    MMM-PIR-Sensor module not working after module update
    32 Posts 3 Posters 14.4k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer @JoeFranz
      @JoeFranz How long have you been using the MMM-COVID19-SPARKLINE? When I installed it the other night it caused issues for me. My NPM did not log any issues but the calculations from the module took too long and caused other modules to freeze up.
        sdetweil @JoeFranz
        @JoeFranz comment out the mmm-soccer module
          JoeFranz
          That’s my entry for the MMM-soccer module in config.js…
          module: ‘MMM-soccer’,
          position: ‘bottom_left’,
          api_key: ‘aeed8b37e1224fe699db9416e7c8ec12’,
          width: 350,
          show: [‘BL1’],
          showTables: false,
          colored: true,
          updateInterval: 60,
          focus_on: {‘BL1’: ‘VfL Wolfsburg’},
          max_teams: 5,
          matchType: ‘league’
          /* will not be shown
          mumblebajM S 2 Replies Last reply Reply Quote 0
          • mumblebajM
            @JoeFranz To comment out a module you need to use /* as the starting and */ as the end.
              sdetweil @JoeFranz
              @JoeFranz but u said same error. there were two.
                JoeFranz @mumblebaj
                @mumblebaj said in MMM-PIR-Sensor module not working after module update:
                It is comment out with /* and */ the * not shown in my post, sorry.
                  sdetweil @JoeFranz
                  @JoeFranz can u show log again please
                    JoeFranz
                    magicmirror@2.12.0 start /home/pi/MagicMirror
                    [2020-07-18 20:00:56.211] [LOG] Starting MagicMirror: v2.12.0
                    [2020-07-18 20:00:56.259] [LOG] Loading config …
                    [2020-07-18 20:00:56.275] [LOG] Loading module helpers …
                    [2020-07-18 20:00:56.279] [LOG] No helper found for module: alert.
                    [2020-07-18 20:00:56.417] [LOG] Initializing new module helper …
                    [2020-07-18 20:00:56.418] [LOG] Module helper loaded: MMM-PIR-Sensor
                    [2020-07-18 20:00:56.480] [LOG] Initializing new module helper …
                    [2020-07-18 20:00:56.481] [LOG] Module helper loaded: updatenotification
                    [2020-07-18 20:00:56.483] [LOG] No helper found for module: clock.
                    [2020-07-18 20:00:57.914] [LOG] Initializing new module helper …
                    [2020-07-18 20:00:57.915] [LOG] Module helper loaded: calendar
                    [2020-07-18 20:00:59.026] [LOG] Initializing new module helper …
                    [2020-07-18 20:00:59.027] [LOG] Module helper loaded: MMM-Tado
                    [2020-07-18 20:01:00.063] [LOG] Initializing new module helper …
                    [2020-07-18 20:01:00.064] [LOG] Module helper loaded: MMM-DarkSkyForecast
                    [2020-07-18 20:01:00.155] [LOG] Initializing new module helper …
                    [2020-07-18 20:01:00.156] [LOG] Module helper loaded: newsfeed
                    [2020-07-18 20:01:00.842] [LOG] Initializing new module helper …
                    [2020-07-18 20:01:00.843] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                    [2020-07-18 20:01:00.908] [LOG] Initializing new module helper …
                    [2020-07-18 20:01:00.909] [LOG] Module helper loaded: MMM-Tools
                    [2020-07-18 20:01:00.935] [LOG] Initializing new module helper …
                    [2020-07-18 20:01:00.935] [LOG] Module helper loaded: mmm-hue-lights
                    [2020-07-18 20:01:00.936] [LOG] All module helpers loaded.
                    [2020-07-18 20:01:01.285] [LOG] Starting server on port 8080 …
                    [2020-07-18 20:01:01.316] [LOG] Server started …
                    [2020-07-18 20:01:01.317] [LOG] Connecting socket for: MMM-PIR-Sensor
                    [2020-07-18 20:01:01.319] [LOG] Connecting socket for: updatenotification
                    [2020-07-18 20:01:01.320] [LOG] Connecting socket for: calendar
                    [2020-07-18 20:01:01.320] [LOG] Starting node helper for: calendar
                    [2020-07-18 20:01:01.321] [LOG] Connecting socket for: MMM-Tado
                    [2020-07-18 20:01:01.322] [LOG] Connecting socket for: MMM-DarkSkyForecast
                    [2020-07-18 20:01:01.323] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                    [2020-07-18 20:01:01.324] [LOG] Connecting socket for: newsfeed
                    [2020-07-18 20:01:01.325] [LOG] Starting node helper for: newsfeed
                    [2020-07-18 20:01:01.325] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                    [2020-07-18 20:01:01.326] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                    [2020-07-18 20:01:01.327] [LOG] Connecting socket for: MMM-Tools
                    [2020-07-18 20:01:01.336] [LOG] Connecting socket for: mmm-hue-lights
                    [2020-07-18 20:01:01.337] [LOG] Starting node_helper for module [mmm-hue-lights]
                    [2020-07-18 20:01:01.338] [LOG] Sockets connected & modules started …
                    [2020-07-18 20:01:01.811] [LOG] Launching application.
                    [2020-07-18 20:01:07.420] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                    [2020-07-18 20:01:07.482] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                    [2020-07-18 20:01:07.487] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                    [2020-07-18 20:01:07.490] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                    [2020-07-18 20:01:07.494] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                    [2020-07-18 20:01:07.605] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:07.606] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:07.608] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                    [2020-07-18 20:01:07.719] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                    [2020-07-18 20:01:07.723] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                    [2020-07-18 20:01:07.726] [LOG] [COVID:CORE] Scan starts.
                    [2020-07-18 20:01:08.209] [INFO] Checking git for module: MMM-PIR-Sensor
                    [2020-07-18 20:01:08.248] [INFO] Checking git for module: MMM-Tado
                    [2020-07-18 20:01:08.272] [INFO] Checking git for module: MMM-DarkSkyForecast
                    [2020-07-18 20:01:08.296] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                    [2020-07-18 20:01:08.321] [INFO] Checking git for module: MMM-Tools
                    [2020-07-18 20:01:08.356] [INFO] Checking git for module: mmm-hue-lights
                    [2020-07-18 20:01:08.609] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:08.611] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:09.277] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                    [2020-07-18 20:01:11.444] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                    [2020-07-18 20:01:11.467] [LOG] - MMM-Tado: Logged in
                    [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:12.040] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                    [2020-07-18 20:01:12.229] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                    [2020-07-18 20:01:12.739] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                    [2020-07-18 20:01:12.746] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:12.747] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:12.771] [LOG] - MMM-Tado: Got me()
                    [2020-07-18 20:01:12.774] [LOG] - MMM-Tado: Got homes()
                    [2020-07-18 20:01:14.293] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                    [2020-07-18 20:01:14.299] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:14.300] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:14.401] [LOG] [COVID:CORE] Access to data source.
                    [2020-07-18 20:01:14.773] [LOG] - MMM-Tado: Got zones()
                    [2020-07-18 20:01:15.218] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                    [2020-07-18 20:01:15.671] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:15.673] [LOG] - MMM-Tado: Not all data present
                    [2020-07-18 20:01:15.852] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                    [2020-07-18 20:01:16.318] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                    [2020-07-18 20:01:16.386] [LOG] can’t find property recovered Canada:
                    [2020-07-18 20:01:16.387] [LOG] adding…
                    [2020-07-18 20:01:16.602] [LOG] [COVID:CORE] Calculating Wordlwide total.
                    [2020-07-18 20:01:16.872] [LOG] [COVID:CORE] Scan Completed.
                    [2020-07-18 20:01:17.530] [LOG] - MMM-Tado: Checking if all data is present
                    [2020-07-18 20:01:17.533] [LOG] - MMM-TADO: All data is present
                    [2020-07-18 20:01:17.732] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                      sdetweil @JoeFranz
                      @JoeFranz the other log, developers window
                        JoeFranz
                        Bildschirmfoto 2020-07-18 um 20.19.48.jpg Bildschirmfoto 2020-07-18 um 20.19.15.jpg
                          JoeFranz
                          Ok little update …
                          After starting MM the same error, shortly after starting the screen goes into standby. The PIR sensor is not working. After about 5-10 minutes it works again. PIR sensor detects movement and the screen comes out of standby.
                            sdetweil @JoeFranz
                            @JoeFranz strange.
