    Magic Mirror 2 won't start
    8 Posts 2 Posters 1.1k Views 2 Watching
      sdetweil @Stef
      @Stef the release notes for this update says that in addition to the git pull, you must also do an npm install in the MagicMirror folder, see
      https://forum.magicmirror.builders/topic/13182/v2-12-0
      in the future, please u the automated update script from here.
        Stef
        @sdetweil Sorry, i forgot about the Release notes…
        I did this, the error is gone but i still have around 50% CPU load, the autostart is not working and i have a black screen when i start the mirror manually…
        Any ideas?
          sdetweil @Stef
          @Stef show the output of
          pm2 logs --lines=100
            Stef @sdetweil
            @sdetweil well… It did not stop… So I forced it
            Linux mirrorpi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Fri Jul 31 18:29:29 2020 from 192.168.0.199
            pi@mirrorpi:~ $ pm2 logs --lines=100
            PM2        | 2020-07-31T23:45:34: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:35: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:35: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:35: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:36: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:36: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:36: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:36: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:36: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:37: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:38: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:41: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:44: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:48: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:51: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:54: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:45:57: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:00: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:03: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:05: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:08: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:11: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:12: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:14: PM2 log: App [mm:2] online
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:1] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:2] exited with code [254] via signal [SIGINT]
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:1] starting in -fork mode-
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:2] starting in -fork mode-
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:1] online
            PM2        | 2020-07-31T23:46:17: PM2 log: App [mm:2] online
            /home/pi/.pm2/logs/pm2-logrotate-error.log last 100 lines:
            0|pm2-logr | [Error: ENOENT: no such file or directory, unlink '/home/pi/.pm2/logs/mm-error__2020-07-15_00-00-00.log'] {
            0|pm2-logr |   errno: -2,
            0|pm2-logr |   code: 'ENOENT',
            0|pm2-logr |   syscall: 'unlink',
            0|pm2-logr |   path: '/home/pi/.pm2/logs/mm-error__2020-07-15_00-00-00.log'
            0|pm2-logr | }
            0|pm2-logr | [Error: ENOENT: no such file or directory, unlink '/home/pi/.pm2/logs/mm-error__2020-07-16_20-14-10.log'] {
            0|pm2-logr |   path: '/home/pi/.pm2/logs/mm-error__2020-07-16_20-14-10.log'
            0|pm2-logr | }
            0|pm2-logr | [Error: ENOENT: no such file or directory, unlink '/home/pi/.pm2/logs/mm-error__2020-07-17_00-01-34.log'] {
            0|pm2-logr |   path: '/home/pi/.pm2/logs/mm-error__2020-07-17_00-01-34.log'
            0|pm2-logr | }
            0|pm2-logr | [Error: ENOENT: no such file or directory, unlink '/home/pi/.pm2/logs/mm-error__2020-07-17_13-46-14.log'] {
            0|pm2-logr |   path: '/home/pi/.pm2/logs/mm-error__2020-07-17_13-46-14.log'
            0|pm2-logr | }
            /home/pi/.pm2/logs/pm2-logrotate-out.log last 100 lines:
            0|pm2-logr | "/home/pi/.pm2/logs/pm2-logrotate-out__2020-07-31_00-00-13.log" has been created
            0|pm2-logr | "/home/pi/.pm2/logs/pm2-logrotate-error__2020-07-31_00-00-13.log" has been created
            0|pm2-logr | "pm2-logrotate-out__2020-06-24_00-00-14.log" has been deleted
            0|pm2-logr | "/home/pi/.pm2/logs/mm-error__2020-07-31_00-00-13.log" has been created
            0|pm2-logr | "mm-error__2020-07-15_00-00-00.log" has been deleted
            0|pm2-logr | "/home/pi/.pm2/logs/mm-error__2020-07-31_06-12-22.log" has been created
            0|pm2-logr | "mm-error__2020-07-16_20-14-10.log" has been deleted
            0|pm2-logr | "/home/pi/.pm2/logs/mm-error__2020-07-31_12-19-24.log" has been created
            0|pm2-logr | "mm-error__2020-07-17_00-01-34.log" has been deleted
            0|pm2-logr | "/home/pi/.pm2/pm2__2020-07-31_13-01-24.log" has been created
            0|pm2-logr | "pm2__2020-06-17_14-07-43.log" has been deleted
            0|pm2-logr | "/home/pi/.pm2/logs/mm-error__2020-07-31_18-29-27.log" has been created
            0|pm2-logr | "mm-error__2020-07-17_13-46-14.log" has been deleted
            1|mm       | npm ERR! enoent
            1|mm       | npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            1|mm       | npm ERR! enoent This is related to npm not being able to find a file.
            1|mm       |
            1|mm       |
            1|mm       | npm ERR! A complete log of this run can be found in:
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_08_015Z-debug.log
            1|mm       | /home/pi/mm.sh: Zeile 1: cd: /~MagicMirror: Datei oder Verzeichnis nicht gefunden
            1|mm       | npm npm ERR! code ENOENT
            1|mm       | ERR! code ENOENT
            1|mm       | npm ERR! syscallnpm ERR! syscall open
            1|mm       | npm ERR! open
            1|mm       | npm ERR! path /home/pi/package.json
            1|mm       | npm path /home/pi/package.json
            1|mm       | npm ERR! errno -2
            1|mm       |  ERR! errno -2
            1|mm       |
            1|mm       |
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_10_895Z-debug.log
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_10_894Z-debug.log
            1|mm       | npm ERR! code ENOENT
            1|mm       | npm ERR! syscall open
            1|mm       |
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_12_794Z-debug.log
            1|mm       |
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_12_823Z-debug.log
            1|mm       | npmnpm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            1|mm       |  ERR! enoent This is related to npm not being able to find a file.
            1|mm       |
            1|mm       |
            1|mm       | npm ERR!npm ERR! A complete log of this run can be found in:
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_14_790Z-debug.log
            1|mm       |      /home/pi/.npm/_logs/2020-07-31T21_46_14_793Z-debug.log
            1|mm       | npm ERR! npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            1|mm       | syscall open
            1|mm       |
            1|mm       |
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_16_929Z-debug.log
            1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_16_923Z-debug.log
            1|mm  | npm
            2|mm  | npm
            1|mm  | npm
            1|mm  | ERR! syscall open
            1|mm  | npm ERR!
            1|mm  | path /home/pi/package.json
            2|mm  |  ERR! code ENOENT
            2|mm  | npm
            2|mm  |  ERR! syscall open
            2|mm  | npm ERR!
            2|mm  | path /home/pi/package.json
            2|mm  | npm ERR! errno
            2|mm  |  -2
            1|mm  |  This is related to npm not being able to find a file.
            2|mm  | npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            2|mm  | npm ERR! enoent This is related to npm not being able to find a file.
            2|mm  | npm
            2|mm  |  ERR! enoent
            1|mm  | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_21_246Z-debug.log
            2|mm  | npm ERR! A complete log of this run can be found in:
            2|mm  | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_21_253Z-debug.log
            PM2      | App [mm:1] exited with code [254] via signal [SIGINT]
            PM2      | App [mm:2] exited with code [254] via signal [SIGINT]
            PM2      | App [mm:1] starting in -fork mode-
            PM2      | App [mm:2] starting in -fork mode-
            PM2      | App [mm:1] online
            PM2      | App [mm:2] online
            2|mm     | /home/pi/mm.sh: Zeile 1: cd: /~MagicMirror: Datei oder Verzeichnis nicht gefunden
            1|mm     | npm
            2|mm     | npm ERR! code
            2|mm     |  ENOENT
            2|mm     | npm ERR! syscall open
            2|mm     | npm ERR! path /home/pi/package.json
            2|mm     | npm ERR! errno -2
            2|mm     |  ENOENT: no such file or directory, open '/home/pi/package.json'
            2|mm     | npm ERR!
            2|mm     |  enoent
            2|mm     | npm ERR! A complete log of this run can be found in:2|mm     | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_23_904Z-debug.log
            1|mm     | npm ERR! A complete log of this run can be found in:1|mm     | npm ERR!     /home/pi/.npm/_logs/2020-07-31T21_46_23_900Z-debug.log
            ^C
            pi@mirrorpi:~ $
              sdetweil @Stef
              @Stef pm2 stop all
              pm2 info
              for some reason some script is trying to do npm start in the users home folder.
              pm2 remove that one (0 or 1)
              pm2 save
              pm2 flush
              then pm2 info, and look at the script being run , examine and test the script.
              then pm2 start (0/1 whatever is left)
                Stef
                I did all this.
                pm2 remove did not work (not recognised as a command) so i did a pm2 delete on both instances.
                All i get now, is a black screen & an error with the Modul “MMM-DHT-Sensor”
                [2020-08-02 17:45:35.346] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node-dht-sensor/build/Release/node_dht_sensor.node'
                was compiled against a different Node.js version using
                NODE_MODULE_VERSION 64. This version of Node.js requires
                NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                the module (for instance, using `npm rebuild` or `npm install`).
                If i remove the Folder from the modules, the Mirror boots up.
                Since the Mirror is loading now, this Topic can be closed and i will open up another one.
                Thanks!
                  sdetweil @Stef
                  @Stef great! I can never remember remove vs delete, but u got it, and found the actual problem.
                  I posted steps in the other topic
