    Auto Reload on Config File Change
    11 Posts 4 Posters 5.7k Views 4 Watching
      sdetweil @mjurgens
      @mjurgens are you using pm2 to start your mm?
        mjurgens
        @mjurgens said in Auto Reload on Config File Change:
        automatic script from sdetweil
        I believe so. I think your script sets that up
          sdetweil @mjurgens
          @mjurgens I have seen inconsistent results with change detection in pm2. I have not debugged it…
            mjurgens @sdetweil
            That probably explains it - a bug - it was strange how it suddenly just stopped working
            • BKeyportB Offline
              BKeyport Module Developer
              It’s actually not a bug, or more like a bug with PM2 that it stops.
              the initial setup sets it up for --watch on the Pm2 line, when it restarts, it’ll eventually forget about that command line point.
              • E Offline
                ember1205
                I have a script that I run every 15 minutes via cron that checks for updates to the config file. It compares the time and date stamp of the config file against the time and date stamp of the pid file from when MM was started. If the config file is newer, it restarts MM.
                        if [ /home/pi/MagicMirror/config/config.js -nt /home/pi/.pm2/pids/mm-0.pid ]; then
                                /usr/bin/pm2 restart mm
                        fi
                  mjurgens
                  What I have done to resolve this is installed the inotify-tools package and then setup a systemd service using the inotifywait command. This watches the config dir and on change triggers a “pm2 restart MagicMirror” command
                    mjurgens
                    Actually, now that I set up my own auto restart, the pm2 one or whatever was doing it to start with has started working again.
                    So now the question is - how do I disable the preconfigured built-in auto restart?
                      sdetweil @mjurgens
                      @mjurgens edit the installers.pm2_MagicMirror_json file, and remove the watch: line and the trailing comma from the prior line. then do
                      # remove old version, not editable
                      pm2 remove 0
                      # cleanup saved task repo
                      pm2 save
                      # start new app
                      pm2 start installers/p2_MagicMirror.json
                      # save  app in restart repo
                      pm2 save
                      • BKeyportB Offline
                        BKeyport Module Developer @mjurgens
                        @mjurgens can you explain the inotify setup? Sounds interesting.
