    MMM-PIR-Sensor module not working after module update
    32 Posts 3 Posters 14.4k Views 3 Watching
      JoeFranz
      That’s my entry for the MMM-soccer module in config.js…
      module: ‘MMM-soccer’,
      position: ‘bottom_left’,
      api_key: ‘aeed8b37e1224fe699db9416e7c8ec12’,
      width: 350,
      show: [‘BL1’],
      showTables: false,
      colored: true,
      updateInterval: 60,
      focus_on: {‘BL1’: ‘VfL Wolfsburg’},
      max_teams: 5,
      matchType: ‘league’
      /* will not be shown
      mumblebajM S 2 Replies Last reply Reply Quote 0
      • mumblebajM
        mumblebaj Module Developer @JoeFranz
        @JoeFranz To comment out a module you need to use /* as the starting and */ as the end.
          sdetweil @JoeFranz
          @JoeFranz but u said same error. there were two.
            JoeFranz @mumblebaj
            @mumblebaj said in MMM-PIR-Sensor module not working after module update:
            It is comment out with /* and */ the * not shown in my post, sorry.
              sdetweil @JoeFranz
              @JoeFranz can u show log again please
                JoeFranz
                magicmirror@2.12.0 start /home/pi/MagicMirror
                [2020-07-18 20:00:56.211] [LOG] Starting MagicMirror: v2.12.0
                [2020-07-18 20:00:56.259] [LOG] Loading config …
                [2020-07-18 20:00:56.275] [LOG] Loading module helpers …
                [2020-07-18 20:00:56.279] [LOG] No helper found for module: alert.
                [2020-07-18 20:00:56.417] [LOG] Initializing new module helper …
                [2020-07-18 20:00:56.418] [LOG] Module helper loaded: MMM-PIR-Sensor
                [2020-07-18 20:00:56.480] [LOG] Initializing new module helper …
                [2020-07-18 20:00:56.481] [LOG] Module helper loaded: updatenotification
                [2020-07-18 20:00:56.483] [LOG] No helper found for module: clock.
                [2020-07-18 20:00:57.914] [LOG] Initializing new module helper …
                [2020-07-18 20:00:57.915] [LOG] Module helper loaded: calendar
                [2020-07-18 20:00:59.026] [LOG] Initializing new module helper …
                [2020-07-18 20:00:59.027] [LOG] Module helper loaded: MMM-Tado
                [2020-07-18 20:01:00.063] [LOG] Initializing new module helper …
                [2020-07-18 20:01:00.064] [LOG] Module helper loaded: MMM-DarkSkyForecast
                [2020-07-18 20:01:00.155] [LOG] Initializing new module helper …
                [2020-07-18 20:01:00.156] [LOG] Module helper loaded: newsfeed
                [2020-07-18 20:01:00.842] [LOG] Initializing new module helper …
                [2020-07-18 20:01:00.843] [LOG] Module helper loaded: MMM-COVID19-SPARKLINE
                [2020-07-18 20:01:00.908] [LOG] Initializing new module helper …
                [2020-07-18 20:01:00.909] [LOG] Module helper loaded: MMM-Tools
                [2020-07-18 20:01:00.935] [LOG] Initializing new module helper …
                [2020-07-18 20:01:00.935] [LOG] Module helper loaded: mmm-hue-lights
                [2020-07-18 20:01:00.936] [LOG] All module helpers loaded.
                [2020-07-18 20:01:01.285] [LOG] Starting server on port 8080 …
                [2020-07-18 20:01:01.316] [LOG] Server started …
                [2020-07-18 20:01:01.317] [LOG] Connecting socket for: MMM-PIR-Sensor
                [2020-07-18 20:01:01.319] [LOG] Connecting socket for: updatenotification
                [2020-07-18 20:01:01.320] [LOG] Connecting socket for: calendar
                [2020-07-18 20:01:01.320] [LOG] Starting node helper for: calendar
                [2020-07-18 20:01:01.321] [LOG] Connecting socket for: MMM-Tado
                [2020-07-18 20:01:01.322] [LOG] Connecting socket for: MMM-DarkSkyForecast
                [2020-07-18 20:01:01.323] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                [2020-07-18 20:01:01.324] [LOG] Connecting socket for: newsfeed
                [2020-07-18 20:01:01.325] [LOG] Starting node helper for: newsfeed
                [2020-07-18 20:01:01.325] [LOG] Connecting socket for: MMM-COVID19-SPARKLINE
                [2020-07-18 20:01:01.326] [LOG] Starting node helper for: MMM-COVID19-SPARKLINE
                [2020-07-18 20:01:01.327] [LOG] Connecting socket for: MMM-Tools
                [2020-07-18 20:01:01.336] [LOG] Connecting socket for: mmm-hue-lights
                [2020-07-18 20:01:01.337] [LOG] Starting node_helper for module [mmm-hue-lights]
                [2020-07-18 20:01:01.338] [LOG] Sockets connected & modules started …
                [2020-07-18 20:01:01.811] [LOG] Launching application.
                [2020-07-18 20:01:07.420] [LOG] Create new calendar fetcher for url: https://p24-calendars.icloud.com/published/2/RZI42MKNIhOnHx93vtTfvCkhhYLoD3Xefk_1-TIxfwNYJH4S_q7JqKO3ULTUgn1TfuS0bKRdQODjZH88Z9X_ZyWMj1KcfbSA_XcjqWokgas - Interval: 300000
                [2020-07-18 20:01:07.482] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/f45jtrqkd9pc25ne28oid2ckbg%40group.calendar.google.com/public/basic.ics - Interval: 300000
                [2020-07-18 20:01:07.487] [LOG] Create new calendar fetcher for url: http://www.project24.info/dav/JMNDA/KOHB/NPD/N/0/bda453a94fcc7de961b6fdcba986b2e6/feiertage.ics - Interval: 300000
                [2020-07-18 20:01:07.490] [LOG] Create new calendar fetcher for url: http://p24-calendars.icloud.com/published/2/7gHy7EORV6hGC51yisVd75vyC1OWCHIxRVW9HGNBFWWCz84lugqogIfqYZQpK6QB38tkfyr9f3WYQS-kBpII7UpEfAXnliowXPB43EyyVAk - Interval: 300000
                [2020-07-18 20:01:07.494] [LOG] Create new calendar fetcher for url: http://localhost:8080/MMM-Formula1/schedule.ics - Interval: 300000
                [2020-07-18 20:01:07.605] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:07.606] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:07.608] [LOG] Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                [2020-07-18 20:01:07.719] [LOG] Create new news fetcher for url: http://www.waz-online.de/rss/feed/waz_schlagzeilen - Interval: 300000
                [2020-07-18 20:01:07.723] [LOG] Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                [2020-07-18 20:01:07.726] [LOG] [COVID:CORE] Scan starts.
                [2020-07-18 20:01:08.209] [INFO] Checking git for module: MMM-PIR-Sensor
                [2020-07-18 20:01:08.248] [INFO] Checking git for module: MMM-Tado
                [2020-07-18 20:01:08.272] [INFO] Checking git for module: MMM-DarkSkyForecast
                [2020-07-18 20:01:08.296] [INFO] Checking git for module: MMM-COVID19-SPARKLINE
                [2020-07-18 20:01:08.321] [INFO] Checking git for module: MMM-Tools
                [2020-07-18 20:01:08.356] [INFO] Checking git for module: mmm-hue-lights
                [2020-07-18 20:01:08.609] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:08.611] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:09.277] [INFO] Newsfeed-Fetcher: Broadcasting 40 items.
                [2020-07-18 20:01:11.444] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                [2020-07-18 20:01:11.467] [LOG] - MMM-Tado: Logged in
                [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:11.490] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:12.040] [INFO] Newsfeed-Fetcher: Broadcasting 10 items.
                [2020-07-18 20:01:12.229] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                [2020-07-18 20:01:12.739] [INFO] Calendar-Fetcher: Broadcasting 3 events.
                [2020-07-18 20:01:12.746] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:12.747] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:12.771] [LOG] - MMM-Tado: Got me()
                [2020-07-18 20:01:12.774] [LOG] - MMM-Tado: Got homes()
                [2020-07-18 20:01:14.293] [INFO] Calendar-Fetcher: Broadcasting 8 events.
                [2020-07-18 20:01:14.299] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:14.300] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:14.401] [LOG] [COVID:CORE] Access to data source.
                [2020-07-18 20:01:14.773] [LOG] - MMM-Tado: Got zones()
                [2020-07-18 20:01:15.218] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
                [2020-07-18 20:01:15.671] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:15.673] [LOG] - MMM-Tado: Not all data present
                [2020-07-18 20:01:15.852] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
                [2020-07-18 20:01:16.318] [LOG] [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
                [2020-07-18 20:01:16.386] [LOG] can’t find property recovered Canada:
                [2020-07-18 20:01:16.387] [LOG] adding…
                [2020-07-18 20:01:16.602] [LOG] [COVID:CORE] Calculating Wordlwide total.
                [2020-07-18 20:01:16.872] [LOG] [COVID:CORE] Scan Completed.
                [2020-07-18 20:01:17.530] [LOG] - MMM-Tado: Checking if all data is present
                [2020-07-18 20:01:17.533] [LOG] - MMM-TADO: All data is present
                [2020-07-18 20:01:17.732] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                  sdetweil @JoeFranz
                  @JoeFranz the other log, developers window
                    JoeFranz
                    Bildschirmfoto 2020-07-18 um 20.19.48.jpg Bildschirmfoto 2020-07-18 um 20.19.15.jpg
                      JoeFranz
                      Ok little update …
                      After starting MM the same error, shortly after starting the screen goes into standby. The PIR sensor is not working. After about 5-10 minutes it works again. PIR sensor detects movement and the screen comes out of standby.
                        sdetweil @JoeFranz
                        @JoeFranz strange.
