    MMM-network-signal not showing
    10 Posts 2 Posters 1.8k Views 2 Watching
    • I
      icmike52
      Runnning MagicMirror v 2.12.0
      I’m missing something simple. Following the instructions…
      I’ve cloned the repo into /MagicMirror/modules directory
      npm install ping (From the MMM-network-signal directory. Not sure if it had to be this directory)
      npm i
      And am using this code in my config.js
      module: “MMM-network-signal”,
      position: “bottom_left”,
      Nothing shows! I’m not seeing anything meaningful in the log, unless it’s not seeing the helper. (npm ping I assume)
      0|mm | > magicmirror@2.12.0 start /home/pi/MagicMirror
      0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      0|mm | [2020-08-01 16:33:47.745] [LOG]
      0|mm | Starting MagicMirror: v2.12.0
      0|mm | [2020-08-01 16:33:47.759] [LOG]
      0|mm | Loading config …
      0|mm | [2020-08-01 16:33:47.773] [LOG]
      0|mm | Loading module helpers …
      0|mm | [2020-08-01 16:33:47.777] [LOG] No helper found for module: alert.
      0|mm | [2020-08-01 16:33:47.893] [LOG]
      0|mm | Initializing new module helper …
      0|mm | [2020-08-01 16:33:47.894] [LOG] Module helper loaded: updatenotification
      0|mm | [2020-08-01 16:33:47.896] [LOG] No helper found for module: clock.
      0|mm | [2020-08-01 16:33:48.656] [LOG]
      0|mm | [2020-08-01 16:33:48.657] [LOG] Module helper loaded: calendar
      0|mm | [2020-08-01 16:33:48.661] [LOG] Initializing new module helper …
      0|mm | [2020-08-01 16:33:48.662] [LOG] Module helper loaded: MMM-MyScoreboard
      0|mm | [2020-08-01 16:33:48.663] [LOG]
      0|mm | No helper found for module: currentweather.
      0|mm | [2020-08-01 16:33:48.665] [LOG] No helper found for module: weatherforecast.
      0|mm | [2020-08-01 16:33:48.667] [LOG] No helper found for module: MMM-network-signal.
      0|mm | [2020-08-01 16:33:48.668] [LOG] All module helpers loaded.
      0|mm | [2020-08-01 16:33:48.883] [LOG]
      0|mm | Starting server on port 8080 …
      0|mm | [2020-08-01 16:33:48.894] [INFO]
      0|mm | You’re using a full whitelist configuration to allow for all IPs
      0|mm | [2020-08-01 16:33:48.908] [LOG]
      0|mm | Server started …
      0|mm | [2020-08-01 16:33:48.909] [LOG] Connecting socket for: updatenotification
      0|mm | [2020-08-01 16:33:48.911] [LOG] Connecting socket for: calendar
      0|mm | [2020-08-01 16:33:48.913] [LOG] Starting node helper for: calendar
      0|mm | [2020-08-01 16:33:48.914] [LOG] Connecting socket for: MMM-MyScoreboard
      0|mm | [2020-08-01 16:33:48.916] [LOG] Starting node_helper for module [MMM-MyScoreboard]
      0|mm | [2020-08-01 16:33:49.964] [LOG]
      0|mm | Sockets connected & modules started …
      0|mm | [2020-08-01 16:33:50.113] [LOG]
      0|mm | Launching application.
      0|mm | [2020-08-01 16:33:53.003] [LOG]
      0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxxxxxxxxxxx/basic.ics - Interval: 300000
      0|mm | [2020-08-01 16:33:53.189] [INFO]
      0|mm | Checking git for module: MMM-MyScoreboard
      0|mm | [2020-08-01 16:33:54.796] [INFO]
      0|mm | Calendar-Fetcher: Broadcasting 26 events.
      0|mm | [2020-08-01 16:34:10.414] [LOG]
      Raspberry Pi 3
      MagicMirror 2.12.0
      Always learning
        sdetweil @icmike52
        @icmike52 said in MMM-network-signal not showing:
        npm i
        so the instructions for https://github.com/PoOwAa/MMM-network-signal.git say
        Clone this repo into ~/MagicMirror/modules directory.
        Install dependencies npm i
        missing step between
        cd MMM-network-signal
        I installed using these steps and it displays lower right
        • I
          icmike52
          Thanks for the quick response. I did both commands “npm i” and “npm install ping” from the /home/pi/MagicMirror/modules/MMM-network-signal-master directory
          pi@raspberrypi:~/MagicMirror/modules/MMM-network-signal-master $ npm install
          added 3 packages from 20 contributors and audited 3 packages in 1.296s
          found 0 vulnerabilities
          Sorry, I’m still missing something simple. Still learning.
          Raspberry Pi 3
          MagicMirror 2.12.0
          Always learning
            sdetweil @icmike52
            @icmike52 and then restarted mm?
            • I
              icmike52
              Yes
              pm2 restart mm
              Raspberry Pi 3
              MagicMirror 2.12.0
              Always learning
                sdetweil @icmike52
                @icmike52 ok, on the mirror, open the developers window ctrl-shift-i, and select the elements tab, and navigate to the position where u configured module.
                bottom-left
                then locate module there and examine it’s dom content
                • I
                  icmike52
                  That is useful. Thanks, Sam.
                  Load script: modules/MMM-network-signal//MMM-network-signal.js
                  loader.js:191 GET http://0.0.0.0:8080/modules/MMM-network-signal//MMM-network-signal.js net::ERR_ABORTED 404 (Not Found)
                  loader.js:185 Error on loading script: modules/MMM-network-signal//MMM-network-signal.js
                  But makes no sense 404 Not Found. I have not edited the MMM-network-signal.js file . The only address i see the the MMM-network-signal.js file is 8.8.8.8 (Google DNS) which I can ping just fine. I’ve even changed the server: “192.168.0.1” and it made no difference.
                  Raspberry Pi 3
                  MagicMirror 2.12.0
                  Always learning
                    sdetweil @icmike52
                    @icmike52 so, filesystem in linux is case sensitive, so module: name,
                    and folder in MM/Modules and filename all have to be exactly the same
                    that is telling
                    as there IS a node_helper for this module… SO, looks like the foldername is wrong…
                    can you do
                    cd ~/MagicMirror/modules
                    ls -laF
                    I 1 Reply Last reply
                    • I
                      icmike52 @sdetweil
                      pi@raspberrypi:~/MagicMirror/modules $ ls -laf
                      MMM-network-signal-master MMM-Tools …
                      MMM-BMW-OW default MMM-Remote-Control
                      MMM-MyScoreboard . MMM-History
                      I renamed the folder “MMM-network-signal-master” to “MMM-network-signal” and it is now working. So simple when you know what to look for. Thanks Sam! I learned something.
                      FYI I seem to remember I downloaded the folder https://github.com/PoOwAa/MMM-network-signal.git from https://github.com/PoOwAa/MMM-network-signal
                      When I unzipped it, the folder name was wrong.
                      Raspberry Pi 3
                      MagicMirror 2.12.0
                      Always learning
                        sdetweil @icmike52
                        yes, u did the zip download process, instead of the git clone process
                        the zip download adds the repo branch name to the unzipped folder name
                        the git clone process does not
                        also, the zip process disables the git pull update process for modules… i recommend NEVER using the zip download process
