Calendar module events stop displaying before due time/date
18 Posts 2 Posters 3.4k Views 2 Watching
    castletonroad
    I export my calendars with recurring events (e.g. school timetable) from NextCloud 18.0.4, to .ICS files, which I then feed to the Calendar module of my MagicMirror.
    The day before events are due, they all show, e.g. a full school day of lessons shows for tomorrow. But when I wake up in the morning and look at the calendar (say, 6am-ish), the first two lessons/periods have already dropped-off the calendar view, and lesson 3 is showing as up next, say, in 4 hours time. I can then see the next day’s first 2 or 3 lessons showing. Throughout the day, as lessons come and go, new lessons for tomorrow correctly show, until in the evening, all of tomorrow’s lessons are showing.
    This happens everyday for all of my school timetable’s first two events (lessons) - these lessons all have different details. These events all show fine in NextCloud (and via all devices that view the calendar by CalDav).
    Every term I update the events by shifting forward by a couple of months all of the recurrent events that make up the school timetable. Each school year, I then change the details of the lessons.
    Is the ‘bug’ something in the exported .ICS file, noting that the other five lessons every day all show correct? OR is this an issue with the Calendar module.
    The MagicMirror is up-to-date, is running only one custom module (Spotify), and is running on an up-to-date build of raspberry pi OS (Buster).
    Any light anyone can shed on this issue would be greatly appreciated.
    Thanks very much.
    S 1 Reply Last reply Aug 5, 2020, 12:26 AM Reply Quote 0
    • S Away
      sdetweil @castletonroad
      @castletonroad when u look at the calendar on screen, do the events show time (8am) or relative (2 hours). And they line up correctly w expected start time?
      mm uses the system time
      cal should have a timezone value.
      if u edit the ics u should see the setting, does it match what u expect?
        castletonroad
        Hi, thanks for replying.
        On the MagicMirror, currently (7pm), the school timetable calendar events are showing with start times and correctly, e.g. ‘Tomorrow at 08.25’.
        Entries in the .ICS file include (e.g. for lesson 2, which is a problem):
        DTSTART;TZID=Australia/Sydney:20200720T092000
        DTEND;TZID=Australia/Sydney:20200720T101500
        …and for lesson 3 (a short one, and not a problem entry):
        DTSTART;TZID=Australia/Sydney:20200722T101500
        DTEND;TZID=Australia/Sydney:20200722T103000
        All seems fine, right?
        S 2 Replies Last reply Aug 5, 2020, 11:38 AM Reply Quote 0
        • S Away
          @castletonroad and the pi is set to the same tz/location, correct?
          C 1 Reply Last reply Aug 5, 2020, 9:34 PM Reply Quote 0
          • S Away
            @castletonroad what is wrong on cal display for lesson 2
            start July 22, 2020 09:20:00
            end July 22, 2020 10:15:00
            C 1 Reply Last reply Aug 5, 2020, 9:31 PM Reply Quote 0
              castletonroad @sdetweil
              The display on the MM is fine the day before.
              But every morning, lesson 2 (and lesson 1) is no longer showing on the MM.
              Next event showing on the MM is lesson 3, 10.30 to 11.25, even though it’s still only 6am.
              S 1 Reply Last reply Aug 5, 2020, 9:35 PM Reply Quote 0
                Yes, correct.
                pi@raspberrypi2:~ $ date +“%Z %z”
                AEST +1000
                pi@raspberrypi2:~ $
                As I mentioned, the issue is just with the first two events each day in this timetable.
                I might delete one recurring event and replace it with a brand new one.
                • S Away
                  @castletonroad so, that means to me the pi is set to the wrong timezone, even tho displaying the right numbers for the time.
                  what is the location setting under the operating system calendar, upper right, right click,
                  locations
                  C 1 Reply Last reply Aug 5, 2020, 9:52 PM Reply Quote 0
                    Sorry, I should have said - I’m in Australia, AEST is correct for me.
                    S 1 Reply Last reply Aug 5, 2020, 9:59 PM Reply Quote 0
                    • S Away
                      @castletonroad you tz said Australia.
                      there have been a number of problems w calendar and recurring events. no fix yet that can see.
                      I would try the redo of the event. where do u create it? PC, mobile, web?
                      C 2 Replies Last reply Aug 5, 2020, 10:28 PM Reply Quote 0
