    G-assistant and Spotify
    8 Posts 2 Posters 1.3k Views 2 Watching
      A Former User
      Are you sure that’s an MMM-GoogleAssistant or Spotify issue ?
      because natively MMM-GoogleAssistant can’t control Spotify volume
        sdmydbr @Guest
        @Bugsounet I really can’t figure out what issue is that. For instance I was playing Spotify in my android tv in another room, when I run the google assistant in my mirror, after interacting with the assistant the volume of the Spotify on my android tv goes to 100% in my android tv, same case of I’m playing Spotify on my mirror, the volume goes to 100%. I don’t know how to figure out the problem.
          sdmydbr @Guest
          @Bugsounet I don’t know how to figure out the problem.
          So I have tried various combinations such as
          G-assistant(phone)+Spotify (phone)= fine
          Assistant (mirror)+Spotify(phone)=fine
          Spotify(mirror)+assistant (phone=fine
          Assistant (mirror)+Spotify (mirror)= volume increases to 100%
          And then I tried with android tv
          Spotify (tv) + assistant (tv) = fine
          Assistant (mobile) + Spotify (tv)= fine
          Spotify (phone) + assistant (tv)= fine
          Spotify (mirror) + assistant (tv)= fine
          Assistant (mirror) + Spotify (tv) = volume increases to 100%.
          Try to reproduce this issue, I can only conclude that there might be some bug in the google assistant module.
            A Former User
            hi, yes it’s +/- a tmp bug
            • A2D control librespot device.
            • I reduce the volume (minVolume) on google response
            • I put maxVolume on standby
            todo:
            -> I have to register actual volume before reduce volume
            -> I have to set old volume value on standby mode
            note: maxVolume and minVolume is on spotify: {} field of A2D Config
              sdmydbr @Guest
              @Bugsounet thanks for looking into it, I hope it will be fixed soon
                A Former User
                @sdmydbr : Corrected with v2.3.3 of A2D
                  sdmydbr @Guest
                  @Bugsounet thank you 🤩
