    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 16.9k Views 4 Watching
    • Cr4z33C
      Cr4z33 @sdetweil
      @sdetweil thanks I already saw that page, but it talks about translateX and there’s no evidence of it in that module’s CSS.
        sdetweil @Cr4z33
        @Cr4z33 ok, so. try it. maybe the default is right to left if not specified.
        worst case u have the existing file still
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil nope I didn’t get what I wanted. :person_shrugging_medium-dark_skin_tone:
            A Former User
            @Cr4z33 : see this
            I think it can help
              i did this, commented out the old in the MMM-NewsFeedTicker.css
              and replaced with this
              /*@-webkit-keyframes marquee {
                0% { left: 100%; }
                100% { left: -100%; }
              @-moz-keyframes marquee {
                0% { left: 100%; }
              @-ms-keyframes marquee {
                0% { left: 100%; }
              @-o-keyframes marquee {
                0% { left: 100%; }
              @keyframes marquee {
                0% { left: 100%; }
              /* new stuff here */
                 0% {
                  transform: translate(-100%, 0);
                50% {
                  transform: translate(-50%, 0);
                100% {
                  transform: translate(0, 0);
              • Cr4z33C
                Cr4z33 @sdetweil
                @sdetweil thank you gonna try asap! :D
                • Cr4z33C
                  Cr4z33
                  OK this is getting weird now because I applied the above code and it STILL keeps scrolling back and forth! :anguished_face:
                    sdetweil @Cr4z33
                    @Cr4z33 did u delete the old code?
                      0% { left: 100%; }
                      0% { left: 100%; }
                      0% { left: 100%; }
                      0% { left: 100%; }
                      0% { left: 100%; }
                    notice the /* and */
                    • Cr4z33C
                      Cr4z33
                      @sdetweil of course I did. :)
                        sdetweil @Cr4z33
                        @Cr4z33 whoops. left out a change comment out the animations for other browsers
                        .MMM-NewsFeedTicker .tickerbody {
                          margin: 0 auto;
                          width: 100%;
                          padding-top: 5px;
                          position: relative;
                          white-space: nowrap;
                          overflow: visible;
                          /*-webkit-animation: marquee linear infinite;
                          -moz-animation: marquee linear infinite;
                          -ms-animation: marquee linear infinite;
                          -o-animation: marquee linear infinite; */
                        weird… on 2.11 it scrolls right to left
                        on 2.12 is scrolls left to right
                          i installed it again on my desktop system (from laptop), and it works as expected (on MM 2.12)
                          • Cr4z33C
                            Cr4z33 @sdetweil
                            @sdetweil nope mine ist still going back and forth.
                              sdetweil @Cr4z33
                              @Cr4z33 weird… I just re-installed MM and the module and changed the css and changed the newsfeed module config entry to MMM-NewsFeedTicker and started, left to right
                              			module: "MMM-NewsFeedTicker",
                              			position: "bottom_bar",
                              				feeds: [
                              						title: "New York Times",
                              						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                              				showSourceTitle: true,
                              				showPublishDate: true,
                              				broadcastNewsFeeds: true,
                              				broadcastNewsUpdates: true
                                from my dropbox , screen video capture
                                https://www.dropbox.com/s/vab6t9j0oa95zyw/Kazam_screencast_00000.mp4?dl=0
                                Cr4z33C 2 Replies Last reply Reply Quote 0
                                • Cr4z33C
                                  Cr4z33 @sdetweil
                                  • Cr4z33C
                                    Cr4z33 @sdetweil
                                      I don’t understand. the default, the text ( the beginning of the line of text) starts to appear on the right side of the screen and scrolls to the left ( last showing the end of the line of text)
                                      my change, per your request, the end of the text appears on the left of the screen, and scrolls to the right ( last showing the beginning of the line of text)
                                      this is for left to right language English. I don’t know if language setting changes the default marquee order
                                        @Cr4z33 did u see my post above?
                                        • Cr4z33C
                                          Cr4z33 @sdetweil
                                          @sdetweil said in [MMM-NewsFeedTicker] scroll from left to right only?:
                                          Yep saw also the video.
                                          Dunno why my MM system ignores the CSS edit… :confounded_face:
                                            sdetweil @Cr4z33
                                            @Cr4z33 do you have a custom.css setting which would override the module?
