    MMM-network-signal not showing
    10 Posts 2 Posters 1.3k Views 2 Watching
      sdetweil @icmike52
      @icmike52 and then restarted mm?
      • I Offline
        icmike52
        Yes
        pm2 restart mm
        Raspberry Pi 3
        MagicMirror 2.12.0
        Always learning
          sdetweil @icmike52
          @icmike52 ok, on the mirror, open the developers window ctrl-shift-i, and select the elements tab, and navigate to the position where u configured module.
          bottom-left
          then locate module there and examine it’s dom content
          • I Offline
            icmike52
            That is useful. Thanks, Sam.
            Load script: modules/MMM-network-signal//MMM-network-signal.js
            loader.js:191 GET http://0.0.0.0:8080/modules/MMM-network-signal//MMM-network-signal.js net::ERR_ABORTED 404 (Not Found)
            loader.js:185 Error on loading script: modules/MMM-network-signal//MMM-network-signal.js
            But makes no sense 404 Not Found. I have not edited the MMM-network-signal.js file . The only address i see the the MMM-network-signal.js file is 8.8.8.8 (Google DNS) which I can ping just fine. I’ve even changed the server: “192.168.0.1” and it made no difference.
            Raspberry Pi 3
            MagicMirror 2.12.0
            Always learning
              sdetweil @icmike52
              @icmike52 so, filesystem in linux is case sensitive, so module: name,
              and folder in MM/Modules and filename all have to be exactly the same
              that is telling
              0|mm | [2020-08-01 16:33:48.667] [LOG] No helper found for module: MMM-network-signal.
              as there IS a node_helper for this module… SO, looks like the foldername is wrong…
              can you do
              cd ~/MagicMirror/modules
              ls -laF
              • I Offline
                icmike52 @sdetweil
                pi@raspberrypi:~/MagicMirror/modules $ ls -laf
                MMM-network-signal-master MMM-Tools …
                MMM-BMW-OW default MMM-Remote-Control
                MMM-MyScoreboard . MMM-History
                I renamed the folder “MMM-network-signal-master” to “MMM-network-signal” and it is now working. So simple when you know what to look for. Thanks Sam! I learned something.
                FYI I seem to remember I downloaded the folder https://github.com/PoOwAa/MMM-network-signal.git from https://github.com/PoOwAa/MMM-network-signal
                When I unzipped it, the folder name was wrong.
                Raspberry Pi 3
                MagicMirror 2.12.0
                Always learning
                  sdetweil @icmike52
                  @icmike52 said in MMM-network-signal not showing:
                  yes, u did the zip download process, instead of the git clone process
                  the zip download adds the repo branch name to the unzipped folder name
                  the git clone process does not
                  also, the zip process disables the git pull update process for modules… i recommend NEVER using the zip download process
