    MMM-Sunrise-Sunset
    44 Posts 9 Posters 26.1k Views 10 Watching
      dankerthrone @sdetweil
      pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
      ls: cannot access 'node_modules': No such file or directory
      … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
        dankerthrone
        after rebooting, the black screen of MagicMirror now shows this in the developer console:
        Starting module: MMM-Sunrise-Sunset
        MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
            at Class.updateSun (MMM-Sunrise-Sunset.js:50)
            at Class.start (MMM-Sunrise-Sunset.js:12)
            at startModules (loader.js:55)
            at loader.js:40
            at HTMLLinkElement.stylesheet.onload (loader.js:200)
        DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
        DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
            at Class.scrollComic (DailyXKCD.js:177)
            at DailyXKCD.js:51
            at DailyXKCD.js:51
        I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
          sdetweil @dankerthrone
          @dankerthrone installing a new module is pretty easy
          cd MagicMirror/modules
          git clone http:// the url of the git repo
          cd the name of the module
          if there is a package.,json file, then to load its dependencies do
          npm install
          then
          cd ~/MagicMirror/config
          nano config.js
          insert the module definition  info, (see the module readme.md)
          save
          then restart mirror app
          this module does NOT list its dependency on jquery as it should
          so, you have to fix it manually.
          SO, i don’t know where you were when u did the npm install jquery
          lets find it
          find . | grep jquery\.js
            @dankerthrone said in MMM-Sunrise-Sunset:
            DailyXKCD
            the XKCD errors look like poor programming by the author
            he tries to find the web content before its there, but doesn’t check if he got the location
              finding jquery as you suggested returns
              pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
              ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                @dankerthrone hm… not where I would have expected it…
                so. lets try this again
                cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
                npm install jquery
                ls node_modules/jquery
                you should see this
                AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                then do
                 cp node_modules/jquery/dist/jquery.js .
                then
                ls jquery.js
                to prove the file is in the module folder
                i just did it all here step by step
                  siggmur
                  Late to the game, but I also am getting black screen after installing the module and adding it to my config. Ill try to give you the steps:
                  Did the git pull. Went into the folder, npm install.
                  Added this to my config:
                  module: 'MMM-Sunrise-Sunset',
                  position: "bottom_center",
                  latitude: "69.13",
                  longitude: "18.59",
                  apiKey: "myAPI",
                  layout: "inline",
                  I also tried @sdetweil post, without any difference. I find the files as listed, did pm2 restart mm without any help.
                  Ideas?
                    sdetweil @siggmur
                    @siggmur latitude and longitude are numbers, remove the quotes.
                    general rule, for values to the right of :
                    number or true/false - not quoted
                    all else, quoted, doesn’t matter which one, just matching.
                    also, lat/long usually are 6 digits
                    xx.yyyy
                      siggmur
                      Thanks for the quick reply, I forgot the quotation marks, but it should throw a config error, not a black screen like I am getting?
                        sdetweil @siggmur
                        @siggmur black screen usually means missing library file.
                        look at the startup.messages
                        either
                        pm2 logs --lines=100
                        or the terminal window where do
                        npm start
                          siggmur
                          @sdetweil ah, now we might be cooking. I find to suspected issues, but I am a bit to noobish to understand:
                          [2020-08-01 01:35:48.402] [LOG] No helper found for module: MMM-Sunrise-Sunset.
                          and:
                          Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
                          [2020-08-01 01:35:50.724] [ERROR] Whoops! There was an uncaught exception…
                          [2020-08-01 01:35:50.727] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                          at listenInCluster (net.js:1274:12)
                          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                          code: ‘EADDRINUSE’,
                          errno: ‘EADDRINUSE’,
                          syscall: ‘listen’,
                          address: ‘127.0.0.1’,
                          port: 8080
                          Any idea what it could be?
                            sdetweil @siggmur
                            @siggmur eaddr in use means something is still using that port 8080,
                            pm2’s job is to start at boot, so you can have more than one running
                            keep stopping
                            check w
                            ps -ef | grep node |grep -v grep
                            kill things til u get none.
                            then
                            npm start
                            • 3 / 3
