MMPM 2.01 Now Available on PyPI!
11 Posts 5 Posters 2.9k Views 5 Watching
    bee-mar
    MMPM version 2.01 can now be downloaded through PyPI!
    Please see the MMPM GitHub for usage and setup. Also, please review the MMPM Environment Variables, which are extremely important to set properly.
      requiemmg
      Thanks for your work!
      Do I start the upgrade process from mmpm’s CLI if I have 1.x installed or do i need to uninstall and reinstall?
        requiemmg
        Uninstalled MMPM 1 and installed MMPM 2. Problem:
        mmpm install --gui # to install the GUI (needs sudo permissions)
        When I execute this without sudo, I get a bad Gateway error by nginx when I try to call the URI.
        Wenn I do “sudo mmpm install --gui” it tells me “mmpm not found”, as well as when I try “sudo su” and then execute the command. How do I fix this?
          sonicgoose
          Installation fails with
          with error mmpm is not installed.
            swvalenti Project Sponsor
            Clear browser cache
            S 1 Reply Last reply Jul 27, 2020, 1:55 PM Reply Quote 0
              sonicgoose @swvalenti
              @swvalenti What browser cache? This is in Terminal.
                @sonicgoose I was referrring to @requiemmg as I got a bad Gateway error by nginx when I called the url. I cleared the cache and it resolved. Also @requiemmg there is probably a clash with MMPM 1 so do the following then install again.
                pip3 uninstall mmpm
                rm ~/.local/bin/mmpm
                pip3 install —reinstall —no-cache-dir —local mmpm
                  bee-mar
                  The installation process can be found here: https://github.com/Bee-Mar/mmpm/wiki/MMPM-Installation
                  Then, you should configure the environment variables: https://github.com/Bee-Mar/mmpm/wiki/MMPM-Environment-Variables
                  And for configuring the hide/show feature: https://github.com/Bee-Mar/mmpm/wiki/Status,-Hide,-Show-MagicMirror-Modules
                  Review other sections of the Wiki as well.
                  You don’t need to clone the repo at all to install MMPM 2.01. You can run the command below, and your current installation will be upgraded.
                  $ pip3 install --upgrade --no-cache-dir mmpm
                  For a full installation of MMPM 2.01:
                  $ mmpm install --gui
                  $ mmpm install --as-module
                  $ mmpm install --autocomplete
                  Do not used sudo in front of any of the above commands. MMPM will use sudo internally when installing the GUI.
                    A Former User
                    @bee-mar
                    Do you plan code exception for MM modules or npm module ?
                    exemple in my case (and maybe for others):
                    • I use google grpc library and with RPI lastest version don’t work with RPI (developer don’t want to fix it)
                      So i fix it by using only the working package and can’t be upgraded automaticaly
                    • You can have some electron braking library (module not found) because it’s not rebuilded
                    That’s why option or exception will be needed
                      requiemmg
                      Now I have a strange problem:
                      MMPM 2.01 worked for me for a few days.
                      Yesterday, on one of my 2 mirrors (they are both exactly the same hardware, config and setup, in fact I have set up one and cloned its drive to the others SD card) i got a Nginx 502 Bad gateway error when I tried to open up the MMPM GUI.
                      I did a full uninstall of MMPM and reinstalled. Worked as intended.
                      This morning the error again (the Pi does a scheduled reboot in the night).
                      Reinstalled again.
                      Browser cache is cleared.
                      Mirror 1 - works perfectly
                      Mirror 2 - works after reinstallation until i make a reboot.
                      Installed with --force-reinstall, --no-cache-dir and --upgrade
                      Anyone having an idea?
