    Calendar module events stop displaying before due time/date
    18 Posts 2 Posters 7.0k Views 2 Watching
      castletonroad
      Hi, thanks for replying.
      On the MagicMirror, currently (7pm), the school timetable calendar events are showing with start times and correctly, e.g. ‘Tomorrow at 08.25’.
      Entries in the .ICS file include (e.g. for lesson 2, which is a problem):
      DTSTART;TZID=Australia/Sydney:20200720T092000
      DTEND;TZID=Australia/Sydney:20200720T101500
      …and for lesson 3 (a short one, and not a problem entry):
      DTSTART;TZID=Australia/Sydney:20200722T101500
      DTEND;TZID=Australia/Sydney:20200722T103000
      All seems fine, right?
        sdetweil @castletonroad
        @castletonroad and the pi is set to the same tz/location, correct?
          @castletonroad what is wrong on cal display for lesson 2
          start July 22, 2020 09:20:00
          end July 22, 2020 10:15:00
            castletonroad @sdetweil
            The display on the MM is fine the day before.
            But every morning, lesson 2 (and lesson 1) is no longer showing on the MM.
            Next event showing on the MM is lesson 3, 10.30 to 11.25, even though it’s still only 6am.
              Yes, correct.
              pi@raspberrypi2:~ $ date +“%Z %z”
              AEST +1000
              pi@raspberrypi2:~ $
              As I mentioned, the issue is just with the first two events each day in this timetable.
              I might delete one recurring event and replace it with a brand new one.
                @castletonroad so, that means to me the pi is set to the wrong timezone, even tho displaying the right numbers for the time.
                what is the location setting under the operating system calendar, upper right, right click,
                locations
                  Sorry, I should have said - I’m in Australia, AEST is correct for me.
                    @castletonroad you tz said Australia.
                    there have been a number of problems w calendar and recurring events. no fix yet that can see.
                    I would try the redo of the event. where do u create it? PC, mobile, web?
                    C 2 Replies Last reply Reply Quote 0
                      I created the appointments a couple of years ago in Google, then imported them and have been using them since. I edit them via the NextCloud web interface. I have a script that exports them to .ICS for MM to read.
                      I will recreate a couple (the whole things takes an age as the timetable runs on a two week cycle) and see how that turns out for tomorrow. I’ll report back.
                      (The Calendar module is literally the main reason for my MM!)
                      Thanks for taking the time to help out.
                        I created a new event for tomorrow:
                        BEGIN:VEVENT
                        CREATED:20200806T005525Z
                        DTSTAMP:20200806T005659Z
                        LAST-MODIFIED:20200806T005659Z
                        SEQUENCE:3
                        UID:ffae8dff-cd39-4315-977c-762a0b47544c
                        DTSTART;TZID=Australia/Sydney:20200724T082500
                        DTEND;TZID=Australia/Sydney:20200724T092000
                        SUMMARY:NEW P1 - LESSON (ROOM No.)
                        RRULE:FREQ=WEEKLY;COUNT=5;INTERVAL=2;BYDAY=FR
                        END:VEVENT
                        Look at CREATED:20200806T005525Z. This is 12.55am, right? I created this at about 10.55am, so a 10hr time diff - AEST <> GMT.
                        Is this relevant?
                          @castletonroad shouldn’t matter, in my opinion
                            @castletonroad I recommend opening an issue on the MagicMirror GitHub issue page. there is work going on the resolve calendar problems now
                              Will do.
                              BTW, I created two new recurring events (new lessons 1 and 2) on my iPhone, then edited the recurrence specifics on the NextCloud calendar app web page (as the iPhone is limited in the ‘custom’ options for events it offers). This morning, neither of the new events showed on the Mirror, so same problem.
                              I then created a new NON-recurring event on my iPhone (start at 09.20), and restarted the MM - the event showed.
                              I then used my iPhone to make the event RECURRING, and restarted the MM - the event DOES NOT show.
                              I THEN set the start to be 10.30 (vs. 09.20) - and the recurring event showed on the MM again!
                              10.05 - the recurring event shows.
                              10.00 - the recurring event shows.
                              09.55 - the recurring event DOES NOT show.
                              I then removed the recurrence - the event shows again.
                              So definitely something to do with event recurrence AND timezones. A recurring event starting within my TZ difference from midnight does not show.
                              What do you think?
                              Thanks for your help with this :)
                                @castletonroad add that to the issue. make an ics for both with/without recurrence. add to the issue.
                                guys are looking for recreatable things to test against.
                                this is really my fault. I opened an issue last year, as we were have cal problems, but using old code. the team updated to the latest library code, which fixed some problems, but has caused more
                                  Hi, issue created.
                                    @castletonroad awesome! thank you
