07-18 20:01:00.935] [LOG] Module helper loaded: mmm-hue-lights
                                  [2020-07-18 20:01:00.936] [LOG] All module helpers loaded.
                                  [2020-07-18 20:01:01.285] [LOG] Starting server on port 8080 …
                                  [2020-07-18 20:01:01.316] [LOG] Server started …
                                  [2020-07-18 20:01:01.317] [LOG] Connecting socket for: MMM-PIR-Sensor
                                  [2020-07-18 20:01:01.319] [LOG] Connecting socket for: updatenotification
                                  [2020-07-18 20:01:01.320] [LOG] Connecting socket for: calendar
                                  [2020-07-18 20:01:01.320] [LOG] Starting node helper for: calendar
                                  [2020-07-18 20:01:01.321] [LOG] Connecting socket for: MMM-Tado
                                  [2020-07-18 20:01:01.322] [LOG] Connecting socket for: MMM-DarkSkyForecast
                                  [2020-07-18 20:01:01.323] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                  [2020-07-18 20:01:01.324] [LOG] Connecting socket for: newsfeed
                                  [2020-07-18 20:01:01.325] [LOG] Starting node helper for: newsfeed
                                  [2020-07-18 20:01:01.325] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                                  [2020-07-18 20:01:01.326] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                                  [2020-07-18 20:01:01.327] [LOG] Connecting socket for: MMM-Tools
                                  [2020-07-18 20:01:01.336] [LOG] Connecting socket for: mmm-hue-lights
                                  [2020-07-18 20:01:01.337] [LOG] Starting node_helper for module [mmm-hue-lights]
                                  [2020-07-18 20:01:01.338] [LOG] Sockets connected & modules started …
                                  [2020-07-18 20:01:01.811] [LOG] Launching application.
                                  [2020-07-18 20:01:07.420] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                                  [2020-07-18 20:01:07.482] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                                  [2020-07-18 20:01:07.487] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                                  [2020-07-18 20:01:07.490] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                                  [2020-07-18 20:01:07.494] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                                  [2020-07-18 20:01:07.605] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:07.606] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:07.608] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                                  [2020-07-18 20:01:07.719] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                                  [2020-07-18 20:01:07.723] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                                  [2020-07-18 20:01:07.726] [LOG] [COVID:CORE] Scan starts.
                                  [2020-07-18 20:01:08.209] [INFO] Checking git for module: MMM-PIR-Sensor
                                  [2020-07-18 20:01:08.248] [INFO] Checking git for module: MMM-Tado
                                  [2020-07-18 20:01:08.272] [INFO] Checking git for module: MMM-DarkSkyForecast
                                  [2020-07-18 20:01:08.296] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                                  [2020-07-18 20:01:08.321] [INFO] Checking git for module: MMM-Tools
                                  [2020-07-18 20:01:08.356] [INFO] Checking git for module: mmm-hue-lights
                                  [2020-07-18 20:01:08.609] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:08.611] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:09.277] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                                  [2020-07-18 20:01:11.444] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                                  [2020-07-18 20:01:11.467] [LOG] - MMM-Tado: Logged in
                                  [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:12.040] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                                  [2020-07-18 20:01:12.229] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                                  [2020-07-18 20:01:12.739] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                                  [2020-07-18 20:01:12.746] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:12.747] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:12.771] [LOG] - MMM-Tado: Got me()
                                  [2020-07-18 20:01:12.774] [LOG] - MMM-Tado: Got homes()
                                  [2020-07-18 20:01:14.293] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                                  [2020-07-18 20:01:14.299] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:14.300] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:14.401] [LOG] [COVID:CORE] Access to data source.
                                  [2020-07-18 20:01:14.773] [LOG] - MMM-Tado: Got zones()
                                  [2020-07-18 20:01:15.218] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                                  [2020-07-18 20:01:15.671] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:15.673] [LOG] - MMM-Tado: Not all data present
                                  [2020-07-18 20:01:15.852] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                                  [2020-07-18 20:01:16.318] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                                  [2020-07-18 20:01:16.386] [LOG] can’t find property recovered Canada:
                                  [2020-07-18 20:01:16.387] [LOG] adding…
                                  [2020-07-18 20:01:16.602] [LOG] [COVID:CORE] Calculating Wordlwide total.
                                  [2020-07-18 20:01:16.872] [LOG] [COVID:CORE] Scan Completed.
                                  [2020-07-18 20:01:17.530] [LOG] - MMM-Tado: Checking if all data is present
                                  [2020-07-18 20:01:17.533] [LOG] - MMM-TADO: All data is present
                                  [2020-07-18 20:01:17.732] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                                    sdetweil @JoeFranz
                                    @JoeFranz the other log, developers window
                                      JoeFranz
                                      Bildschirmfoto 2020-07-18 um 20.19.48.jpg Bildschirmfoto 2020-07-18 um 20.19.15.jpg
                                        JoeFranz
                                        Ok little update …
                                        After starting MM the same error, shortly after starting the screen goes into standby. The PIR sensor is not working. After about 5-10 minutes it works again. PIR sensor detects movement and the screen comes out of standby.
                                          sdetweil @JoeFranz
                                          @JoeFranz strange.
