    MMM-KeyBindings Error
    2 Posts 1 Posters 478 Views 1 Watching
      banbutcher
      ive installed mmm-keybindings and ive got it working the way i want but ive just noticed that when i start MM i get this error:
      [2020-07-31 20:27:28.838] [ERROR]  Whoops! There was an uncaught exception...
      [2020-07-31 20:27:28.845] [ERROR]  Error: Cannot find module 'evdev'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js
          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Class.startEvdevMonitor (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:61:17)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:99:22)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:112:11)
          at Socket.emit (events.js:200:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at processTicksAndRejections (internal/process/task_queues.js:82:9) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      [2020-07-31 20:27:28.861] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-07-31 20:27:28.874] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      i dont think it affects MM but id like to get rid of it coming up, any help is much apprecated!
      Richie
        banbutcher
        ive figured it out… just had to add the line:
        evdev: {enabled: false],
