    installing mm
    23 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @geo
      @geo are you running MagicMirrorOS? and not the raw MagicMirror app on raspian?
      you did NOT use sudo when u ran the install, correct?
      • G Offline
        geo
        hi i loaded the mm from your script
          sdetweil @geo
          @geo so, it still makes no sense
          you open a terminal window, ctrl-alt-t, and the install.log should be right there
          u have to edit it,
          nano install.log
          or type it
          cat install.log
            Mykle1 Project Sponsor Module Developer @geo
            @geo said in installing mm:
            i am at a loss as to what to do next other than to sell everything.
            It may take a little time and a few attempts but follow @sdetweil’s directions and he will help you get it running.
            • G Offline
              geo
              nstall starting - Wed Jul 15 11:26:24 BST 2020
              installing on armv7l processor system
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretc$
              ^[[96mUpdating packages …^[[90m
              Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB] Hit:$
              apt-get update completed ok
              apt-get upgrade started
              apt upgrade result =rc=100 Reading package lists…
              Building dependency tree…
              Reading state information…
              You might want to run ‘apt --fix-broken install’ to correct these.
              The following packages have unmet dependencies:
              apt-utils : Depends: apt (= 1.4.8) but 1.4.10 is installed
              E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or spec$
              ^[[96mInstalling helper tools …^[[90m
              build-essential is already the newest version (12.3).
              [ Read 415 lines ]
              ^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
              ^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
                sdetweil @geo
                @geo can u please try with buster, stretch is too old
                • G Offline
                  geo @Mykle1
                  @Mykle1 hi again, yes i realise that its more to do with my frustration and lack of understanding.
                    sdetweil @geo
                    @geo we’ve all been there, patience.
                    • G Offline
                      geo
                      debian stretch v 9.11.tried to install buster several times and failed.messages unmet depedencies,and try,apt – fixbroken install
                      hope this makes sense
                        sdetweil @geo
                        @geo I understand the words, but don’t understand why you have this problem. I tested 2.12 on buster a couple weeks ago, again.
