    MMPM 2.01 Now Available on PyPI!
    11 Posts 5 Posters 4.1k Views 5 Watching
      bee-mar
      MMPM version 2.01 can now be downloaded through PyPI!
      Please see the MMPM GitHub for usage and setup. Also, please review the MMPM Environment Variables, which are extremely important to set properly.
        requiemmg
        Thanks for your work!
        Do I start the upgrade process from mmpm’s CLI if I have 1.x installed or do i need to uninstall and reinstall?
          requiemmg
          Uninstalled MMPM 1 and installed MMPM 2. Problem:
          mmpm install --gui # to install the GUI (needs sudo permissions)
          When I execute this without sudo, I get a bad Gateway error by nginx when I try to call the URI.
          Wenn I do “sudo mmpm install --gui” it tells me “mmpm not found”, as well as when I try “sudo su” and then execute the command. How do I fix this?
            sonicgoose
            Installation fails with
            with error mmpm is not installed.
            • swvalentiS Offline
              swvalenti Project Sponsor
              Clear browser cache
                sonicgoose @swvalenti
                @swvalenti What browser cache? This is in Terminal.
                  @sonicgoose I was referrring to @requiemmg as I got a bad Gateway error by nginx when I called the url. I cleared the cache and it resolved. Also @requiemmg there is probably a clash with MMPM 1 so do the following then install again.
                  pip3 uninstall mmpm
                  rm ~/.local/bin/mmpm
                  pip3 install —reinstall —no-cache-dir —local mmpm
                    bee-mar
                    The installation process can be found here: https://github.com/Bee-Mar/mmpm/wiki/MMPM-Installation
                    Then, you should configure the environment variables: https://github.com/Bee-Mar/mmpm/wiki/MMPM-Environment-Variables
                    And for configuring the hide/show feature: https://github.com/Bee-Mar/mmpm/wiki/Status,-Hide,-Show-MagicMirror-Modules
                    Review other sections of the Wiki as well.
                    You don’t need to clone the repo at all to install MMPM 2.01. You can run the command below, and your current installation will be upgraded.
                    $ pip3 install --upgrade --no-cache-dir mmpm
                    For a full installation of MMPM 2.01:
                    $ mmpm install --gui
                    $ mmpm install --as-module
                    $ mmpm install --autocomplete
                    Do not used sudo in front of any of the above commands. MMPM will use sudo internally when installing the GUI.
                      [[global:former-user]]
                      @bee-mar
                      Do you plan code exception for MM modules or npm module ?
                      exemple in my case (and maybe for others):
                      • I use google grpc library and with RPI lastest version don’t work with RPI (developer don’t want to fix it)
                        So i fix it by using only the working package and can’t be upgraded automaticaly
                      • You can have some electron braking library (module not found) because it’s not rebuilded
                      That’s why option or exception will be needed
                        requiemmg
                        Now I have a strange problem:
                        MMPM 2.01 worked for me for a few days.
                        Yesterday, on one of my 2 mirrors (they are both exactly the same hardware, config and setup, in fact I have set up one and cloned its drive to the others SD card) i got a Nginx 502 Bad gateway error when I tried to open up the MMPM GUI.
                        I did a full uninstall of MMPM and reinstalled. Worked as intended.
                        This morning the error again (the Pi does a scheduled reboot in the night).
                        Reinstalled again.
                        Browser cache is cleared.
                        Mirror 1 - works perfectly
                        Mirror 2 - works after reinstallation until i make a reboot.
                        Installed with --force-reinstall, --no-cache-dir and --upgrade
                        Anyone having an idea?
                          requiemmg
                          Addition: mmpm log shows this.
                          No errors in pm2 log.
                          Excerpt from my config:
                          var config = {
                          	address: "0.0.0.0", // Address to listen on, can be:
                          	port: 8080,
                          	ipWhitelist: [], // Set [] to allow all IP addresses
                          This is mmpm log:
                          2020/07/29 10:49:53 [error] 735#735: *35 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.0.100, server: _, request: "GET / HTTP/1.1", upstream: "http://[::1]:7891/", host: "192.168.0.123:7890"
                          2020/07/29 10:49:53 [error] 735#735: *35 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.0.100, server: _, request: "GET /favicon.ico HTTP/1.1", upstream: "http://[::1]:7891/favicon.ico", host: "192.168.0.123:7890"
